JFP in PA
  1. Unfortunately, while the Durametric can see many things, fuel pressure is not one of them; that requires a mechanical gauge hooked up to the test port on the fuel rail. The Durametric would still be an excellent addition to any Porsche owners tool kit however.
  2. A decent fuel test unit (Actron) is going to be about $60 or so, and has adaptors to work on just about anything. With a test unit, you can test for fuel pressure and delivery rates to determine if the fuel pump is working correctly. You can also check for pressure bleed down while the engine is off, a sign the regulator is on the way out.
  3. I seriously doubt the new CPS is at fault, it is a simple Hall Effect sensor with no moving parts. Do you have a fuel pressure test unit for the car? That would be the next thing that I would look at
  4. As there are no activations in Durametric for the parking brake on your model & year, I would have to say no.
  5. That looks like the EVAP system purge line.
  6. Have you checked the grounds on the seat belt buckles? They are well known for ground related faults. No, this was new information for me. Where can I find it / them ??? The seat belt buckles, the part that the shoulder harness plugs into, have wires running to them that tell the system when the seat belts are buckled and turn off the seat belt alert chimes. They also help tell the air bag system which seats are occupied in case of a crash, as well as controlling the system pre-tensioners. If the buckles get dirt in them, they often do not register properly and the air bag system declares a fault. Sometimes, but not always, just cleaning out the buckles with some electrical contact cleaner will solve the issue, other times the buckle and/or wiring harness need to be replaced as wear has broken the circuit.
  7. Have you checked the grounds on the seat belt buckles? They are well known for ground related faults.
  8. As the car must have taken a jolt when you hit the pothole, the plug connector on the temp sensor or the surge tank level sensor may have come loose. Suggest checking them for a tight connections.
  9. Hey JFP. I changed my oil yesterday. My drain plug uses a T50 Torx. Is this unusual? Careful inspection does reveal that the teeth are indeed squished a little to one side, the side engaged when removing the plug! Factory or aftermarket plug? You need to remember that certain Allan key sizes approximate some Torx bit sizes, but not perfectly. Continued use of the wrong type of bit will wear and elongate the device, particularly the very soft OEM plugs.
  10. There is a reason for that, your dead or near dead battery is absorbing the current so fast, the alarm never sees it and goes off. You are going to have to live with the alarm sound until the power level in the battery builds up, or resort to using the manual emergency cable to release the front hood so you can either charge up (yes, the alarm will sound unless you disconnect the battery) or replace the battery entirely. And when you install a new battery, the alarm may sound yet again, but will respond to being reset by the remote.
  11. LUK is one of the largest OEM flywheel supplier's in the world, and is also one of Porsches OEM suppliers. I would not be surprised to find out it bears the same part number as the Porsche factory part.
  12. While debate rages on concerning the use of single mass vs. dual mass flywheels on these engines, even though Porsche released a tech brief to their dealers some time ago advising against their use, the jury remains still out on the significance adding a dampening unit on the other end of the crank. While it cannot hurt, I'm not sure anyone has demonstrated to what level it helps
  13. Any time, glad you got it sorted. We have seen more than our share of failed or failing CPS in these cars, and it is one sensor that can act up, or even fail totally, shutting off an otherwise perfectly running engine, or prevent one from starting, all without throwing a code.
  14. I just read that, and still have no idea why that did it that way, other than to show how to remove an IMS bearing without using the now accepted tools. Once the cams are released and the heads are off, there is no load on the IMS shaft, so pulling the bearing is not required before splitting the cases. I would remove the flange cover first, however.
  15. I do not have any pictures of the tool on a 3.6L engine, but perhaps someone else reading the thread does. I'm not sure why they did it that way, do you have a link to their disassembly?
  16. Nothing really new there, and EPS (the producer of the video) are promoters of the European roller bearing replacement system.
  17. No, that requires a PST II or PIWIS depending upon the model of the vehicle.
  18. http://www.renntech.org/forums/topic/35926-diy-adjusting-the-foot-brake/
  19. Common response of these cars to very low battery voltages is for the alarm to sound when auxiliary power is applied. If you have access to a battery maintainer with a lighter plug, hook it up to the car and let it run for a bit until the battery builds up enough to allow you to open the hood and pull the battery out.
  20. First, welcome to RennTech :welcome: Perhaps it is just me, but I would not allow it to continue to leak. While the water will not get into the car's interior, continuous leaks can lead to other issues like rust or the water getting into electrical connections and causing all sorts of problems. Another consideration is freezing; while you may not be subject to the temperature extremes we get here (it is 3 F this morning), if you keep adding water to a system with a leak, eventually it could freeze and split multiple components, which gets expensive. Take the car to someone that knows what they are doing and get it fixed properly. As mentioned above, often these leaks are just a disconnected or short hose, which can be remedied for very little money. The missing nozzle should not have any impact on the leakage, but it will put a dent in you wallet as they are not cheap.
  21. 80K is a better than average life for the clutch, so it may be approaching its time.
  22. any updates on this? Tool is actually a VW item and looks like this: About $54 from Samstag Tools Thanks JFP, just purchased. Do you know if they make or sell a floor jack pad for 2011-14 cayenne ? I don't think I can use my jack at the spare tire jack point.Any other points under car where I can jack using floor jack while doing brake at a time? Also any special tools to loosen the pads before removing the caliper? obviously there is no more room to use piston spreader with new design of caliper. I don't really know about the jack pad, but "search" is always your best friend. The pads do not need an tool to loosen them, they usually just pop out. Thanks again JFP, I wanted to know since the new caliper design does not offer room to use a piston spreader from top would I just have to try and get a flat head screw driver in there to try and loosen the pad away from the caliper in order to pull off caliper? This was my main concern. Ive read others have said that the two tripe square bolts facing outside needed to be loosen in order for pads to get loose, but also read that this is incorrect> Can you further elaborate if you have any more info on this subject? Thanks!! If memory serves, there was a detailed write up on the procedure's on Rennlist some time back. Once the calipers are up on those pins, you use an angled brake pad spreader to push the pistons back and remove the pads:
  23. I'd keep a close eye on it for a while, you could still have an underlying intermittent thermostat issue.
  24. Any changes in pedal effort is reason for concern. How many miles on the clutch?
