JFP in PA
  1. Individual injector failures are pretty rare in these engines. By far, most misfire codes are ignition system related. It would also be fairly easy to prove/disprove the injector theory by monitoring your fuel trim values as the car warms up.
  2. Long before I'd go after the temperature sensor, I would be looking at the air diverter doors in the heater box. These are a well know failure item on the 986, and will cut off the heat.
  3. This needs proper diagnostic's, such as checking the actual oil pressure and trying to isolate the sound source in the engine bay.
  4. Welcome to RennTech What kind and weight oil did you use? I would not be driving the car until you fix the problem, as it could make it much worse.
  5. Your voltage is too low, should be around 14 V running; the alternator is still bad, possibly the voltage regulator inside it.
  6. You can use any bolt combination that is long enough and stout enough to support the weight. Beleive it or not, they do not have to even be metric as they will pass through the stand mount and the trans bell housing.
  7. We attach the engine stand mount to the engine, then lift it with a nylon strap sling using an engine hoist. Simple, but it works and is very stable and safe.
  8. Welcome to RennTech When the alarm goes off, and even when just setting it, the alarm module flashes the vehicles turn signals. So shorting one of them can work backwards through the alarm system and get to other components.
  9. What is this, a quiz? You remove the large nut, and then the inner race, twisting slightly.
  10. Without proper scan data, any suggestions would be a pure guess. There are several things that can trigger cruise system faults (wheel speed sensors, brake or clutch safety switches, cluster programing and communications faults, etc.). To fix this with minimal effort and cost, you need to know where to start.
  11. P0600 is a communications system fault, no message is being received and the system is timing out.
  12. The early 986's had issues with the EVAP system making noise and causing other issues; do a search, there has been a lot of information posted on this subject.
  13. You have a fault somewhere, you need to scan the car with a Porsche specific tool to see what is going on.
  14. You are allowed a total of three VIN's on that model cable, after which it will not accept any more. If you want unlimited VIN's, get the Pro version.
  15. If you are referring to the tutorial, it is available for contributing member's.
  16. Yes, we have done several in the shop, and every one came apart that way.
  17. When you get to step #5, you need to slide the switch faceplate about 5mm (1/4 inch) out of the vent unit, the turn the switch slightly counterclockwise to remove it.
  18. They need to be replaced, which is not all that difficult. On yours, they pop off: How to replace clips
  19. With difficulty. You should not be working in this area with the battery connected. If you cannot get a small tool in and pop the fuse out, your other option is to drop the heater box out of the way.
  20. It is mounted to the firewall and actually penetrates the firewall to access the battery cable. It cannot easily be pulled down without disconnecting several things.
  21. Welcome to RennTech. Probably a good place to start is looking at the Bentley manuals for the car, which while not as extensive as the factory service manuals that are no longer available, it will still give you a good idea of the systems layout. And as Porsche tends to be brutal concerning their intellectual property rights, such as wiring diagrams, you will not likely find what you want for free. This forum also does not participate in or encourage the violation of any intellectual property rights, as was mentioned in the rules you agreed to when joining. The Porsche DME is somewhat limited for tuning purposes, but there are some aftermarket re-flashes available that may add very modest output improvements when used along with a significant investment in mechanical engine modifications. The Tiptronic transmission has its own controller that works in conjunction with the DME. I would also suggest you do a search and read up on known potential weak points in the M96 engine, such as the IMS bearing and RMS. These can easily be corrected, but need to be addressed prior to running the car in competition. Good luck!
  22. You would need to get in line, others have been there before you. Mityvac, amongst others, have promoted this concept for years. Unfortunately, there is are a couple of major downsides: Going in through the dipstick tube, you rarely get all the old, contaminated oil out. Secondly, and perhaps more importantly, there are a lot of sharp edged things down there that can catch flexible tubes inserted down the dipstick tube. We have had more than one car flat bedded to the shop after an oil extraction unit line got stuck and could not be removed, requiring us to run up some expensive shop time getting it out. If you cannot get under the car and change the oil, or are uninclined to do so, take it to a shop and let them change the oil as the car was designed to do. In the long run, you will save yourself headaches and expense.
  23. Porsche no longer publishes this type of information in a print form.
