JFP in PA
  1. I would bet that the other side sensors are on their way out, which is why I asked who did the tests. Age wise, your car is in the "zone" where the batteries in the wheel sensors start to crap out, which weakens the signal strength and the receiver stops seeing them. A sensor tester held near the wheel will still see them, but weakly, giving the false impression they are fine. If you hold the tester close, you get a signal, but if you back away slightly, it disappears (it is an RF signal). If I am correct, the sensors need to be replaced (the battery is not replaceable). This requires dismounting the tires, spending about $100 per wheel for sensors, remounting and balancing the tires. And you can thank all the morons on the road that will not take five min. to check the air pressure in their tires once a month for the fact the federal nannies had to force the OEM's to install these totally unnecessary, expensive, and annoying systems in all cars...............
  2. First of all, you have a 987, not a 986, so this is posted in the wrong forum The TPMS is two part system, senders in each wheel, and a receiver in the dash; so it has to be one of the other. Who tested the system (dealer or indy)? Reason I ask is the type of tire sensor tester matters..........
  3. The generic style code readers that AZ uses will not even see a Porsche airbag; he needs either a PIWIS or the Durametric system......
  4. Yes, I just tried it in the shop. The old style Porsche maintainer (small black box style) has a stepped lighter plug that works after the retrofit; the Porsche branded Ctek units were sold after Porsche stopped bringing in the cars with the European DIN lighter and went to the "US spec" lighter, so they will fit also. That said, I would go with a non-Porsche branded Ctek unit long before I would use the older style Porsche unit; the Ctek is a much more sophisticated system that is superior to the old style Porsche "charge-o-mat", which is probably why even Porsche stopped using it.
  5. You want number 2.......................
  6. Do a search, been covered many times................. http://www.renntech.org/forums/topic/29295-broken-turn-signal-lever/
  7. Weird. Most of the ones we see are due to very high mileage (200K+) or some type physical damage to the cat itself.
  8. "5 sets of cats"? I don't think we have replaced that many cats in total on all the cars we service combined over the years.......... What in the Hell are you doing (just out of curiosity)?
  9. All of Porsche's front radiators are vulnerable due to the mounting methods and the lowness of the nose of these cars. Just running the nose gently up on a grass hump or a parking curb is enough to break them. I know of no functional way to prevent this other than to protect the nose of the car from any impacts. I’d also forget about trying to repair the damaged radiator; we have seen a lot of attempts at this, but very few successes. Considering how much fun it is to get them out, it is better to simply lick your wounds and replace it. Your cheapest source for a new unit is probably going to be board sponsor Sunset Porsche, unless you can find someone that has one and does not need it. As for refilling the system, best method is the Uview vacuum filling system; it is the exact same system the dealer’s use, only about 1/5 the price Porsche would charge for it. With this tool, it is a 5 min. process to refill the system without any issues.
  10. Glad it worked out; most people do not realize the O2 lines on the display are supposed to move back and forth.
  11. Fuel pressure and delivery is done by connecting a pressure gauge with a side flow port to the test port on the fuel rail (looks a lot like a brass capped tire valve). If the fuel pump is bad, the pressure will not be consistent, or in the correct range. Entire process takes about 15 min. to do.
  12. Be sure test the pump pressure and delivery as well, sometimes these pumps start locking up when they age, shutting off the fuel supply intermittently.
  13. pH should be in the 9.5-10.0 range; coolant should be changed when it falls below 9.0; be cautious about how accurate test strips are, they change with age.
  14. Check your fuel pump for pressure and delivery rates, also look at the fuel pump relay.
  15. Contact Jeff at Sunset Porsche, there is a $20 retrofit kit to change the lighter over to US specs in about 10 min.; then anything you want to plug in (phone charger, GPS, etc.) will fit. If you have not purchased a maintainer yet, seriously consider the Ctek line (buy it online from a place like Amazon rather than from Porsche). Ctek make one of the best systems out there, much better than $20 Walmart stuff or Battery Tenders. Well worth the money.... "Mr. Pa"..................? Yikes, I must be showing my age! :eek:
  16. Cam timing looks fine; if you do not have any vacuum at the oil cap, start by looking at the line that supplies vacuum to the AOS and also check the dipstick and oil filler tubes (they are often disturbed when doing the IMS): you sound like you have a vacuum leak.
  17. The car is designed to use the cigarette lighter for the maintainer; there is even a notch in the bottom edge of the driver’s door to allow the cord to come out with the car locked up and the alarm on.
  18. If the cats are that bad, you should be able to see it in a scan of the engine; a lot of 996 so-called "cat rattles" have turned out to actually be coming from other sources like heat shielding. I would also move cautiously on what the manufacturer claims for their product’s CA legality.
  19. The code is definitely for bank 4-6 and ahead of the three way cat:
  20. First, a couple of questions: Why do you believe you need to replace the cats? In all the years of working on this marquee, cat replacement has to be one of the least often occurring repairs. Second, will the aftermarket cats pass your state’s rather draconian inspection requirements? Last time I checked, a visual inspection for any non factory emissions gear is part of the process, so before spending any money, I’d be sure you are not going to be doing this twice to get inspected…………
  21. I hate to be the bearer of bad news, but I for one am not a big fan of using the Allen screw method to secure the cams while changing the IMS. Besides not really positively securing the cam drives, this method can also move the gear on the rear of the shaft (which is a press fit from the factory), causing the chains to be off axis and cause no end of issues that can only be fixed by taking the engine apart. While some have success with the Allen screw method, some have also had major problems. We pull the green cam plugs and lock the cams down with fixtures while doing one of these upgrades, which eliminates any chance of problems. That said, you should have the engine scanned by the OEM PIWIS, a PST II, or the Durametric software to determine the current camshaft deviation values before moving further. These engines’ are supposed to be +/- 6 degrees; if yours does not fall into that range, the cam timing is out. Normally, we scan all engines inbound for IMS updates both before and after installation to verify everything is as it should be.
  22. P0154 is the code for signal interruption on the indicated O2 sensor. While it could be a bad sensor, more often it is a wiring issue. You can electrically test the sensor to eliminate it as a candidate before you start tracing the wiring harness looking for damage or a loose connection.
  23. Here ya go..................... http://www.hsy.com.a...ensor_gears.pdf Pelican Parts (amongst others) sells them...........
  24. Believe it or not, ATE, the brake fluid people, make a $15 tool to determine which side had the shutter wheel in it…….works every time.
