JFP in PA
  1. Ahsai is right, don't go over pressuring these systems. If you suspect your have a leak up front, an excellent alternative is to add some Uview UV dye to the cooling system a few days before pulling the bumper, then when you do a black light will quickly show you where the leaks are: We use this stuff to find small or hard to locate leaks in the cooling system, and the dye will not bother anything.
  2. Temps are still a bit low. Normally, if you clear codes, the SAI takes a while to reset to "ready" status, so what you are seeing is unusual.
  3. I'd would run a leak down test on the cylinders in question; anything beyond 10% is problematic.
  4. Something is not right, once the engine is warmed up to a steady state, the oil should always be hotter than the coolant, which is why the car has an oil to coolant cooler system.
  5. Welcome to RennTech! :welcome: The hose in the right-hand photo above is the vent for the battery. The missing part at the base of the headlight is for the headlight washer assembly (pops up when activated).
  6. Be glad they had one. The Autologic unit is one of the most capable aftermarket systems for European brands; unfortunately, it is also one of the most expensive as well. The base unit is north of $10K, fully loaded with all the modules to do Porsche's brings it in at over $60K, not including very stiff annual update contracts, which is why they are few and far between, enough so to be considered nearly non existent. They are also very weak on coverage for Asian brands, which are dominant in the aftermarket repair business. For that amount of money, you can lease a true PIWIS for several years. Dealerships (and shops) charge by time increment's; some dealers use 30 min. slices, others full hours only. Most shops work on 15 min. time intervals to keep prices down.
  7. This is a clear picture of what the terminal area of the starter looks like: The wire with the "hook" is the solenoid trigger wire.
  8. I'm afraid you are going to find that most of the back of the car is only available as one harness section. Unless you want to keep the car totally factory, you will need to cut, splice, and heat shrink wrap replacements for the burned sections.
  9. Porsche only made very large sections the main harness system as one piece, and those large sections tend to be very expensive as well as time consuming to replace. What problem(s) are you trying to solve by replacing it?
  10. Sorry, but I cannot see or tell anything from that photo................
  11. If you are not able to do it, that would be your next step.
  12. I would start with both a voltage drop and continuity (checking for shorts to ground) on each of the circuits (backup lights, top control module on cabriolets, seat and mirror memory control module, and outside mirrors) on that fuse. I would also consider individually testing each circuit for current draw. I would also immediately stop using any fuse rated higher than 7.5 amps until the problem is resolved; running higher rated fuses increases the chance of damaging the system further.
  13. I always get a chuckle out of people trying to save time by defeating the purpose of a tool. You might be surprised at how many cars we see flat bedded into the shop because someone tried to "save the time required to clean out" their Motive pressure tank. If you miss on keeping the fluid level up in the reservoir, which alone has to be more effort and time than cleaning the tank on the Motive unit, you are going to introduce air into your ABS/PSM control system, which requires the use of a PST II/PIWIS/Durametric system to get it out. While we do make a lot of money off other's mistakes, I still suggest you use the tool as it was designed. We have multiple Motive units in the shop; it takes about 5 min. to fully clean one after using it. The flat bed and shop time to fix it if you guess wrong cost a bit more. As I have never done what you are describing, I have no basis to answer your question about if pumping the pedal will empty the reservoir, but based upon the size of the system reservoir and the volume of fluid the clutch master pushes out per pump, I would guess that it would not empty it completely.
  14. This is correct following the wait and slowly releasing the pedal. Loren, I think I am having the same issues as Andy. These steps don't make sense to me . . . specifically pumping the clutch pedal when the bleeder valve on the clutch slave cylinder is OPEN. How do you NOT introduce air into the system on the return stroke of the clutch pedal? If you are using a power fill, the system is under pressure. So what is the point of pumping the pedal? Won't all the old fluid exit the system (assuming the clutch is fully depressed and held) just by the pressure of the power fill? Thank you. Sean Pumping the pedal while the system is under pressure and the bleeder is open moves the internals of the clutch master cylinder back and forth to clean out any residual fluid in the master while the pressure system keeps clean fluid flowing through. It is in the bleeding instructions found in the OEM service manuals for these cars.
  15. Could simply be a bad idler; it happens, we have seen bad ones right out of the box.
  16. It does sound like a single cylinder dead miss (often a coil pack), only problem is without the codes you don't know which cylinder and the coil packs are not cheap. Is there an auto parts store nearby (Autozone, etc.) that loans or rents diagnostic tools? Just about any OBD II scanner can pick up cylinder misfire codes............
  17. The problem is a simple one, you need a key that the car's security system recognizes, which means using a PST II or PIWIS to accomplish. The key is going to set you back over $100 alone, cutting it and coding the car to accept it is all labor. Right, I understand this. Knowing this helps me how? More specifically, where can I get a key other than dealership? And what details should I look for in securing a key? Who can cut and program it besides a dealer? Indies? Thanks Simple: Several places (including online houses like Pelican or Suncoast) sell the key blanks and heads, but very few lock smiths have the correct equipment to cut a Porsche key (they use a unique system), and I also doubt any Indie would have that equipment either, so you are pretty much stuck with the dealer network. Anyone with either a PST II or PIWIS can do the coding once you have the key. While PST II's are common with serious Indie shops, very few would have a PIWIS system; expect to be billed for about an hour of shop time for the coding at the local prevailing labor rate. If you shop around, you can probably get everything for between $200 - 300 all in.
  18. The voltage output could be low if there is high resistance in the larger cables. Thank you JFP Would you tell me please if i have access to this bigger cables and where they are? Thankx I talking about the large cables that run from the battery to the starter and the alternator. They can be tested in place by measuring the voltage drop across the various sections; you should not see more than 0.5V drop, if you do, the internal resistance is too high and that cable section needs to be replaced. This is a very common problem in the 996 cars.
  19. The voltage output could be low if there is high resistance in the larger cables.
  20. The problem is a simple one, you need a key that the car's security system recognizes, which means using a PST II or PIWIS to accomplish. The key is going to set you back over $100 alone, cutting it and coding the car to accept it is all labor.
  21. Running it without an exhaust system, but with the headers in place, will not harm anything other than your hearing. To get oil pressure, pull the fuel pump relay and crank the engine until oil pressure comes up on the dash. Plug the relay back in and you are good to go.
  22. Early Boxsters (through year 2000) had a problem with flexible lines on the fuel pump assembly moving and blocking the lower one way flapper valve at the base of the filler neck (Loren's TSB). When this happens, you get exactly what you are describing (won't fill, no codes). The fix is to drain down the tank, pull the fuel pump and tie back the lines to keep them away from the lower flapper. Time consuming, but not an expensive fix. One of the reasons I think that this is your issue is the lack of codes; if your carbon canister (EVAP) was truly plugged, you would be throwing multiple codes. The EVAP system is also not passive, it involves multiple sensors and controls:
  23. Year and model of the car, as well as any codes thrown?
  24. If you want to do something positive for the cooling system, install a 160F stat.
  25. Problem is that there are multiple items on that circuit, and one of them is overloading the fuse. To resolve that, you need to test each device on the fuse circuit individually to isolate the problem(s).
