JFP in PA
  1. Here is the dash plaque from a real Black Edition: Door sills: And the cars were all black, even the wheels and exhaust tips.
  2. I'm not sure what you have here, the only "Black Edition" Boxsters I have seen were all 987's, and they were definitely all black. They also had numbered dash plaques which told you what number they were in the edition sequence.
  3. The Bentley manual is only available in hard copy.
  4. You should be able to find the diagram you are looking for in the Bentley Boxster manual.
  5. A bad battery causes all kinds of weird electrical issues to pop up. JFP, Once I replace the battery, is it likely all will return to normal? I hope to get one today, put the car on the charger through the cig lighter, pop the trunk and hope all well after replacement - probable? A new battery usually clears up these types of issues as they are caused by low voltage.
  6. Please do not "bump" posts.
  7. Do not jack the car up on stands, let it sit on the ground. Clean the car inside and out, apply a good coat of wax. Air up the tires, change the oil and filter, add Stabil to the fuel tank, fill the tank, run for about 15 min. before parking. Use a quality battery maintainer. When you come back in six months, it will fire right up and be ready to go.
  8. A bad battery causes all kinds of weird electrical issues to pop up.
  9. The thermostat should not make any sound.
  10. Sounds like you lost your serpentine drive belt on the engine. Should be easy enough to confirm via a quick visual inspection. In the mean time, I would not be running or driving the car.
  11. You have to remember the basis of the DIY psyche: "If one is good, and two is better, then forty seven has got to be just right!" I'm surprised that you don't see more cases of people marinating their plugs in it over night before installing them.........
  12. I thought Porsche issued a tech bulletin advising not to use anti seize on "modern" plugs. IIUC modern heavy nickel-plating on the plugs prevents seizing in the aluminum threads as well as the old anti seize compound, while ensuring a great ground for the spark. Porsche did come out with some information concerning the use of anti seize, which specifically addressed compounds that may not be electrically conductive. Most anti seize compounds you will find are metal paste based, and are both thermally and electrically conductive. As we regularly see cars that the plugs have been in for 10 or even 12 years, a little anti seize is a good insurance policy against them pulling the treads out of the head next time out. And to put another perennial "old wives" tale' to bed, anti seize does not cause plugs to loosen and fall out, but improper installation does. Use a torque wrench.
  13. Beru was the factory plug. Changing the plug is pretty straight forward; we like to use both anti seize on the threads and a dab of dielectric grease on the plug insulator. Be sure to torque to specs, and inspect the plug tubes for any oil leakage while you are in there.
  14. Remove the air filter housing if it is in the way.
  15. No, TPMS did not become a federally mandated system until 2007 model year, but it could have been an option on a 2006. You can also purchase aftermarket sensors for less than half the price of Porsche units, and they are fully compatible.
  16. Try pressure testing the system at the tank, we occasionally find tanks with small cracks that lead to condensation in the trunk area. If the system is closed and tight, there should be no condensation.
  17. Supposedly possible on '03's and some '04's, but apparently does not work on later models due to software changes. I've never tired it.
  18. The AOS is more than just an "emissions device", it provides a consistent low vacuum level (around 5 inches of water) inside the crankcase that serves multiple functions. First, and perhaps most importantly, it relieves any blow-by pressure build up which can keep low tension piston rings from sealing properly, which will cause loss of power and oil consumption. In addition, the vacuum in the sump lowers the boiling point for any water or fuel accumulated there, allowing it to be converted to vapor and pulled into the intake system to be burned off before it can build up to levels that cause problems. These engines also use silicone type sealants on flat machined surfaces on the sump cover and cam covers, as well as very low tension rear main seals, particularly the newer style PTFE seal, which can start leaking if there is any pressure build up over time. You can also blow out the cam plugs on the cam covers as well (they are just a friction fit plug). How quickly and to what level these problems will happen is dependent upon the miles on the engine, ambient weather conditions, and how the car is being used. Just leaving the vacuum source line disconnected can help relieve some of the pressure build up, but not in all cases, plus it does nothing to address the ring seal problem and is particularly bad when it comes to build up of water and fuel in the oils.
  19. Not necessarily a great idea; these are low tension piston ring engines, and killing all the vacuum to the crankcase can lead to other issues, such as burning oil and blowing out oil seals and gaskets.
  20. Not really, you have to look at it, often with small mirror stuck down inside the canister. [flame_on] Ok, well being an engineer, I just have to ask....."And what problem were they trying to 'fix' that the full flow spin on filters didn't have?" This sort of engineering drives me nuts.....and on a 55K car no less.... [/flame_on] grrrrrrr Some like to say that the cartridge style filter is more recyclable than the spin on, but that is not really true because the spin on units can also be recycled as well, you are just recovering two streams (media and metal case) rather than one with the cartridge type. I think the bigger issue here is that these engine's are very debris sensitive, and the spin on offers both finer media and full flow protection. A secondary advantage of the spin on is that it can also easily run a FilterMag unit, which turns the entire metal housing into a magnet to trap ferrous debris, including the stuff so small that it would normally pass through the filter itself.
  21. Not really, you have to look at it, often with small mirror stuck down inside the canister.
  22. Thanks JFP, out in the desert rancho mirage 85-112 daily Then definitely go to a 10W-40, like Castrol Edge with Syntec Technology; I'll bet you see a change in your oil pressure right away.
  23. Not the type used by the LN adaptor (Wix/NAPA Gold), they are "full flow", which means no internal bypass valve is in the filter, so you get 100% filtration at all times.
  24. I would keep it off the road until it is fixed. When the AOS fails catastrophically , they can suck in enough oil to hydro lock the engine and destroy it. Not worth the risk.............
  25. Ohhh, I didn't know that...Is this something that happens 'often'? Should this be a maintenance item? My boxster has 30K miles on it... In a word, yes. Worst part about it is that you don't know it is happening until you take the filter off and look at the valve (in is in the bottom of the plastic housing) and see it is stuck open. Most people don't do this, as they don't even know it is there, or for how long it has been allowing unfiltered oil to circulate. The valve itself is a plastic device with a spring to operate it, and it sits in the very bottom of the OEM plastic housing. When the valve sticks, you typically end up buy a new housing, which ain't cheap either, only to have the new one eventually do the same thing. We became aware of the problem because we do a fair number of oil changes and always clean out and check the plastic housing for cracks, etc.
