Porsche 1999 C4 996 over heating concern; initially reported on August 21, 2009
After having the engine replaced, I noticed the engine compartment cooling fan would come on after shutting the motor down, even when the ambient temperatures were in the 50's F. In hot weather with temps over 90 F or so, the over temp light would flash. At the time we were in Nevada in July and just had to wait until sundown to drive any distance. We took it into a dealer in Reno who said that other than some grasshoppers, the radiators looked clean. And of course, we ran with the A/C turned off. The car, a 1999 996 C4 sat in the barn over winter and saw little road time. Now as spring has returned, so has the flashing overtemp light, again with outside temps only in the 60's.
So following the advice given last year; I pulled the bumper cover and cleaned out the radiators. Not surprisingly both were covered with debris over 30 percent of the frontal area. The debris was leaves, bugs, and a stiff coating of dust with the majority of it on the engine radiator, not on the A/C heat exchanger. The borescope could not see the area where all the junk was. Interesting how the dirt got packed into the space between the two. Cleaning was done with a vacuum and soft bristle brush; perhaps I should have pressure washed the radiators, but was not able to do so inside the garage. Next time I'll do the tear down outside and do a better job.
Problem solved? The overtemp light has not flashed after driving in stop and go traffic. However, the fan still comes on after shutdown. The dashboard gage quickly climbs to "180" with the needle right between 8 and 0 (and it is still no warmer outside that the mid 60F's). So far it has not gone above the indicated "180" under varying driving conditions. The fan typically runs 2 to 3 minutes after shutting the engine down, and then turns off.
My concern is with the factory replacement engine, now with less than 6 months of warranty remaining; is there something still wrong? Again the old motor hardly ever ran the fan after turning it off. I initially attributed the situation to a new motor that might be a bit "tight". However with more than 5000 miles on it, I doubt that is the reason for the apparent excess engine heat.
Earlier in the warranty period I experienced the dreaded oil in the coolant problem. After more than a week in the shop, the dealer found the "new" oil cooler was leaking oil into the coolant. After replacing the cooler and many fill and flush cycles later using the "special" factory specified block coolant cleaner (all under warranty), that problem was said to be resolved. I fear I may still have a problem and after sinking an amazing amount of money into the car, I can't believe that I have to go through the warranty claim process again.
But I will, with vigor. Is my experience as described a cause for concern? If so, what might I do to verify there is a problem before taking it back into a dealer? I plan to start taking temp data with Durametric software and would like to know which parameters are of significance to my situation? Hopefully recording the pertinent data should either help to clear my concerns, or verify there is a problem. There were no fault codes in the memory at last check.
Any and all suggestions are most appreciated.
