JFP in PA
  1. No, you have to have the original tag to program the system.
  2. The lack of an immobilizer signal to the DME shuts off multiple circuits to prevent the car from starting.
  3. An additional thought: There is a small glass fuse in the box under the seat, have your guy check it as if it was blown, the box is dead.
  4. Works this way: When you insert your key into the ignition, a pill in the key is read by the box under the seat, which then sends a code to the DME, allowing the car to start. If someone tried to hot wire the car, or use a bogus key, no pill, no read, no signal to the DME, car won't fire.
  5. That maybe, but the fault codes say it is the central locking system, you need to figure out what was done during the radio install that upset it. It would also be helpful if you listed the "P" codes as well.
  6. That looks like your central locking/alarm computer is malfunctioning and keeping the car from starting (thinks you are stealing it). Has this key worked in the past? If it has, you need to start looking at the control unit under the driver's seat to see if it is wet, has become disconnected, or has its internal fuse blown.
  7. You have to stay objective; if something looks questionable, it probably is and is not the only thing that is.
  8. P1372 - valve lift control, bank 1
  9. I would try and grab as much data as possible, as at this juncture you don't really know what you are looking for. I would, however, pay particular attention to the fuel data.
  10. Quite often, the hardest part of buying a car is not getting emotionally attached to it, but stepping back and looking at it in the hard light of reality. I'm sure there is another one out there that has been lovingly cared for and just waiting for you to find it.
  11. Run, do not walk away from that car. We see this all the time: Deferred maintenance. If he did not care to maintain the car, what else did he ignore.........................
  12. Only way to know that is to connect a Porsche specific scan tool to the car and collect real time data.
  13. I am not aware of that happening.
  14. Welcome to RennTech P0335 and 0336 are cam and crankshaft position sensor issues, sensors are either out or wiring to them is questionable. P1266 is for your "drive by wire" system, which is also reading out of range, which can also be related to the sensor issues.
  15. Welcome to the world of 911 service. If you think yours is bad, take a look under a 996 turbo.................
  16. Most likely, you have burned out one or more circuits by doing this. I would test the alternator for output, but you have probably either smoked the voltage regulator or a diode or two, which will require replacement. The PSM is probably a ghost code due to the alternator issue. You may have also cooked other circuits that have not showed up yet, so be prepared.
  17. $36 a plug is more than a bit steep. Check the same part number on board sponsor Sunset Porsche's parts website, I'll bet it is significantly better..............
  18. Actually, it is pretty high based upon experience. I would pull the coils and look for small cracks, the give away sign that the coils are on their way out.
  19. You can read the alternator output with a digital multimeter, but the battery should be load tested.
  20. Scan them into your computer, then cut and paste them into the translator.
  21. Welcome to RennTech When posting questions like this, it is always useful to also provide the year and model of the car.
  22. That slight a tire pressure difference should not be enough to trigger this problem. More often than not, battery/charging system issues can trigger "ghost" ABS/PSM codes in these cars, so I would start by checking them first. I would also scan the car with a Porsche specific scan tool to see what faults are indicated.
  23. Welcome to RennTech Sunset Porsche is one of RennTech's board sponsors, and very highly regarded within the Porsche community at large. Many poster's here, as well as shops like mine use them almost exclusively for our parts needs without problem. Did you try to contact them to resolve your problem with them?
  24. No, the CPS would totally shut down the engine if it failed.
  25. OK,let’s start with the most obvious: Cracked coils are a problem, regardless of what plugs are used. They need to be replaced. As for the plugs, there are a wide variety of plugs that will work fine in these engines, ranging from the factory Beru to Denso Iridiums, but they need to be properly gapped. Most shops do not have the tools to reset the gaps on multiple side electrodes, so they just slap them in the way they come out of the box. Usually, the Beru’s are pretty close right out of the box and need no changes, which is one reason they are widely used.
