Let's see........... We go from a gear oil with the wrong API GL rating for these gearboxes (Mobil 1), to one with no API rating at all (GM/Penzoil Syncromesh)..................yeah, that makes sense...................
Wow, everybody is an expert around here. JFP do a google search on GM Syncromesh around the net. I have used it in everthing from 500hp street driven civics to RX7's with Japanese 3 Rotor right upto Supras with 800+ hp and Audi S4's with dual K04's makin around 400+whp with quattro. Guys who run major power end up with tranny issues and the GM syncromesh works wonders in all these cases. Now eventually they will need to be rebuilt however in the mean time it gave them all some extra tranny life they would have never received before. The supra especially with the Getrag tranny was grinding into 2nd pretty badly. The syncromesh all but took away 90% of the grind for another year and eventually he stripped the gear right outta the box at the drag strip, if he didn't do that who knows how much longer it would have lasted. It's a bit of an unknown trick however just because it was developed for GM doesn't mean it's bad.
I'll bet you have N rated tires on your car too eh?
Let's start with API GL ratings (you can join the API website and read all about it); the API (American Petroleum Institute) sets the testing standards for various product parameters and requirements set by the SAE (Society of Automotive Engineers, the engineers that design and test the gearbox) for use in vehicles.
Porsche (as well as many other OEM’s such as Nissan) has been using API GL-4 rated gear oils for many years. The GL-4 rating requirement stems from the use of certain alloy types in the transmission components, specifically the synchronizer and bearing assemblies. Use of a non GL-4 rated lubricant leads to premature wear or corrosion of these components, poor shifting, and potentially catastrophic component failures; which can get pretty pricey with Porsches.
Mobil 1 does not produce a GL-4 rated fluid, and in response to technical question has recommended against using their gear oils in any gearbox requiring GL-4 lubricants. GM/Pennzoil Synchromesh technical bulletins do not list any API ratings, but instead say:
“SYNCHROMESH FLUID is specifically formulated for synchromesh transmissions used by General Motors requiring General Motors Part No. 12345349 (Specification No. 9985648) Synchromesh Transmission Fluid or Chrysler transmissions requiring Part No. 4874464 (Specification MS-9224). It is also recommended for use in General Motor transmissions requiring General Motors Part No. 12345577. It is listed in the Pennzoil Lubrication Recommendation And Capacities Guide as “GLS.” PENNZOIL® SYNCHROMESH FLUID is NOT intended for all GLS applications. You must verify the manufacturer’s part number, indicated by a superscript number and found at the end of the vehicle application listing.”
Therefore, this product does not meet the API GL rating required for a Porsche. But, instead of doing individual research into what lubricants your gearbox was designed to use, please go with the "I saw it on the internet" approach, and feel free to put whatever you want into your transmission; as well, use whatever crap third world tires that floats your boat……………..
