JFP in PA
  1. Very few systems can reset the airbag MIL in these cars, the PIWIS and Durametric are the most common useful tools. Airbag codes are sometimes "ghost codes", meaning they are triggered by a false reading rather than a true event, so clearing the code and waiting to see if it comes back is an advisable step.
  2. Very nice!
  3. Recheck it once it is back in the car and the car is sitting level.
  4. It is a bit "fiddly' and time consuming, but not overly hard; DIY discussion here: http://www.renntech.org/forums/index.php/topic/30329-oil-fill-tube-q/?&p=160714&hl=%22tube%22&fromsearch=1#entry160714
  5. That is targeted more at a shop; you can actually buy single pages if that is all you need. In the end, it is legitimate, it is current, and it "comes from the source". Plus, when you think about it, back in the day when the manuals were still in print, you paid $2300 for the 986 set, plus another $1800 for the OBD II diagnostics manual; and that only covered one model car. The online subscription gets you access to anything they have for any model. Perhaps not what a DIY wrench would see as a deal, but it really is not that bad. You could always lease the PIWIS unit itself for $17+K a year, and get it that way.............. :help:
  6. Glad to hear the purchase met your expectations, the turbo cars are a blast to drive. The gas flap spring is like a cartridge inside the flap door hinge, so you need to pop off the door by releasing the tabs and slide it out. Borrow the book back for about 5 min. and you will see how it comes apart.
  7. You need to insert two thin bladed screw drivers, one on each end of the filler flap hinge to unlock the two small tabs that hold it in place. If you have access to the Bentley 996 book, there are photos and diagrams starting on page 50-2. When are you going to post some photos of that bad boy?
  8. Vacuum leaks are often a pain to locate on these cars as there are so many places, some nowhere near the engine, where they can occur. Often, a test with a smoke machine is the only real option.
  9. Not sure I have ever seen that published anywhere as there are no oversized bearings for these engines. Usually, after such a failure, the crank and carrier are replaced. Might want to drop Jake Raby an email on this one.
  10. You are correct, we like the Iridium's both because they work well, but mostly because they keep working well, which can be a major plus on something like a Turbo, where a plug change is a multi hour affair at best.
  11. Beru is the OEM brand and work very well. We have also used Denso Iridium's with excellent results as well. As for the coil packs, unless they are acting up, or show obvious signs of future problems (cracking, etc.), I'd leave them alone. Then are not cheap, and are easy enough to replace when actually needed. Same applies to the MAF, which is probably second only to O2 sensors for being replaced for no reason. Contrary to a lot of published information, we like to use a very small dab of anti seize on the plug threads, as well as a small amount of dielectric grease on the coil plug boots. Porsche has had problems with some types of anti seize compounds causing an increase in electrical resistance between the plug and cylinder head, but as most anti seize compounds available now are based upon a fine metal paste and excellent electrical conductors, that is no longer an issue.
  12. Welcome to RennTech! :welcome: Most people do not realize that power steering fluid ages and gets pretty dirty over time. While a full flush every couple years is always a good maintenance practice, disconnecting the lines to do a full flush is both a bit messy and beyond what many want to get involved in. A company called Cardone, who makes replacement power steering hardware, came out with an inline filter that goes on the low pressure return line and can be popped apart by removing a simple clip to drain the system quickly and cleanly, This unit also has a magnet and stainless steel cleanable filter element to trap the crap that collects in the system.: Another, and more simpler option is to suck as much old fluid out of the system reservoir once a year using a syringe device and refill it with fresh fluid. While not perfect, it is both quick and effective in keeping the system in good shape in the cold. Be sure to use only the spec fluid as contrary to popular misconception, they are not all the same.
  13. Welcome to RennTech! :welcome: Like most OEM’s, Porsche no longer prints any service manuals, but only makes them available online via subscription. You need to also be aware that Porsche has a reputation for severely protecting what they see as their intellectual property, so be very careful buying pirated versions. Porsche does have an online subscription service that gives you access to their official service system database that is called Porsche PIWIS TSI (http://www.renntech.org/forums/links/goto/18-porsche-piwis-tsi/). They have multiple subscription types (by the page, time based, etc.) which would give you full access to anything you may need now. or in the future. One of its biggest advantages is that they keep it updated, so you get the latest data. Bentley also has a service manual for the VW Touareg, which is a very similar vehicle, but not an exact match.
  14. Try 5352
  15. Someone once wrote that the definition of character is doing the right thing, even when no one is looking................ :oops:
  16. I think that needs a couple pretty pictures...................... :eek:
  17. No, not necessarily. In this case, there is something unusual as neither a PIWIS or Durametric system see any faults or codes, so there are none to "reset". Unhooking the battery does remove any chance of collecting any data stored in the system; and, in any case, you have never been able to reset an airbag MIL by disconnecting the battery on one of these cars.
  18. Not sure what that will accomplish as disconnecting the battery has never been able to clear air bag MIL's in these cars.............. I have to agree with Loren on this one, it does not make sense; you should not be able to trip the air bag MIL without some event that a good scanner would see. But I would also do an electrical systems test (battery load test, alternator output, etc.) as strange voltage excursions can trigger MIL's that are not real.
  19. The issues may be related, start by looking at the brake fluid and see if it is low; if it is, fill to the correct level. If the fluid is not low, you may have a problem related to getting wet when you washed it, such as a loose or cracked harness connector. Another option would be to scan the car with either a PIWIS unit or the Durametric software to see what codes are involved.
  20. Ahsai is correct, there already is a magnet mounted in the case, but adding another one would not hurt anything.
  21. Sometimes, persistence pays dividends. Glad you got it out.Can you provide where you saw the plug in question? I am having difficulty locating it.
  22. You can try tapping on the plug, just don't get over ambitious in the process. The plug should have been torqued to 22 ft. lb., so it may just be some corrosion. You might also want to try one of those new "freeze and release" penetration oil systems on the market.
  23. A word to the wise on transmission service and drain plugs: Never remove the drain plug until you get the fill plug out; if you take out the drain plug first, and then cannot get the fill plug out, you are officially in very deep yogurt because you cannot refill the gearbox. Get the fill plug out first.
  24. The first thing to do is have the system pressure tested (including the coolant cap); takes about 30 min., but would confirm the presence of a leak or not. If it fails the pressure test, you need to go to the next step. As the leak can be very small, yet still smell quite strongly, I would suggest getting a bottle of UV coolant dye and adding it to the vehicle. Run the vehicle normally for a couple days, then using a "black light" UV source, start inspecting the entire system looking for the tell-tale evidence of a leak (there may be more than one), which will be very pronounced visually due to the dye.
  25. All Porsche factory service manuals are copyrighted, and Porsche has a history of zealously defending their intellectual property.
