jbrewer
Everything posted by jbrewer
  1. Thanks Minny! I had similar ticking sound that was so distinctive that it had me concerned I might be in for a huge expense. Can't tell you how happy I was to find a loose spark plug! Tightened up on the plug and the ticking is gone. I'll have to make another donation to RennTech.Org! :renntech:
  2. Mike - How did you make out?
  3. Jeff - What happened? How did you resolve your problem? I got a tranny stuck in 3rd but doesn't appear to be a cable problem. (sorry about the blank post. just figured out you can edit a post)
  4. After ignoring my check engine light for several weeks my 2000 996 failed to start immediately after refueling. The engine would turn over very well but wouldn't catch. After two or three tries and maybe 3 to 5 minutes the car would start. This happened twice (for some reason I dread sitting in a disabled Porsche in public). I thought it was time to take it in however, next refuel didn't result in restart problem. A few days later I am accelerating after entering the boulevard and all of a sudden I loose power. Fortunately I was lucky to be able to pull off the road into a parking lot with the momentum I had established (avoided that dreaded incident of being on side of the road in a disabled Porsche). I engaged the parking brake, put transmission in neutral and attempted to rev up the engine. RPM would not exceed 1300 regardless of pedal position. Now I knew it was time to take it in (duh). I turned the car off and restarted it. Surprisingly I could now rev the engine to any level. Figured my luck may be running low so I had it towed into the shop. Diagnosis was failed evap fuel valve. Just got it back. The part that was replaced listed as a "Vent Line" on shop invoice. Part number 996 110 129 52 maps to something called a "Regeneration Valve From Throttle Body for Fuel Vapor System". Check engine light is gone and seems fine. For some reason this doesn't feel like it's over. Will update later on whether it solved my problem.
  5. No progress. Haven't taken the car in for the test. It's taking me a while to "pucker up" :) Although the beeping and clicking is "driving me up the wall". Just received assessment. Water damage to Alarm Control Unit under driver's seat. Alarm Control Unit needs to be replaced. This was likely caused by clogged drain ( I have noticed moisture on floor behind drivers seat before). I could live without an alarm at this stage however, I'm told that it's not possible to disconnect the alarm system. I read that these units have to be programmed so I suspect it's not likely a DIY job if all you have is a set of metric wrenches (like myself). Also, unless I can find the "key code" I'll need to purchase new keys to remotely lock/unlock the car.
  6. No progress. Haven't taken the car in for the test. It's taking me a while to "pucker up" :) Although the beeping and clicking is "driving me up the wall".
  7. Thanks, car is a coupe. will check the microswitch thing (if I have one) and get the alarm system tested. Will report back after testing....
  8. I have an 2000 996 and recently noticed that my doors will lock and unlock periodically while I'm driving. Sometimes I press the dash switch to unlock the door and the horn beeps twice, interior lights come on and the lock remains engaged. The lights dim after a few seconds. Sometimes while unlocking the door with the key remote the horn will beep twice. The car is certainly trying to tell me something I just don't speak beep. Please help!
  9. Just performed this procedure. Took me 2 hours. Saved me big money. I donated some to Renntech!
  10. oops . . . Mobil1 0W40 About 1 qt per 600-700 miles. Used to be about 1 qt per 1500 miles. Changed over the winter. Jon - What did you find out?
  11. 2000 C2 Coupe, 6 speed - original owner, 106,000 smiles. 3rd RMS counting original. Replaced Transmission at about 90,000 miles (not smiling at that moment). Burning about 1Qt oil every 2000 miles or so. I drive it everyday. Some days I drive it with no where to go. I am really hoping for at least 200,000. Can anyone comment on whether oil consumption is coincident with the reported engine failures?
