kubota
Everything posted by kubota
  1. Just pull hard its held by two clips at the back. see picture
  2. opening the cluster isnt to difficult a few screws and clips. however swapping the gauge faces asks for removing the needles this is quite tricky. i've just swapped the internals of two clusters because i didn't want to remove the needles hope this helps
  3. I used a piece of plastic but you can use a piece of wood, set it up against the side. Get a hamer a just give it a tap. it should come right of. i couldn't get it of with my hands either
  4. You'll need to slide it to the right.
  5. Folders is not a problem, i use multiple folder each for every artist. You can easily navigate using the audio button Have had some problem that the drive wouldn't read certain mp3 files this was due to the files weren't lame encoded. Hope this helps
  6. Porsche has 5mm spacers from H&R as an option those come with the longer bolts
  7. They must have had their rear wheels spaced. Then you get another set of longer ones, because the original ones are too short. However no idea why they don't have the dimple.
  8. To get the lightswitch out just push it in and twist it to the left, thats all. Hope this helps
  9. 2007 v6 new model
  10. Hi, I'm looking for a part number for the both front doors on a new model cayenne 957 Any help appreciated thanks!
  11. If you use a turbo rear bumper on standard carrera dont you have any clearance issues with the mufflers? Or are you going to use a custom exhaust system? I'd love to see some pictures of the turbo bumper on your carrera :D
  12. I think the salesman is right since the gt2 is a widebody just like the turbo. the standard carerra has an offset of 57 front and 67 rear. and the turbo has an offset of 57 front and 51 rear. Maybe if you put spacers in between it can be done
  13. Wow really nice looking! Do you happen to know when porsche is going to declare the gt3 set end of life?
  14. Went to porsche today and asked if they could help me and the printed me the entire service manual about how to remove the dash. So that was absolutely great. If anyone is interested about how it is to be done send me a PM. here's the pic when everything was removed after three hours of hard work.
  15. Hi Loren Could you send me a copy of the service manual? that would be great. I'm willing to try that first instead of completly replacing the dash.
  16. Thanks everbody but the drawing helped to remove some pieces but still dont know how to remove the dash itself I also spoke to someone at the porsche centre. He saided if the airbags came out you'll have to replace the entire dash since there is an steel or aluminium plate underneath which bended under the airbag detonation here's a pic of the problem
  17. Hi there, I own a 997 c2s which i bought with accident damage however the airbags also popped. Which i ofcourse will have to replace. Does anybody in here know how to remove the complete dash since this will needed to be replaced. Have used the search but didnt found any topics which showed the complete removal. Any help appreciated. Kind regards
