JFP in PA
  1. Power steering pumps can make a racket when they are coming apart. Take off the serpentine belt and turn it by hand, you should feel it of that is the source of the noise. They also tend to leak when the bearings are going bad. If it is the pump, you will need to replace it as it cannot be rebuilt easily. You will also need to flush the fluid in the system as it could be full of debris, which can kill the rack as well as the new pump.
  2. For the coil packs, use some dielectric grease (any auto parts outlet). As for the plugs, the Beru plus are fine, we have also used Denso Iridium's with good success. Yes, use anti seize, but sparingly, on the treads.
  3. Yes, the Durametric can read cam deviation values for you. The small chain paddles can be done with the engine is the car, although it is a bit fiddly to do as the cam covers have to come off. You might want to ask the shop doing your IMS if they can put together a "packaged deal" for you to do both if it is required, as it could be more economical to address both at the same time rather than taking the car apart twice.
  4. What you need to do is check the cam deviation values with the engine fully warmed up; the spec is +/- 6 degrees, if the car is outside that range it needs attention, if it is still in range it can wait a bit. And I would not put off retrofitting the IMS.
  5. If you Google "Drive off Assistant Failure" you will find more than a few people with this issue. Unfortunately, for some reason, this system cannot be disabled (to my knowledge). The system is also very complicated as it has to know what gear the car is in, is the car moving, is it on an angle greater than 5 degrees, etc.; so there are a lot of sensors involved. I think you are going to need either a dealer or an indie with a PIWIS to help sort this out.
  6. Hard to tell without actually seeing them, but as I mentioned above, the most common sources are the wear pads on the chain paddles. As your son's car is a five chain motor, they are probably from the small wear pads between the cams on the cylinder heads, which are easier and cheaper to replace when the time comes.
  7. First, welcome to RennTech :welcome: Something you need to understand from the outset is that if you have had an IMS failure, it didn't just start, but has been shredding metal and dumping it into the oil for some time, so the debris is everywhere inside the engine, not just in the sump. As such, any shop worth its salt would look at the sump and oil filter contents and tell you that it is already too late to consider a retrofit. In addition, a common side effect of losing the IMS is piston to valve contact, which results in bent valves at a minimum, or worse: From experience in my shop, I am sorry to tell you that if you have suffered an IMS failure, at a minimum your engine will have to come out and apart, if for no other reason than to check all the components and have everything properly cleaned of the fine metal that is most likely everywhere in the engine. From time to time, someone posts about having an IMS failure and then replacing it and doing some oil flushes to cleanout the engine. Again, from direct experience, the number of times that process is actually successful can be counted on one hand with several fingers left over. Usually, 50-75 mile down the road, the engine simply grenades from that one spec of ferrous grit that ultimately found a rod or crank bearing and tore it to shreds. And all the money spent is wasted as well. To have someone pull your car apart, replace the IMS and do some oil flushes is going to cost a considerable amount of money, and has little (if any) chance of succeeding. You would be better off pulling the engine, taking it apart and seeing if it can actually be saved, or needs to be replaced.
  8. The dye can remain in the engine indefinitely, it is harmless.
  9. There are two "drains" on the cooling system, one is an actual plug (photo below) and the other is a "weep hole" which is beneath the water pump pulley itself. If a "crust" develops from leakge at the weep hole drain (second photo), the seal and bearing in the water pump are failing and need to be replaced.
  10. Sure, I should have given it to you in the first place; Part #:B483806 (1 oz. bottle). You can find more info here: http://testsite.uview.com/ProductDetail.php?PartNumber=B483806
  11. I would also change the filter, if for not other reason than to get the extra 1/2 L of oil out. You can use the 8 oz. bottle, just follow the directions on how much to add to the system (the bottle has a measuring system on it). Most shops have a UV light that we use to check cooling system, AC systems, etc. Uview also makes an inexpensive unit that is a modified flashlight. I would run the oil for 2500-3000 miles in order to give everything a chance to spread out and work, then drain it and take a sample for analysis and checking against the UV light source. Remember to retain a virgin sample for testing as well.
  12. Almost all oil manufacturers are altering their formulations, and Mobil is no exception. Many do now use additives that contain sodium. I would suggest two thoughts: Change your oil now, and retain a sample of the virgin oil to send with your next used sample for comparison testing. That should answer the question about additives. Secondly, I would obtain a bottle of coolant UV dye from Uview (they make the vacuum coolant filling system for Porsche) and add it to your coolant immediately. At your next oil change, check the oil for the presence of UV dye; if it is there, the engine has an internal coolant leak that is getting into the oil.
  13. From your description, I'm afraid this may not be a "DIY" project. If coolant is leaking out of the bell housing area, the engine and transmission need to be separated and examined (both have coolant in them), which requires both some serious equipment (lift, possibly an engine cradle to lower the unit, etc.), and considerable Porsche specific technical knowledge. I would recommend against running the car any further, and finding either a well equipped independent or a dealership in your area to assist you.
  14. More often, fuel pumps fail without any warning or noise, which is why I suggested trying to confirm the sound's source. In the end, it may not be coming from the fuel pump.
  15. I would suggest using something like an automotive stethoscope to try and isolate the sound to make sure it is the pump.
  16. Something has happened to the central locking system that makes it think that the door(s) aren't closed. Try clearing the codes and see which ones come back. Whoever did the tint job must have somehow disturbed one or more of the micro switches that signal the control unit.
  17. P0710 code is often a temp sensor failure in the Tip. Problem is that the sensor is very expensive to replace (sveral hundred bucks for a new one in a box), so I would first check the actual fluid temperature to make sure the unit really is not running hot before considering replacing the sensor.
  18. Because of the relative "newness" of the PDK technology, even a lot of the dealer's techs are not going to be overly knowledgeable on what problems can and do occur. PCNA, on the other hand, sees the "bigger picture" on this technology, and can often recommend an appropriate course of action for the dealer to try. A lot of the issues with PDK's have been software related, and there have been multiple updates, some have helped, others not so much. Talking with PCNA is not going to necessarily get the dealer in hot water, but it could help lead them to a answer that solves the problem.
  19. The main reason I would be interested in adding a TPMS to my car is early detection of slow leak flats, before the tire gets damaged. Wouldn't a TMPS serve that purpose?Thanks It would, but then so would a $5 tire pressure gauge and checking the tires from time to time.
  20. Actually, just about every year since they became mandatory here in 2007. They are expensive, not particularly accurate (although better than nothing), and more expensive to have to replace every 4-6 years. Yes, they can be turned off, and no, most (if not all) shops won't do it as they are a Federally mandated safety system (so the car can fail annual inspection if it is turned off), and the shop can be held financially liable if the car gets into an accident. Simply ain't worth it.............
  21. I find it interesting that someone wants to add a TPMS system to a car without one, as most inquiries we get at the shop about TPMS systems are about how to turn one off on cars that came with them. Just an observation...........
  22. Warranties are a unique form of contract law, controlled by the applicable laws of the country or state in which they are issued. I would suggest having your solicitor examine the wording in your case and tell you what your options are, before making any decision.
  23. Haven't used Chrome, but have also not had complaints from users either. Check to see which time frame is selected (left side of main screen), many use "last 24 hours".
  24. +1 on Ahsai's comment. There are also other online retailers (non dealers) selling it for around $35 a gallon as well.
  25. If it actually is the same, and I do not know that as a fact, it is also around $13 per 1.5L container, so it also costs more (at retail) than Porsche coolant.
