JFP in PA
  1. #7 is a M14X160 bolt, spec is 118 ft. lb. Thanks JFP. I think you and I are looking at different fiches for some reason. Here is what I am looking at from Porsche's website and shows #7 as a M14x1.5x110. I was using the diagram in the Bentley manual; the PET should be more correct, although the bolt may also have been superseded, so I would stay with the PET. The torque spec (from the OEM service manual) is correct at 118 ft. lb.
  2. #7 is a M14X160 bolt, spec is 118 ft. lb.
  3. I would also suggest a front end alignment done by a competent Porsche shop. Considering what started all this, I would also get under the car with a torque wrench and check every non castellated nut for the correct torque specs.
  4. I think that if you have an active or pending code, you are toast; but you may want to check the California DMV web site for details on where the lines are on this subject.
  5. You should not be using anything but a full synthetic oil in the car. Full synthetics are a different animal than conventional oils; they have lower surface tension, better heat transfer, and much superior film strengths than conventional analogs. They also utilize totally different additive packages and have much longer running lives before they fall out of grade. Using a non synthetic is false economy, you will pay for it in the long run. As for what brands and weight, that is always a topic of conversation, but there is a published list of Porsche approved oils in the document archives.
  6. Without the radiators or heater core, the forward cooling system looks like this:
  7. Thanks. Item # 4 does not look like the part. I think the bolt I am looking for is # 11. But I will print this out and take it to the car this morning and confirm. FYI, I found these on Porsche.com also. http://www.porsche.com/all/media/pdf/originalparts/usa/996_USA_KATALOG.pdf That is an online copy of the PET, which is their parts catalog.
  8. We have seen more than our share of OEM IMS bearings, none of them had any signs of grease left in them, only oil, even though the seals often looked intact. And quite often, the oil was in pretty bad shape.
  9. Part # 90037832901 would be item #4 in the diagram. Go to http://www.autoatlanta.com/ website, look up your model and you will find that diagram under the steering/front end section with the part numbers for each item. You can also find the same info if you have access to a Porsche PET. Good luck!
  10. I thought it might be easy to spot. See if this helps ID the part you are looking for:
  11. You need to start looking at the entire front suspension and steering, giving things a good shake as you go. If something fell off, and now the steering wheel is shaking, I cannot imagine looking at the car and not seeing anything wrong........
  12. I agree 100%, get the car up in the air, pull the front wheels and start looking. I also would not be driving the car until it is inspected.
  13. Glad you got it worked out. Your comments point to a common misconception about the battery and charging system in modern cars; despite what many say, they do age and lose significant output over time, particularly the battery. This why the bench mark tests for batteries and alternators is how they perform under load. To that end, the standard testing procedure to check out either unit is by using what is called (not surprisingly) a load tester, which puts a heavy drain on each one separately to see how they respond. While the test only takes a few min. to run, it is a fail safe "go/no go" way to determine if it is time for a new battery or alternator. Most competent shops have the equipment to do this, and many serious "DIY" own them as well as they work on anything with a battery and/or a charging system. A decent hand held digital 130 Amp unit sells for around $80-100 over here.
  14. It is not critical, but it does make things easier as you don't lose everything from the radio presets, window auto up/down stops, to the DME's learned settings. On some models, you would even lose the gas tank calibration settings, so you would have to empty the tank, refill it with a known amount of fuel and then reprogram the gas gauge so it was correct, which can be a major pain in the butt not to mention very time consuming. Do you have to retain power: No; but it is easier if you do.
  15. Which is why I suggested using one of the several makes that has the feature, like the Ctek 7002. In a pinch, there is a $10 "dongle" with a cig lighter end on one side and the two snaps for a 9 V battery on the other that works as well.
  16. It cannot be connected to the battery posts as the charge would stay with the battery, not the car; it either has to be connected via the cigarette lighter plug (preferred method), or on the cable ends.
  17. Several maintainers, and particularly those from Ctek, have a specific setting to do this. but while conducting the swap, you need to remember that the cable leads are still hot when disconnected and do not short or ground them.
  18. On the 997/987 cars, Porsche changed the design of the relay banks, apparently for space reasons. The one in the rear boot on a 987/Cayman now flips somewhat and slides out on arms unlike the early ones that are bolted to the firewall under the trunk carpeting on a 986, and the one up under the dash appears to be a similar design, although I have never tried to move it as it is in a very confined space so something has to move out of the way to make room for it (when you look up under the dash, you are looking at the bottom cover of the relay bank, so you need a small telescoping mirror to extend above it to see what you need to do). While it may represent progress, it is a bit peculiar. In any case, relay changes are not a daily occurrence, and remain possible if a bit arduous.
  19. Not without going to some lengths; you would need to pull the headlight assembly, remove the bulbs and then try to get it out, and in the end it would not make much (if any) difference in how the light performs.
  20. I would try to do it without pulling the gear box, that is a lot of work for one fastener, unless the car is going to see severe duty (e. g.: lots of track time), I would not be overly concerned about it not being there. What I would do, however, is find another shop; people that leave fasteners out when putting these cars back together get up my nose and should not be allowed near them. I would also double check that all the other bolts are torqued properly.
  21. Being double jointed definitely helps; we have never tried to pull one down, preferring to work upside down with my head under the dash using a small mirror and light. Not comfortable, but it is quick. The front relay panel may be mounted on a similar set of arms that the rear one is.
  22. This photo of the engine with the transmission removed shows location and type of the fasteners that attach the transmission. The location and orientation of the hardware can be very confusing and it's not well documented in the Porsche factory diagrams, so I've provided a legend with part numbers for all Boxsters 1997-08 here: A- M10x40mm triplesquare (999-073-118-09) B- M12x1.5x100mm (999-072-010-09) C- M12x1.5x100mm (999-072-010-09) with 15x28x3.5 washer (N-905-028-02) D/G- M12x1.5x70mm (999-072-008-09) E/F- M12x1.5x90mm (999-072-009-09) H- M10 hex nut (900-377-011-09) attached to M10x30mm stud in transmission case (999-218-088-09)
  23. Sorry, I gave some incorrect info, it is not in the front of the trunk, but on the drivers side (behind a removable panel) on your car. :huh: 1. Open luggage−compartment lid, turn the two fixing clips at the side by 90° and fold down the luggage compartment cover.2. Pull relay carrier forward on the two supports.
  24. Facing into the trunk from the rear of the car, pull down the inside trim liner at the front of the trunk area.
  25. Not to rain on your parade, but you are looking at relay panel #1, and the DME relay is not in that panel, it is in panel #2 in the rear boot. :eek:
