JFP in PA
  1. The first thing I would do would be to get a can of spray electrical contact cleaner and try cleaning out the buckles thoroughly (a build up of crud inside them makes for poor electical contact), that often does the trick, and it is cheap. Just make sure everything is electrically dead first by disconnecting the battery.
  2. Some owners of the early 986's have gone through more than one set of seat belt buckles; it is a commonly known issue.
  3. Which part number in the diagram is broken? The part number you gave is for a $1,500 tank assembly...............
  4. Stant makes both a great kit, and adaptors for just about anything (we have two Stant’s in the shop). Reasonably priced, built like a tank: http://www.stant.com/repository/documents/12270.pdf Late model VW, Audi, and Porsche adaptors are all the same.
  5. Try 9243
  6. No, it should not alter fuel pressure or driving behavior, just the fuel level accuracy and what the trip computer thinks is going on.
  7. Try 5438
  8. Try 4856
  9. Fuel The fuel gauge will not read accurately, can also impact fuel usage calculations in the OBC system for that reason.
  10. Loren would you please describe what means FUEL TANK RE CALIBRATION?Thank you You will need a PIWIS tester to calibrate it.1. Disconnect the battery and cover terminal or battery.2. Remove cap over the fuel level sensor system.3. Remove fuel level sensor. (attached to the fuel pump inside the tank).4. Using a fuel extractor, completely drain the fuel tank through the fuel level sensor opening.5. Make sure that the two recesses on the left and right−hand sides of the tank are emptied completely.6. Reinstall the fuel level sensor and, with "ignition off", fill the tank with 28 liters of fuel.7. Perform tank calibration with the Porsche System PIWIS Tester:· Select vehicle type (997TT)· Select control modules· Select instrument cluster· Select menu item "Tank calibration"· Confirm calibration8. The fuel level sensor system has now been calibrated.Be very careful when doing anything with the fuel system as there is danger of fire or explosion.
  11. The Durametric system is the diagnostic backbone of my shop, and in use just about constantly. It is a very worthwhile investment, and one that also holds its resale value for those that leave the Porsche fold for whatever reasons. A lot of diagnostic tool companies spend a lot more on their marketing than they do on their products, Durametric goes the other way about and says little, but let’s their products and customers speak volumes for them. And, just in passing, we have had several customers try a multiple software systems on their Android or iPhones, with mediocre or inconsistent results at best when compared to even generic OBD II purpose built scanners. The phone may be “smart”, but sometimes just not smart enough……………
  12. We get people coming into the shop all the time with "the next great Porsche diagnostic tool that will do everything for half the price of the Durametric system"; only problem is they usually end up only being able to half what the Durametric system does, or less. As Loren noted, the Durametric is hard to beat on either performance or price.
  13. I would favor having someone like Gbox that specializes in these transmissions go through it, updating anything needed. Would also be a good time to consider a type of limited slip diff, and redo the IMS & RMS while the gear box is out if it has not been done already
  14. As I mentioned is postings # 2 & 4 above, it is my understanding that the system has to be active and connected to the PIWIS to set the correct fluid levels for the clutch, while the gearbox is a simpler overflow system like a manual gearbox. At this time, I am not aware of an aftermarket alternative to the PIWIS, such as Durametric, being able to do this step. So the indy would need to have a PIWIS. With enough of these systems on the street, I am sure someone will develop a "work around" to get it done, or that the aftermarket will develop diagnostic tools to help, but right now I know of none that will do the job.
  15. Many dealers do not even activate the ABS/PSM pumps during a standard flush unless there is a lot of air in the system or they are replacing major system components, so you should not need to either. You will need a bit over one liter of fluid.
  16. You need to be careful about two things: First, the Tip does not like the wrong type of fluid. Specs say that the car should use OEM 999-917-545-00, Esso LT 71141, or Pentosin ATF-1. Secondly, the lack of communication between the Durametric and the Tip controller is a concern. If the Tip’s controller is out, that needs to be addressed as you need to communicate with it to correctly service the Tip.
  17. Try 7139
  18. Try 4890
  19. You sometimes have to wonder if they could possibly make it any more complicated............................. :eek:
  20. Very few aftermarket exhaust systems actually add anything but noise, some to the point of distraction. Some even reduce the engine's power output, so don't put a lot of weight on performance improvement claims. Quality, fit, and installation complexity are all over the map. Do some "due diligence" before buying, talk to actual owners, and if possible actually get to hear what you are buying on a car like your own before spending a lot of money on something you may not like long term.
  21. Strange electrical issues (things not working when they should, or working when they shouldn't) are often related to a failing ignition switch. The switch is a cheap and easily replaced item.
  22. Not overly complicated; remove the plastic underbody shields, support the transmission and remove the trans mount support bolts. Remove the trans support metal brace. At this point you should be able to see the driveshaft flex disc, remove the bolts in the disc and pull the driveshaft out while putting something under the front diff to catch any oil that may drip. This procedure, by-the-by, is fully covered in the Bentley 996 service manual with photos and complete diagrams of the components.
  23. Glad to be of help...................
  24. Get rid of the gear oil and refill with the OEM product; it is a unique full synthetic gear lube produced for only for Porsche. We get cars in regularly with gearbox noise issues that are traced back to using the wrong lube.
  25. Today's tool-tip: Spend about $9 and get yourself a hose removal tool (this one is by OTC and sold by Amazon): Slide it into the hose end, and a quick slide around the fitting circumference, the hose is loose and undamaged. Works on any rubber hose held on by a clamp.
