JFP in PA
  1. Are you sure it is the line and not the fuel tank connection itself? Your 2004 has a fuel filter that is part of the pump assembly itself down in the tank.
  2. What scanner did you read that code with? Reason I ask is it comes back as a high exhaust gas temperature sensor.........
  3. If the stat is stuck wide open, reving the engine quickly increases coolant flow without any "throttling" effect of the thermostat, and temp drops below normal range.
  4. The thermostat sets the minimum temperature of the engine' if it is stuck open, the engine will tend to run cooler.
  5. Welcome to RennTech There is a small switch near the latch that closes and completes the circuit when the boot is opened; I'd start there.
  6. This exact problem was just discussed, with complete fix details and photos on the 986 Forum: http://986forum.com/forums/general-discussions/66146-need-everyones-help-pushed-front-drain-hole-grommet-through-hole.html
  7. Welcome to RennTech There is a specific thread area for recovering radio codes called "Lost Radio Code - post your request here"; I would suggest reposting there....
  8. I would also ask whose IMS retrofit was used; there are some replacements that are not as good as others...........
  9. No. The PST II is a Windows based system only and cannot be used on any type phone.
  10. I would start by removing the oil filter and cuttingt it open; if it is full of metal, you will need to drop the engine for further examination. If the cams are not rotating in sync with the crank, I would seriously doubt the news is going to be anything good......
  11. Correct on the cam plug location. An oil drain is not necessary, with the engine off there is little oil in the cylinder heads. If the chains have failed, the engine will not run, and even turning it over would result in bent valves, and the engine would not be able to complete one rotation. These are interference engines, meaning that if the valves are not opening or closing at the correct time, parts start hitting and it is all over.
  12. If yours is a 2001 Boxster, pull the green plug on the exhaust side of the head on the passenger's side and rotate the engine by hand (clockwise ONLY) using the bolt in the crank pulley. When the engine is at TDC, the slot in that cam should be straight up and down in the plug opening. As the crank drives the cams via the chains, yes the crank would move if the chains were broken, but the engine would be trash as there would have been massive piston to valve contact. At that point, codes would be irrelevant.
  13. Tool 9637 is one of Porsche's Unicorn tools, it is called a pin out box for diagnosing electrical issues in the harness. These things cost a couple of grand, and the last time we looked the wait time to have the elves in the Black Forest build one for you was about two years. It is not going to be easy to find. The harness can be repaired, but with a couple of caveats: The wire gauge and colors should match for later diagnostic purposes, and the replacement should be soldered and heat shrinked, never crimped (low voltage sensor signals are very suseptable to line resistance, which is common with crimped connections). You can always swap the sensors, but as the code is specific to a harness issue, the code would not likely change. You would probably better spend your time jury rigging the wiring harness electrical tests looking for the short.
  14. Not really sure about the switch part number; I can honestly say I have not seen one without a number, but then I have only see a few of them total. But I am still focused on the point that when you purchase the wheel as a kit from Porsche, it comes with a switch, which may mean the switch itself is different for the multifunction wheel. You would need to talks to a Porsche parts department to confirm or deny that.
  15. Codes are probably related, but the P0343 is often more a wiring issue than a replacement: P0343 Camshaft Position Sensor 1 – Above Limit Potential causes: – Short circuit to B+ Check the connector/wiring. Check signal wire from DME control module, pin III/20, to CMP sensor for short circuit to B+. 1. Connect special tool 9637 to wiring harness (DME control module connector). 2. Remove connector of CMP sensor. 3. Connect voltmeter to special tool 9637, pin III/20, and ground. Switch on the ignition. Display: 0 V If battery voltage is displayed, check wiring harness for chafing and pinching damage.
  16. Looking at the photo again, you might be correct, which would explain why the car has no codes (the sensor is still connected electrically but not mechanically). If that is the case, the part is a $5 "support", 99634137103.
  17. Call Sunset, tell them which side you need (although I think one fits both sides) and they will confirm what you need.
  18. That should be correct. If Sean is on his game, he should have asked you for your VIN to verify that is the most current part (their system is always more current than what we have out in the field).
  19. Yup, that little black object is call the level sensor, and retails for around $70-80. Items # 1 & 2 in this diagram:
  20. Easy enough, contact board sponsor Sunset Porsche ( (503) 718-6060) and they will set you up with what you need. Sensor should be 99763112100 , but check with Sunset for any updated numbers, retail should be about $70 each.
  21. Porsche designed the cars to be able to use the cigarette lighter for this purpose; we also have used the lighter connection on cars for years without problems.
  22. Welcome to RennTech You have discovered what several others have as well, when it comes to Porsche diagnostic tools you have few viable options because of the unusual diagnostics protocols that Porsche employs. Several companies have claimed they had Porsche compatible tools that could be used on any car, but very few have actually delivered on that promise, and those that did ended up costing many times what the Durametric system sells for.
  23. While using some blue (read medium strength) Loctite is a good idea on low torque fasteners that tend to come loose, over torqueing them or using red thread locker is decidedly a very bad idea, as he will likely discover if he ever needs to disassemble the components in the future..........
