JFP in PA
  1. Front trunk, rear engine cover, doors, center console, interior sensor.
  2. Nothing really. You need to see a trace of the voltage movement over time for both sensors on the same side at the same time. Should look like this: If they follow each other like this, you have a bad sensor:
  3. You need a scan tool that reads the O2 sensor voltages in real time, and preferably graphs the values. One sensor on each side should by cycling, while the other draws a straight voltage line. If both are cycling, one of the sensors is out. My concern would be that someone just worked on the car and may of crated a wiring issue that is screwing up one sensor on each side, causing the issue. This is where there is no substitute for the correct diagnostic equipment. I would start by using the above chart to determine that you really have the correct sensor in the correct locations; otherwise you will be chasing your tail trying to sort this out......
  4. The codes indicate that the warmup cats are operating below the efficiency threshold.
  5. Welcome to RennTech Looks like you have an alarm fault. As you have the Durametric, you should be able to read the last ten alarm faults stored in the DME, which will point you to the source.
  6. Welcome to RennTech Check your fuel pressure and fuel delivery rates, you may have a pump on the way out.
  7. Take it back to whoever did the repairs and tell them to make it right.
  8. I'm well aware of the cost. Porsche, like other manufacturers, often updates one item (like the cable) due to known problems, which forces you to update other associated parts as well. You can either replace it, or "MacGyver" the repair; your choice...………. And stop buying from Pelican, they are both over priced and often substitute what they call "OEM" parts that are actually after market. Board sponsor Sunset Porsche will give you both the best price and the latest genuine Porsche parts every time.
  9. Use the updated parts, they were updated for a reason.
  10. Welcome to RennTech Easiest way to find out what is trigger the alarm is to scan the car with a Porsche specific scan tool like the Durametric system. The DME stores the last 10 alarm faults in memory.
  11. P1502 is the code for a short circuit in the end stage fuel pump relay circuit. Check the relay, if it is OK, check the wiring from the DME to the fuel pump relay for a short to B+.
  12. Yup, a very large 600 ft. Lbs. torque wrench.
  13. Not really, I searched Amazon for automotive grommet sets and found several with multiple sizes included and picked one that looked like it would cover our needs.
  14. You are not going to find a comprehensive size list. We keep a selection of grommet's we bought on Amazon for such occasions.
  15. I’m not surprised that anyone would not honor any warranty after it has expired; that is why it has a date on it. Also not surprised about your comment on the EPS bearing, falls into the rules of small numbers.
  16. What is your concern? If the IMS was replaced with a quality retrofit like the LN system, you have miles to go before anything needs to be done. Go drive it like you stole it!
  17. Welcome to RennTech Try contacting board sponsors Sunset Porsche in Beaverton OR.
  18. Welcome to RennTech No. It is the drive that moves the clamshell.
  19. First of all, you should be running a 160F thermostat and not the 195 F factory unit. If you suspect the stat, pull it and get a low temp unit. You also need to know that the dash temp display in these cars are notoriously inaccurate as well as non linear. The best way to monitor the coolant temp is with a Porsche scan tool like the Durametric system.
  20. First of all, it is nearly impossible to get all of the coolant out of these cars; at best you are going to drain around 85% or so of the total capacity, so with a 5 gallon system, that is about 4 and 1/4 gallons. Second, with the Uview evacuated down to 25-28 inches of vacuum, there is no air trapped anywhere in the system, even if it is still partially full of coolant, period. It simply is not possible for any air to remain. Once one of these cars is refilled under vacuum, there is absolutely no need to open bleeder valves, jack the car up or anything else. That is the beauty of vacuum refilling. I seriously doubt there is a "blockage", and even if the thermostat was welded shut, there are still by pass coolant passages around it.
  21. There is no way to add coolant at the radiators. The factory evacuates the system with the Uview and draws the coolant in under vacuum, and the car holds around 5 gallons total.
  22. The PWM is triggered by a signal from the DME, which gets the coolant temp from the same senor that operates the dash gauge. As these dash displays are well known to be both non linear as well as flat out inaccurate, I would suggest reading the DME temp by connecting the car to a Porsche specific scan tool. The car may not be as hot as the dash makes you think it is.........
  23. It should lock into the very bottom of the canister housing; if it no longer does, you need to either buy a new canister, or switch the car over to a spin on style filter which is a much better option.
  24. Your radiator fans are controlled by what is call plus width modulation, which is built into the fan motor itself, and therefore rather difficult to modify.
  25. Sounds like it is the factory oil bypass unit that should be attached to the bottom of the filter canister.
