JFP in PA
  1. You might be surprised what you find in there, we actually found a dead bird once:
  2. Your idea is fine as well, only I have found it is easier for most DIY'ers to pull vacuum rather than go to pressure. Usually also results in fewer fatalities. :eek: With a little jury rigging, you can even use the Airlift vacuum filling tool to do this.
  3. There are four round openings on the bottom of the cooler, two in and out passages for the oil and water. The easiest way to test it is to plug one opening and pull a vacuum on the other for each loop, taking the vacuum down to around 24 inches or so, and then seeing if it holds for 10-15 min. A simple hand vacuum pump is all that is needed, along with some rubber plugs.
  4. The only legitimate source for complete and up to date Porsche technical information since they stopped publication in 2004 is their subscription TSI program.
  5. The engine oil coolers do fail.
  6. That PDF file is more than a little out of date. On your Boxster, the oil cooler is accessible by simply draining the cooling system and removing the air tube running from the air filter box to the throttle body, leaving the cooler out in the open. To replace it, you need to remove four bolts, disconnect the air bleed line on the top of the cooler, lift the cooler slightly, sliding a plastic bag under the cooler before starting to pull it out (the plastic bag is there to catch the residual oil and coolant which is going to come pouring out when you tilt the cooler to remove it; without the bag it is going to get all over the place). You will need four new O-rings (two each of the different sizes the cooler uses), do not even think about using the old O-rings, they will leak. Once the new unit is in place, torque the bolts to 7.5 ft. lbs. using an inch pound torque wrench (that would be 90 inch pounds). You will need to thoroughly flush out the cooling system using a system cleaner and lots of clear water, then refill the cooling system and you are back in business. I would also highly recommend pressure or vacuum testing the old cooler to confirm it is the source of your problems.
  7. That link does not lead anywhere, so I cannot comment. Most of Fabspeed's stuff can be installed by any competent muffler shop, or an auto repair with stainless welding experience.
  8. Well, the system uses the same temperature sensor that runs your dash temp gauge, so altering one would change both, which might not be as useful. Some track rats have wired up a manual override switch to force the fans to run, which does not interfere with the automatic system, so that might be a pathway. Another way to go would be to add a third radiator up front, which significantly increases the heat transfer capacity of the car, but is going to require more effort and expense. Are you sure your radiators are clean? You would be surprised at what we find when we open up a car with overheating problems.
  9. In a word, no. The fan on temps are built into the DME base coding and cannot be altered by either a PIWIS or Durametric system.
  10. Any differences in air flow should be adjusted and compensated for by the DME.
  11. It varies by year and model, but going in through the wheel well us usually the easiest. No special tools are required and the hose ends have pinch to release fittings on them, just be sure to lightly oil the seal rings inside the new hose ends before installing.
  12. I think it is way past time to stop trying to repair the hose and just replace it. When they get that bad, they are past their sell by date.
  13. I have some questions regarding the Clutch Bleeding portion of this tutorial. How do you know if you need to bleed your clutch? Are there signs that this needs to be done? 3 weeks ago I bled my brakes with the Motive Power Bleeder but I didn't do the clutch bleeding. Should I go back and do this? Or is there a test I can do to know if my clutch needs to be bled? I have a 2004 996 with manual transmission. And just so I get a better understanding...the clutch uses brake fluid and the brake system master cylinder to operate? Thanks in advance. Both the clutch and the brakes share a common fluid reservoir, so when you bleed the brakes, you should also do the clutch at the same time.
  14. Most low speed problems with the PDK have been software related. Have your dealer scan the car to see what version it is currently running, and update it if necessary. You didn't say how many miles are on the car, but you could also consider at least a clutch oil change while you are there as well.
  15. After you clean it the filter canister, use a bright light and carefully inspect it for any impact damage. We have had a couple leak because something hit them and cracked the plastic housing.
  16. No. With the engine running, and the trans in gear, the front pump is running at full pressure and everything is full.
  17. Sounds like a bad misfire, but without a scan and the codes triggering the MIL, anything would be a guess.
  18. By-the-by, did you ever get your RMS straightened out?
  19. Duncan is correct; the only time you would need to pull the third tensioner would be if you cannot get the flange off after pulling the original two, and that very, very rarely happens.
  20. Well, you can try sending your photograph to the dealer's parts department, and maybe they can give you a better answer.
  21. Behind the wheel well liner on that side is the EVAP canister and fuel tank filler. Most likely, you are hearing noise from that. Have a read through this: http://www.renntech.org/forums/topic/33970-strange-whistling-sound/
  22. Try looking here: http://www.sunsetporscheparts.com/auto-parts/2000/porsche/boxster/roadster-s-trim/3-2l-h6-gas-engine/hvac-cat/evaporator-and-heater-components-scat Remember, some parts are not available separately, you may need to buy a larger component to get it.
  23. No. #3 is called a lower control arm, #6 is the track bar. http://www.sunsetporscheparts.com/auto-parts/2011/porsche/cayman/s-trim/3-4l-h6-gas-engine/front-suspension-cat/suspension-components-scat
  24. The Pro version is capable of activating the cruise control system, but the Enthusiast cannot.
  25. Yes, but always use new bolts only.
