JFP in PA
  1. Hi Loren. Are you able to look at my picture I've attached in this thread? I would appreciate if you are able to tell you which number combinations to match. I have managed to find a couple of boxes on ebay but are unsure which numbers must conform? Have found a box where all the numbers shown true except that which stands between the "stars" With respect / Alex, Sweden The new box must have all the same exact same part numbers as your original unit.
  2. Welcome to RennTech :welcome:
  3. The special adaptor is only needed if your engine stand head does not adjust enough to accommodate the smaller shape of the M96 bell housing. Many engine stands will work just fine.
  4. Lowering the engine makes the AOS much more accessible.
  5. Some oil consumption is not uncommon on the M96, but yours sounds excessive. First thing to check is the AOS, try removing the oil fill cap while the car idles; if it is very hard to remove, you are sucking oil in through a bad AOS, which you can change out. The M96 is also known for wearing the cylinder walls on the thrust side of the pistons; if yours has gone that way, a total rebuild is the only cure. You can usually detect cylinder scoring with a simple compression test, or by using a bore scope.
  6. First, welcome to RennTech :welcome: Some of the earlier PDK cars suffered what has to be described as "teething pains" that were corrected (as much as possible) with some software updates. Have your dealer check to be sure you have the latest software.
  7. You want an OEM cap whose part number ends in -04 or higher.
  8. There are several type and sizes of pin extraction tools: Amazon, amongst others, sells several of them
  9. All coolant system combustion gas tests require a running engine to get accurate results. The Lisle tester works fine, but it can be fooled by coolant getting into the tester which can lead to strange results. If you use the Lisle tester, follow the directions very carefully and watch to see if the test fluid level increases, which would be a sign that liquid coolant has gotten into it.
  10. Other than the ground fault Loren mentioned, I am also not aware of any "catastrophic failure" issues with these cars.
  11. 10% is pretty much the limit on leak down tests, so your one cylinder is highly suspect. A combustion leak tester is a good idea, I prefer the two stage Uview unit, which tends to be more accurate than single stage devices, but also costs more.
  12. A good start to getting into this is to have the car scanned with a Porsche specific scan tool (Durametric, PIWIS, PST II) and write down all of the codes, then let us know what you have found.
  13. P1551 is a signal interruption in the IAC; most common causes are wiring breaks, bad IAC, or a problem with the DME.
  14. Please do not quote your previous posts to try and "bump" it, that is against forum rules.
  15. That's the bit that concerns me. Is it like my 911 where it's basically 2 bolts and support the engine on a jack? Any opinions on the Numeric cables and SSK. I promised myself I was going to leave this car stock, but if I have to get in there and replace stuff, I might as well go for a mild upgrade :) Yes on the front engine mount. The after market (Numeric & SSK) cables have a lot more metal in them than the OEM does, which tends to make them much more durable and somewhat improves the shifter feel, but that move away from plastics decreases sound isolation a bit and some have complained that while the shift feels better, they are getting noise transmitted into the cabin; so they can have some trade offs.
  16. Well, like I said, it's not difficult, but it takes time; lots of time.
  17. The cables set is a bit over $400 alone, and I believe it is about 4-5 hours to change them out (it is not hard, but you need to pull the car's interior apart to get at the inside bits, lower the front of the engine, and then route the cables through the rear bulkhead to the gear box as they are one piece). The job is more aggravation and time consuming than hard.
  18. and this, Ladies and Gentlemen is why I'm not an auto technician :) Diagnosis is the thrust bearing. They also mentioned my shifter cables are very worn. Was quoted $1200 parts+labor for replacement. That seems awful high. Is it hard, or just time consuming? I'm off to go look for a good writeup... To do the thrust bearing, they have to pull the gear box out. If it were in my shop, I would recommend renewing the clutch while in there, and removing the rear seal on your non serviceable IMS bearing. $1200 is not that bad a price to replace the throw out bearing.
  19. Based upon the excessive deviation on the bank 2 cam, I would say that the P0021 code is real. What concerns me is the value as your engine would not run with a cam deviation of 90 degrees.
  20. Supposedly, on the 997, you unplug one of the two wires (I do not know which) and then you still have to fabricate a new on/off circuit to control the exhaust.
  21. OK, let's start with the easy stuff: All these cars came prepped for cruise control, on board computer, etc., but they were only completed and activated on cars ordered with the option. With the Durametric system, these options can be activated (some require the Pro version), but would still require any sensors, switches, wiring, etc. to be installed to make the system function. To find out what is available on your specific model, you need to go through the Durametric system and examine each section's "coding" subheading. As for the blinking side lights, on your model, you may be limited to either having them as turn indicators or side markers, but not both, by just coding without some rewiring. Some models offer the flexibility to work as indicators and side markers at the same time. It is very easy to override the PSE speed control, just unplug the vacuum lines on the PSE, the default position is "open" (read loud). If you want to be able to close and open it on command at any speed, this DIY was posted here: http://www.renntech.org/forums/topic/2470-remove-pse-cutout-in-2-minutes-no-tools-required/ No Durametric system can update the code in your DME or controllers, that would require a PIWIS. Under several categories in Durametric, instrument cluster for example, you will find a subsection called "coding" which will list what is active and what is not, as well as activation options for the category. I'd suggest doing some searching, as these have been a popular subjects both here and on other websites.
  22. The critical item is camshaft deviation values, which are how far the cams are off the ideal value; on a Durametric system, they would look like this: Porsche uses some unusual terminology on fuel trims; RKAT is the adaptation value near idle. FRA is the adaptation value under load and further divided into FRAU (lower load range ) and FRAO (higher load range) ranges. The RKAT values near idle are used to change the length of the injector pulse to account for deviations from ideality (ie intake leaks) to maintain the proper O2 sensor reading. The RKAT value is an additive factor and can deviate by +/- 4.5%. The FRA value is a multiplicative factor and can deviate by 1.32 to 0.70. The positive values or values greater than 1 increase the injector pulse length to account for a lean mixture, and negative values and values less than 1 are to compensate for a rich mixture.
  23. You should be looking at the cam deviation values (real time data) and they should be in normal spec range (+/- 6 degrees); if the VarioCam unit is acting up, the values should be well outside that range.
  24. If the P0021 was real, you should have been able to see the cam deviation values as being well out of whack at the same time.
  25. You should also check with Durametric to see if they have any reconditioned units; same performance and warrantee for less money.
