JFP in PA
  1. Before relying on such sites, just be aware that the original 1997 Boxster factory service manual was the subject of many revisions, corrections, and updates to correct erroneous information contained in the original edition, all of which were only available in the print version. You also need to recognize that these manuals are considered the intellectual property of Porsche, a point which they vigorously litigate whenever they find someone violating their property rights. As such, it is against this forum's rules to repost such materials or condone such behavior.
  2. I cannot give you a specific limit number, but I can tell you that putting in an engine with both high HP and torque, such as a Mezger turbo into a Boxster, decidedly exceeded the gearbox limits. But I also know that people like Jake Raby have built very high output engines for customers where the gearbox's survived just fine, but I have no idea what if any mods he may have made to the trans to make this work. Again, these cars are a system, changing one thing can result in needed alterations elsewhere like in the driveline.
  3. The only way to know the answer is to connect a set of A/C test gauges to the system and see what the pressure of the system is:
  4. If you do not have the correct equipment to recover the freon out of the system before replacing the unit, take it to an A/C pro that does. These systems require that the old freon be pumped out, parts replaced, vacuum pulled on the entire system to both dry it out and check for leaks, and then it be recharged with the correct amount of gas and lubricant oil; this is decidedly not a backyard mechanic project.
  5. They are simply reposting what the manufacturer claims, they don't make it or stand behind it, they just sell it. For the stuff they actually make, that is another story as they do stand behind their products. At the end of the day, it is your money and your car..............
  6. On the dyno, these things add VERY marginal improvements in performance, and then only at the extremes of the RPM envelope and in conjunction with other modifications. Most people see little if any real gains other than to make their wallets easier to sit on.......
  7. You should be checking cam deviations at idle, but with the engine fully warmed up, like after a short drive.
  8. Cam deviation values are cam timing values, where the cams are vs. where they should ideally be in relation to the crankshaft. As these engines are Vario Cam, meaning the cam timing is controlled by the DME to maximize performance, the cam timing changes with RPM. When you read cam deviation, you are looking how far off ideal:
  9. Yes, but for a different reason: Cam deviation specs for your five-chain engine are +/- 6 degrees, so you are out of spec. On your style engine, this is typically caused by severely worn chain pads between the cam shafts: The dark pad has a groove worn into it, while the light pad is a new one. This is a very common problem with the early Boxster's.
  10. As noted above: " P1531 - Trigger of actuator, no active position Possible faults: -Open circuit -Actuator defective Diagnostics: P1530 check triggering wire for short to ground, if none is found, replace actuator P1531 Check for battery power on supply wire, if ok, check triggering wire for continuity; if both ok, replace actuator Because the car has been sitting, I would look closely at the condition of the wiring harnesses....................."
  11. No, I recommend doing the diagnostics indicated to see if it really needs to be replaced; we are not fans of randomly replacing parts to see what happens.........
  12. You have alarm sensors (read switches) on each door, both trunk and engine cover, the "oddments" holder (read console), and last but not least, a motion sensor at the top of the windshield; any or all can become problematic and throw faults and should be tested. As yours is a cab, I would also be looking at the immobilizer under the driver's seat, looking for signs of it having gotten wet, a common source of multiple alarm faults. The tank servo is an independent system and also needs to be looked at for electrical faults.
  13. To begin with, you are going to need basic electrical diagnostic gear like a digital multimeter, and a copy of the car's wiring diagram so you can start tracing circuits and testing them.
  14. You have multiple electrical faults; the tank servo is not getting power, the central locking computer is not reaching the locked configuration, the interior motion sensor is faulty, and the alarm system is seeing multiple sensors not closed.
  15. P0446 is the code for a blocked EVAP system purge valve P1124 and 1126 indicates the system is so lean that the DME cannot correct for it, usually a sign of a vacuum leak in the intake system; none of these codes have anything to di with the O2 sensors..........
  16. P1530 - No triggering of the actuator, in the active position Possible faults: -Short to ground -Actuator defective P1531 - Trigger of actuator, no active position Possible faults: -Open circuit -Actuator defective Diagnostics: P1530 check triggering wire for short to ground, if none is found, replace actuator P1531 Check for battery power on supply wire, if ok, check triggering wire for continuity; if both ok, replace actuator Because the car has been sitting, I would look closely at the condition of the wiring harnesses.....................
  17. All depends, did the PPI include a full road test of the vehicle? If it only included a lift inspection, probably not.
  18. I would start looking at the drive line: wheel bearing hubs, axle shafts, etc. If the engine had a balance problem, it would shake revving it in neutral; if that isn't the case, the drive line is all that is left. 😉
  19. If codes will not clear, that means the fault still exists and needs to be repaired for the code(s) to clear. 😉
  20. Foxwell, Autel, and many others have persistently offered "Porsche" specific models, "BMW" models, "Merecedes" models. etc., with claimed "factory level" diagnostics that always seem to turn out to be "available in a future subscription update" that never seems to materialize. We have had salespeople bring their hardware into the shop for years, and we have always sent them packing because it never could do what is needed almost every day in the shop. If you want factory level diagnostic capabilities, "you gets what you pays for............." And Loren is correct, gateways are not prone to fail without a reason
  21. You have an alarm fault as witnessed by the double beep. With a Porsche specific scan tool (PIWIS or Durametric) you can read the last 10 recorded alarm faults, which would point you to exactly where to look. 😉
  22. Welcome to RennTech Year and model of the vehicle would be useful, as would the type of diagnostic tool you are reading the codes with...............
  23. Your vehicle should carry the 7DT75 model gear box, which is only used in the Panamera, and the filter listed in your invoice is for a filter for the 7DT70, which is a non-Panamera model PDK which has multiple oil circuits that the 7DT75 does not have. I do not know if that makes a difference or not, but it caught my eye.
  24. Welcome to RennTech I don't know where you took the vehicle for PDK service, but there are a few things you need to know about these transmissions: These tran's are extremely sensitive to the type of fluids being used (see my post above). To service them correctly, the shop must use a PIWIS unit to complete the service process as no other diagnostic tool can correctly access the systems internally. There is very little parts availability for these gearboxes as Porsche never intended them to be disassembled for service in the field but replaced them with rebuilt units when problems arise. Aftermarket parts are questionable at best, potentially dangerous in the worst-case scenarios. Ideally, you should take the vehicle to a Porsche dealer and have them check it out for you.
