- Paint Codes
8,885 -
Last visited
Days Won
219
Exterior Paint Colors
Classifieds
Vgatescan VS-890 Code reader
JFP in PA replied to PB987's topic in 987-1 Series (Boxster, Boxster S)
That appears to be a generic "global" OBD II scan tool. What are you trying to do? -
+1. These units can be quite dangerous, even to those that work with them regularly.
If you are referring to this: It should pop right in with gentle persuasion.
- 8 replies
- valve cover gasket
- cam adjuster seal
(and 1 more)
Tagged with:
Rebuilding calipers
JFP in PA replied to no1joey's topic in 997-1 Series (Carrera, Carrera 4, Carrera 2S, Carrera 4S)
I am partial to Goodrich, but there are several others that make excellent braided SS lines as well like Crown. I also prefer all stainless. The flex lines do not really have a torque spec that I am aware of, just "good and tight" is the way to go, as long as there is no leakage. -
Rebuilding calipers
Grease looks good. We reuse the vibration dampeners all the time, as long as they are not corroded or damaged in any way. -
Rebuilding calipers
Leave the fluid level in the reservoir alone. Leave the brake pedal alone. As mentioned, you need to disconnect the flex line at the hard line connection and then cap the hard line to prevent the system gravity draining and getting air into the control network, We replace the vibration dampeners on pad kits that do not come with new ones, we use a dab of silicone brake grease to hold them and reduce the potential for noise. Yes, used a quality brake grease on the lube points noted in the service manual. You can try to sand your rotors, but I would check them for correct thickness and replace if needed. Noise problems with the brakes on these cars tend to be with the pads rather than the rotors. Any air that gets in while servicing the calipers will come out during a system bleed once the car is assembled. We use only pressure bleeding, using one of Motives units, which both speeds up the process and makes it a one man proposition. -
Secondary Air Test Readiness monitor incomplete
JFP in PA replied to mesutter's topic in 986 Series (Boxster, Boxster S)
As mentioned previously, the car has to go through a number of cold starts, full warm up, drive at highway speeds, shut off, and full cool down cycles before it resets. People have promoted specific regimens like the one you mentioned for the 993 from time to time, but I am unaware of a specific one that works consistently on the later cars.- 70 replies
- secondary air injection
- emissions
(and 2 more)
Tagged with:
The 2001 DME and emission system is completely different than that of an air-cooled 993. After a code reset, the DME is looking for any signs of problems on the five items Loren listed above, and that there are no new codes (active or pending) on these system for a period of time and under certain driving conditions.- 70 replies
- emissions
(and 2 more)
Tagged with:
First, you need to know that we cannot see the files you attached. Second, while the dealers have been replacing both the RMS and IMS flange seals due to leaks for many years, it is still the official position of Porsche NA that you cannot change the IMS bearing on the early cars without taking the engine apart. As the direct result, many dealers simply change the flange cover and RMS seals and leave it at that. Repeated RMS failures is an potentially large problem. Porsche had a run of engine cases where the opening the RMS sits in is not concentric; they even developed a tool and procedure to test a leaking engine before installing a new RMS. The reason this is an issue is that if your engine is one of those (and there were quite a few) with non concentric RMS cavities, the only remedy is a replacement engine. That's umm.. quite scary, to say the least. Can Porsche NA help me with the VIN's of the defected casings? Any idea how I can find the root cause of the RMS leak? The IMS is a different story all together.. To my knowledge, there is no way of knowing which cars are affected until the leak occurs and the engine case is checked with the special tool. What happens with the case opening is not concentric is that the seal is offset to one side and the rear of the crankshaft basically beats the seal to death in a relatively short time frame. When this first started happening, Porsche switched the seal materials to PTFE from Viton, and changed the correct seal installation depth, which seemed to help in many situations, but not all of these replacements worked, resulting in continuing leaking problems. That is when they developed the "go/no go" tool that checks the RMS seal opening in the case for concentricity. If the opening is not round, there is nothing that can be done with the engine still assembled, so they began to replace these engines, many of which were still under warranty at the time. This was all written up in a very extensive article on the subject in Excellence magazine several years ago. Thank you, JFP. I spoke with the seller last night -- He mentioned that he never really notice any dripping (in 9 year of ownership - 43k miles), but the dealer said "there was sweat around that area" during a routine maintenance, so, they performed the replacement. Also, could you/anyone help with my other IMS-related questions please? Porsche of Motor city replaced the RMS and IMS seals in May 2013 (with 2 year warranty), as the owner noticed oil leak -- see attachment. The RMS and IMS was replaced again in May of 2015 under the above warranty -- see attachment. What I don't understand is, why didn't the dealership recommend an IMS bearing upgrade, since they were already in there. - Can the bearing be inspected during the replacement of IMS seal? Maybe they didn't deem the upgrade necessary? - Are dealers instructed to recommend the IMS upgrade when they're servicing anything else in that area? - Should I assume they have inspected the clutch and flywheel when they replaced the seals? - Have you guys experienced repeated leakage from the RMS? Again, Porsche Cars NA's official position is that the IMS bearing cannot be changed without disassembling the engine, so I seriously doubt they would recommend its replacement, much less upgrading it with aftermarket parts. When the flange is off, you can see the rear bearing seal and perhaps move the center bolt to see if it is very loose, but neither would tell you very much. They may have inspected the clutch, but if they did not note it in the paperwork, there is no way of knowing. Yes, I have seen repeated RMS leaks, usually as the result of the PTFE seal not being installed properly, but in my case they were not done by a dealer. Both the dealers and I use the factory RMS installation tool and recommended procedure's as this installation is very specific and has to be done correctly or they will leak: I have also personally seen two cars with non concentric RMS case openings; in both situations, because the car's were out of warranty, the owner's chose to have a new seal installed and then either sold or traded the car in. Thanks again! I'm wondering, if I had the defective casing, would I be able to see some oil in a matter of days or months? Seals were replaced in May, 2015 and after 6000 miles, there's no leakage. They don't always leak right away, sometimes it takes miles and months to start again.
Such a feature does not exist in the Porsche DME.- 70 replies
- emissions
(and 2 more)
Tagged with:
While that might sound logical, it is not how the system operates; the car has to go through a number of cold starts, full warm up, drive at highway speeds, shut off, and full cool down cycles before it resets.- 70 replies
- emissions
(and 2 more)
Tagged with:
Very Black Oil
JFP in PA replied to Lee Quave's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
This sounds more like the filter bypass system in the bottom of the filter canister has failed and oil is continually not being properly filtered. This is not that uncommon. You can replace the canister to get a new bypass system, or switch to the LN spin on filter set up, which has no bypass and offers 100% filtration at all times. -
For some unknown reason, some of the earlier 986 cars (2000-2001) are very slow to reset the secondary air injection system's I/M Readiness flag, sometimes taking as much as 100 miles or more to reset after code clearing. People have tried a variety of techniques to overcome this, often with very limited success. If you can hear the system running on a cold start, and there is nothing else organically wrong with the car, I would just put some everyday miles on the car until you see a clear I/M Readiness test, then take it in for inspection.- 70 replies
- emissions
(and 2 more)
Tagged with:
Rebuilding calipers
If you do not cap the brake hard lines when you remove the flex lines & calipers, you will quickly find out why Porsche developed the method of using the diagnostic computer to run the ABS/PSM system while bleeding the system, as the entire contents or the hydraulic system will gravity drain and you will get air into the control network. You do not need anything elaborate to cap the hard lines, a piece of rubber hose with a tight fitting screw in one end will do the job. I personally do not like clamping the rubber soft lines, they are already soft enough to reduce the hydraulic pressure in the system. If you want to do the job right, plan on replacing the rubber flex lines with DOT approved braided stainless lines while you have the car apart. You see a noticeable change in how your brake pedal feels when these lines no longer pliable rubber. -
Couple of suggestions: We have an excellent archive of "how to's" on just about every subject (DIY Tutorials tab at the top of the page), so "search" is your friend. This topic can be found here: http://www.renntech.org/forums/tutorials/article/56-cabrio-top-hydraulic-fluid-step-by-step/ And yes, the syringe/siphon method on the steering fluid is fine. Considering the potential amount we may have saved you on projects already, now might also be a good time to become a contributing member.......
Fluid replacement - coolant, Pentosin, brakes...
JFP in PA replied to nmlss2006's topic in 996 TT, 996 TT S, 996 GT2
ATE Blue is no longer DOT and not even available in many states. ATE 200 is the same thing, without the blue dye that seems to give DOT agita.
