JFP in PA
  1. Welcome to RennTech :welcome: When asking questions like this, it is always good to include the year and model and they are not always the same.
  2. Normally, when the switch goes bad, strange electrical things start to occur. Lights won't turn off or turn off unexpectedly; other accessories (radio, dash displays, etc.) do not function properly, etc. Commonly referred to as 'electrical gremlins'.
  3. Welcome to RennTech :welcome: Possible bad electrical section of the ignition switch.
  4. Dealer item, try Sunset Porsche, a board sponsor: http://www.sunsetporscheparts.com/
  5. There is an obvious communications issue when they try to set up the control module. Unfortunately, it is nearly impossible to even hazard a guess as to what is wrong without further diagnostics, which means an open ended search for the fault.
  6. Duplicate posting deleted by moderator. Please re read the forum rules you agreed to when joining concerning multiple thread posts on the same subject.
  7. You can see the wire retaining clip in this photo:
  8. Actually, it may not. Wet belt slippage is a common complaint on these cars, even with brand new belts.
  9. As your central locking unit seems to be responding (beeping and not locking), there is probably nothing wrong with it. As for the missing parts, those you are going to need to be sourced. It sounds more like you have a bad lock mechanism, which will have to be replaced (be sure to check both doors).
  10. That totally depends upon the integrity of the rest of the muffler; if it is otherwise in good shape, it should hold for a long time.
  11. That should not be left as is, both because in many states, you would fail inspection for that, plus it is leaking CO under the car, which can be dangerous, particularly in the winter. Depending upon how solid the surrounding metal is, it could be welded.
  12. We no longer have the pipe coupler, but it is a common white CPVC pipe coupler found at Lowes or Home Depot. Just be sure it has the internal shoulder than the pipes would normally butt up against. The shoulder is important because that is what the flywheel bolts rest on while inserting the seal.
  13. Your convertible top is not in the expected position. Could be sensing micro switch, or the top is not set properly and needs to be recalibrated.
  14. Sounds like you may have a clutch fork pivot issue.
  15. hi hope you can read my question. i changed the transmission oil i got 4 liters out and i put 4 liters in. but the owner told me they just replace the tranny oil couple of months so i did not change the transmission filter. and put the 4liters of oil. after this the engine lights on and P( parking ) and D4 start blinking. i can still drive but it drives me crazy and scared. pls tell me what to do before i take it to the shop and charge me arm and leg Welcome to RennTech :welcome: Get the car scanned with a Porsche specific scan tool, looking for transmission codes.
  16. Now that we have gotten past that one, check your bulbs on the side blinking fast to be sure they are illuminating properly (could be a bad bulb), otherwise I would look at the turn signal flasher module, it may be going south.
  17. JFP, I just checked GP2 and GP3 per Bentley Manual. Both are secure and wires look good. I'm running out of ideas... Yes, but did you check them with a multimeter for continuity and resistance? OK, that was easier than I thought. So both circuits involved had a nominal amount of resistance, around 3 ohms. I'm thinking that indicates we have continuity. I'm wondering now if there's a bad connector at the headlamp. The connector at the foglight looks good. I guess I should check for continuity between the headlight connector and fog connector next? Three ohms strikes me as higher than I would expect. Yes, I would also check the headlight connector as well.
  18. JFP, I just checked GP2 and GP3 per Bentley Manual. Both are secure and wires look good. I'm running out of ideas... Yes, but did you check them with a multimeter for continuity and resistance?
  19. Welcome to RennTech. Check the grounds on the light in question.
  20. OK, let's take this one bit at a time. Coolant lines on a 996: Very few AOS failures result in an intermix problem; usually when the AOS fails you get clouds of smoke from oil being sucked into the intake due to excessive vacuum in the system. I replace these things for a living, and every 996 leaving the shop has the coolant version. The 986 has never shown any freeze up tendencies, so no coolant is necessary. Because the AOS connection to intake vacuum is actually behind the throttle body, you will never see any oil in the TB. If you are pulling 10-11 inches of water at the oil fill cap (a good AOS will pull 4-7 inches of water on a cold start, but level off at 5 inches or less vacuum warm), your AOS is toast and should be changed out before you start sucking liquid oil into the intake, which can hydro lock the engine and kill it. Buy a new factory (not aftermarket) AOS and change it before something really stupid happens. That's pretty straight to the point, I appreciate the advice and will get the part on order. I wonder what that plastic tube coming into my intake track just before the TB is if not AOS connection... I have the X-51 kit in case that makes a difference in your response. thx The AOS vacuum connection has to be after the throttle body, or there would be no vacuum. The intake ahead of the throttle body is at atmospheric pressure.
