JFP in PA
  1. Like all OEM's, Porsche has selected several faults that can trigger "limp mode", most of which related to either what they consider safety issue or severe emission related problems that could result in damage to the vehicle.
  2. My analytical comments were directed at the use of a Blackstone type oil analysis to determine if two lubricants were the same. In the case of both RP and Redline, they have both made statements in the past concerning what specs their products meet, which were later found to not be correct, and had to be retracted. This type of spurious "spec" behavior is unfortunately too common with smaller lubricant blenders. On that basis, I'm suggesting caution. Without fully supporting evidence to the contrary, the "best" lubricants are often what the OEM specs for the application.
  3. Total supposition based upon some coincidental matching chemical compounds. To use laboratory analytical techniques to match lubricants, you would need match physical properties (e.g.: coefficient of friction, foam development, lubricity, heat transfer properties, etc.) as well as a full chemical match (mass spec, etc.). Just because two different products both contain boron does not mean they are even remotely the same thing. You would be risking a very expensive trans in the quest for saving a couple of bucks......
  4. The outers are much more susceptible to wear because of the amount of movement they see, plus they are directly in the line of fire for road debris. The inners lead a sheltered existence by comparison. I would not replace the inners unless they show signs of needing replacement.
  5. Did you check the small fuse that is actually in the alarm module?
  6. That quote is more than a little out of line. Getting water under that seat is common, and many times the alarm module located there can be saved by simply drying it out (do search, this has been covered several times). Second, usually it is not necessary to replace the keys if you did have to change the module out, and $1300 for two keys is akin to highway robbery. I'd first try to do a DIY save on the alarm module before spending any money, you could just luck out and get away with just the loss of your time.
  7. First of all, DO NOT use a metal impeller pump in these cars. The composite impeller is there for a reason; when these pumps begin to wear, and they all do, the shaft is going to wobble a bit. When that happens with a metal impeller pump, the impeller starts machining away the back of the pump cavity, which happens to be the alloy engine cases. You can quickly do irreparable damage to the cases. Even engines that only suffered slight metal impeller damage were observed to have reduced coolant flow due to the now larger gap between a new pump's impeller and the damaged cases. Do not use metal. A good idea for your flush is to get some appropriate sized large rubber stoppers and slip on hose fittings that you can use to jury-rig a more water tight seal for the hose in the openings while back flushing. Makes the process quicker and a lot less messy.
  8. Welcome to the wonderful world of composite water pump impellers............. If you forced water into the hose where it connects to the thermostat housing, you would be flowing water backwards into the radiators. If you removed the thermostat housing (to prevent the stat from blocking flow) and then pushed water into where the other hose connects to the engine, the water would be flowing backwards through the engine.
  9. The heavy amperage draw item on the circuit is the compressor clutch drive assembly, try disconnecting that and then turn the system on (the AC won't run, but everything except the clutch will be on) and see if the fuse still blows. If it doesn't you need to have the compressor clutch drive looked at.
  10. The diagrams are correct, the line that goes into the thermostat housing (orange in the photo) is the return coming back from the radiator's to the engine, and Pelican has been wrong before.
  11. You do not have to tear down the entire engine, but you do need to remove the cam shafts from the cylinder heads, and it does require some special tooling. I've never heard of a worn tensioner or paddle wear pad causing any type of failure, but the engine's do begin to run poorly and will start to throw codes related to the cam timing.
  12. Here's what I take under the car: But then I don' t like to not have anything I might need.................. :D
  13. There is a specific thread on this forum about lost radio codes and how to retrieve them, suggest you repost there.....................
  14. The cam deviation is due to slackness on one or more timing chains, which is also where the noise comes from. Sometimes it is just the hydraulic tensioners causing the issue, but more often on the five chains it is the small shoes between the cams.
  15. Judging by the extreme cam deviation values, and the year of the car, you have a five chain motor that is suffering from wear on the cam tensioning pads located between the two cams on either one or both heads. In your case, bank one seems to be the worst offender. This is a common problem on the five chain cars and can be fixed by replacing the worn parts: There was just a similar thread about this problem: http://www.renntech.org/forums/topic/46101-camshaft-position-1-deviation-of-897/?hl=%2Bworn+%2Btensioner+%2Bpads#entry252738
  16. I agree 100% that I don't want to mess with the high pressure side of system. that is why I was looking to test it at the rubber hose where fuel line comes in to engine bay rather then at the fuel rails. Agree that car in that video is not DFI, my point of reference in that video was that at the hose he tests it would be low pressure regardless of if car is DFI or not. I picked that point because that hose is what feeds the high pressure pump and appears to be the only connection in the engine bay that would be low pressure. Problem is I cant seem to find any reference to what size that fitting is or where I can buy a fitting that would properly allow me to test pressure and flow. It should be a 12MM fitting if memory serves (I'm away from the shop at the moment), Actron has an adaptor that works with their fuel pressure test system for the low side only, "holding pressure" should be in the 60-70 PSIG range. Porsche never published the fitting size, just the part number for a ridiculously over priced tool that it came on. We found one that worked by trying everyone we had in the tool box. You should also be aware that many of the fuel problems on the DFI cars are on the high pressure side, not the low pressure side, unless one of the transfer pumps has gone bad.
  17. The video you are looking at is not for a DFI car, yours is a DFI car. The car in the video is running at less than 60PSIG fuel pressure at the injectors, yours is at over 1,700PSIG. If you do not know what you are doing, or if you mess with this high pressure system using the wrong tools, you could seriously injure your self, or worse. If you were to find an adaptor and connect the gauge in the video to the high pressure side of your car, your fuel system would blow it apart. If you do not have the correct equipment or experience, I'd suggest taking it to someone that does
  18. You didn't say what model or year, but assuming an early Boxster it is in the rear boot next to the main DME unit, mounted on the boot's forward bulkhead.
  19. You will not be able to rotate the engine fast enough to get the VarioCam system to kick in (no oil pressure).
  20. All the more reason to track down one of the LN Engineering part number 106-05 first version tools.
  21. We have not seen this problem to date, so it may be recent production. We have also retained a couple of the first style unit's "installation tool" (LN Engineering part number 106-05) that was a separate piece used to install the first style that used solid metal pins that slipped into the oil holes in the filter unit and had a machined head that the socket slipped over. These things were very well made (all steel) and probably cost LN a bit, which is why the discontinued them and went to the hex on the filter adaptor itself. These installation tools still fit the current version spin on adapters, and we tend to use them to install the spin on adapter rather than put a steel tool on the alloy hex. You might want to check fleabay to see if any of these tools are still about, a lot of them were disposed of once the spin on adaptor was installed. And additional thought would be to ask Charles if he has any of the old tools kicking around (the original style adaptor cannot be installed without one).
  22. Hard to say without more data. I'd get the battery load tested, and also have the alternator output voltage tested.
  23. Depends upon where your head is at. Auto Enginuity is an OK diagnostic system, but pricey and not as completely capable as the Durametric system. The basic AE tool will set you back about $250, and then you need to add the "enhancement" for another $230. The basic, or "enthusiast" version of the Durametric system is $287 all in, and is considered by many to be the most capable Porsche diagnostic tool other than Durametric Pro version ($753), or the factory the PIWIS ($~17K first year lease). And while AE was charging for future updates in the past, but now are offering them for free, all Durametric updates have always been free.
  24. Replacement wheel speed and brake pad sensors will have the correct connectors on them, but if you have also lost the harness side connectors, you have a bit of a problem. Porsche does not break up the main wiring harness into too many replaceable sections, and the ones they do sell are anything but cheap or easy to replace. You may be better off getting new sensors and then either trying the scrap yards for a useable section, or going to a VW dealer and seeing if they can match the sensor connectors for you (a lot of the connectors are VW sourced on these cars). And when you splice into the main harness, use shrink wraps to seal the splice against the weather.
  25. Try disconnecting the cable from the throttle body and see if the car does the same thing when you manually operate the throttle; if it does, it is not the cable.
