gixxer1127
    queens,nyc
    2005 Cayenne Turbo w/E81 package
gixxer1127's Achievements
  1. Sir: I don't know what area of the country in which you live. I live in San Diego and have kept my front end " clean " on my 2006 C2S by not placing a plate on it, it came from the dealer bracket and plate holder not attached. If I am stopped by a police officer for a " fix-it " ticket, I will double tape the plate to the front bumper and get it signed off, then remove the plate No ticket fee here in San Diego... just a fix-it ticket. Others have used the towing portal in the front bumper and have rigged plate holders from that opening....good luck. I like the look of no plate. Chromedome agreeeeeeeeeeeeeeeeeeeed!!
  2. Does anyone have the diagram or which wire to trigger the door sills to light up?? The way its run now they will light up anytime the footwell lights are on, so i cant keep them dim like i prefer to
  3. fabspeeds I have a set if you are interested (used 2 months)
  4. its more for weight dustribution Also you do know there are terminals under the hood in the event you need to boost the truck
  5. :jump: uuummm you do realize the battery is under the drivers seat from the factory right?
  6. i had the dealer change mine (1 hour labor), i have my original wheel (multi in black) if you are interested
  7. without the flares, they come right to the fenders edge (my truck has the wider rears, i dunno if the backspacing is the same)
  8. i had mine replaced at a top end body shop who are notorious for being anal about their work and i have no complaints
  9. my belt just broke on saturday, my truck has 35,000 miles on it. The dealer Roslyn Porsche just called with concerns about the aftermarket items my truck has (cargraphic muffler, evoms intake and turbo mike aluminum intake- no chip). WTF are they kidding me??? and it has a porsche 100,000 warranty
  10. I believe he is referring to the Porsche OEM wheel spacers that you could have ordered directly from the option sheet
  11. my truck also has the tequipment wheel flares so they dont stick out at all
  12. i have them on the back of mine with the 10in wide technos
  13. gixxer i have the same set up as you (AERO KIT) what bulbs did you use for the fogs? i just used regular bulbs
  14. i had them installed on mine even though the advertising claimed that it would not set off the fault code and it would take 15 minutes to set off the code so i removed them. Regular bulbs produce much better light with my new aero kit lamps anyway
  15. had that happen to mine, dealer changed a acceleration sensor?
