JFP in PA
  1. Welcome to RennTech Couple of possibles: (1) A wiring issue causing the heaters to malfunction. (2) The reflash itself. A lot of people have experienced all sorts of weird DME issues after getting aftermarket reflashes done as these systems are quite often set up to try to eek out small power gains by trying to trick the basic DME engine control functions, everything from strange codes to blocking connection to the OBD II port. Returning the vehicle to the factory DME flash put an end to the problems.
  2. As each line on the oil level gauge is a small fraction of a liter (somewhere around 0.2 L), by adding a two quart (or liter) sump extension, and then lowering the level two bars from the full line, you have still increased your total oil capacity by around 1.6 L; and as any increase in oil capacity is generally a good thing, you are still ahead of the game. 😉
  3. Not even remotely correct in this world. But I would agree that Porsche's A40 spec is irrelevant as it is a marketing tool, not a lubricant specification. If you want real specs, consider products that meet or exceed ACEA A3/B3/B4, which are real, technically based and widely accepted performance standards.
  4. A "breather" is simply and atmospheric vent, not unlike an open window. The vacuum signal "throttling" done by the AOS is much like the thermostat in your home: It keeps the environment in the sump at a controlled level. If there were no vacuum level, the low tension rings would not seal, pressure would build up, and engine oil seals would blow out. Too high a vacuum signal and the intake starts inhaling oil as Jake showed in his video and the engine kills itself. The AOS vacuum throttling function keeps the sump "just right". 😉 That part in the diagram marked "breather" is actually how the sump vents any pressure that might build up after the engine is shut down and there is no vacuum. The pressure would wend its way around the system and back into the intake manifold, and back out into the world. It all has to go somewhere; the engine cannot function as a sealed vessel.
  5. On the track, it is not uncommon to see one of these engines blow some oil smoke. Sometimes this may only happen in certain corners, and not in others. Problem stems from too much oil being retained in the upper engine area (read cam covers), where it cannot drain down fast enough through the M96's oil scavenging system, and the AOS becomes overwhelmed. This is one of the reasons Porsche developed the X51 package, which uses a "northwest passage" extra scavenging system to get the oil back down where it belongs. One trick a lot of track rats learn is to drop the oil level in the sump a couple of bars to help control the oil level in the heads. On the street, we always filled customer's sumps to at least two bars below the max line for this exact reason. We also tested everyone of the cars that passed through the shop for sump vacuum levels, as the AOS deteriorates and then fails a lot more often than people expect. It should be considered a maintence consumable item that needs to be replaced before it begins to fail. One comment on your diagram: The actual intake vacuum signal at idle can be as high as 26-28 inches of mercury, and one inch of Hg is 13.6 inches of water. The only time the intake would drop to anywhere near the levels in your diagram would be a wide open throttle. So the AOS is not only separating oil and returning it to the sump, it is throttling the intake vacuum down to around 5 inches of water in the sump to help the low tension rings seal.
  6. Welcome to RennTech Normally, oil films on the inside of the intake system is a sign the AOS is on its way out.
  7. A lot of people and shops simply update the cars to the later setup, which is totally bolt in, or update to aftermarket bars and mounts that are adjustable for better handling.
  8. That is not going to be easy, most people use a torch to heat the aluminum section where the tapered pin inserts, then wack it out with a hammer when the aluminum is hot. Unfortunately, that often snaps off the tapered pin or destroys the bar link itself, which is the reason it is common to see 74-77 911's with no rear sway bars.
  9. That ball and socket end link is a press in item: Porsche stopped using this design in 1977 because it is such a pain to seal with and move to a more "wrench friendly" mounting system in 1978, which is a simple bolt in swap for your car.
  10. You CAN Bus system is how various systems communicate with each other. Sometimes the individual modules lose contact and need to be reset to work properly, which again requires a Porsche specific diagnostic tool. While there are are some aftermarket diagnostic tools that can "see" a fault, like yours they typically cannot communicate and reset the system. This is the unfortunate state of automotive diagnostics, the OEM's are required by law to allow some systems to be accessed by third party diagnostics tools, but many component's are "walled off" and require very specific tools to work with them, in a vain attempt to secure work for their dealer network. Law also requires the OEM to make their factory diagnostic systems available to the aftermarket; in Porsche's case, their PIWIS system is only available for lease, with the first year costing around $20,000.
  11. That is because you need to have access to a Porsche specific scan tool like the PIWIS Porsche factory tool; a "global" European scan tool won't be able to access this system, and won't see anything wrong. Some independents have this tool, all dealers have them.
  12. As that engine is a VW variant, a VW shop with the VagCom should also be able to clear it.
  13. I do not believe that the Durametric software supports this function, but you can check with them directly on that. You may need to have a dealer do a code clear with the PIWIS.
  14. Reductant Consumption is the Diesel Exhaust Fluid (DEF) that is used to assist in converting leftover exhaust particles to harmless gases. Are you sure your DEF tank isn't empty?
  15. Then using the basic rule to always go back to the last thing you worked on, the intake plenum.
  16. I would check to make sure you reconnected the coil packs, both completely plugging them in, and not having crossed any.
  17. The correct filter dimensions are 113 MM height, 65 MM outside diameter, 24 MM inside diameter. If the filter they sent you does not match these, do not use it.
  18. It sounds like something is not connected in the door you worked on, which can disable the remote. I would start with checking what you took apart.
  19. You should be running the car one or two bars below the full mark on the electronic display. I would also seriously consider replacing the AOS unit with a new factory unit, they are known for not liking liquid oil in the diaphragm area of the AOS system. I also am not aware of any atmospheric "vent" in the AOS, so check to make sure something is not connected properly.
  20. Glad it straightened out and passed. As I said above, I have seen some of the early cars go some distance before coming around, but you now officially hold the mileage record for this, so congratulations 🙃
  21. Just follow the brown wires. I would start by checking the ground terminal inside the light and see if it has continuity to ground using a multimeter.
  22. Most common problem for this is poor or non existent grounds (usually a brown wire).
  23. Some of the early cars had a real problem getting the IM Readiness test "not ready" status to change without resorting to the PIWIS, even after all the necessary repairs have been completed. I have personally seen cars go more that 200 miles of daily drive cycles before the system switched to "ready", but I have never seen or heard for one going 2,400 miles. I would have to agree with Loren on this one; something is still not right. If the O2 sensor ahead of the cats goes to a straight line zero, or near zero voltage while the SAI pump is running, the system is functional. Before repair After repair
  24. Jake's company is Flat Six Innovations, and has done all of the development work for M96/97 component's for LN Engineering , which is owned by Charles Navarro. Jake does complete engine rebuilds, from mild to wild, and only sells educational materials such as the DVD mentioned, as well as the only existing complete engine torque spec manuals in print, but Flat Six no longer sells any hardware, only complete engines. LN manufactures and sells all the hardware (Nickies cylinder liners, IMS retrofits, piston sets, etc.), and also sells Jakes torque manuals which are excellent reference sources. LN will also provide machine shop services such as installing all new Nickies cylinder liners.
