JFP in PA
  1. The gear oil drain plug is in the transmission (plastic) pan. and the gear oil fill plug is on the same side, a few inches up on the case. Both plugs are hex head and a little larger than clutch oil fill plug. The clutch oil drain plug is on the tranny pan. and the fill plug is on opposite side as gear oil fill plug.
  2. The PIWIS is required to shut off the clutch oil cooling system during the service. Currently, it is the only scan tool capable of doing that. The oil fill is up on the side of the gearbox.
  3. You know, when you post on a Porsche technical forum, it would have been helpful to perhaps at least mention you had a GM engine in the car and are running two completely incompatible computer systems. As such, I have no reference point to offer any diagnostic help. Good luck...…….
  4. +1. Mine has been in the car for 18 years.
  5. Welcome to RennTech No, they don't have a rollover switch, but they do have a crank position sensor which shuts the fuel pump off when they go bad...…...
  6. Actually, the PDK transmission is exactly the same as the manual gearbox with a drain and fill plug. Do a gravity drain, and refill using the fill plug. ALWAYS remove the fill plug before removing the drain, so that you know you will be able to refill it once it is drained. The "kicker" on the PDK car is changing the clutch fluid, which should be changed twice for every time the gearbox is changed once, and requires the use of a PIWIS unit to do it properly.
  7. Please do not "bump", it is against forum rules.
  8. I would highly recommend against poking anything down one of these drains, as it is far to easy to either hole the tubing or break it loose at a connection point. Use compressed air.
  9. Never used an "upper cylinder lubricant", as I have no idea what it is supposed to do, but we use and recommend Techron at least once a year, preferably just before you change oil as it can result in crap showing up in the oil. To my knowledge, Techron is the only fuel system cleaner Porsche ever recommended as well. Please don't double post, it is against forum rules.
  10. Welcome to the land of Porsche's, were gear box and transfer case fluids often have very peculiar specs and are often produced to Porsche's specs. People regularly use other products, some seem to work OK, others not so much. We only use the Porsche products as we (and our customer's) have never had an issue as the result.
  11. Never used an "upper cylinder lubricant", as I have no idea what it is supposed to do, but we use and recommend Techron at least once a year, preferably just before you change oil as it can result in crap showing up in the oil. To my knowledge, Techron is the only fuel system cleaner Porsche ever recommended as well. Please don't double post, it is against forum rules.
  12. I've always found it easier to put the bottom on first.
  13. Have that cylinder bore scoped. These engine's are known to scuff cylinder walls or even turn the cylinder slightly oval under some circumstances. If the wall is scuffed, de-carboning is not going to get you much.
  14. That maybe your only choice as Porsche never published that wiring diagram, it was only available on their PIWIS system.
  15. Welcome to RennTech Your code indicates a signal problem, not necessarily a bad sensor. More likely, you have a loose or corroded connector in the circuitry, or a bad wire somewhere in the system. You are going to need to do some circuit diagnostic (continuity, voltage, voltage drop, etc.) to find the problem.
  16. Look at the vacuum lines carefully, quite often it is just a small split in one or more lines.
  17. P0491 Secondary Air Injection System, Bank 1 - Insufficient Flow P0492 Secondary Air Injection System, Bank 2 - Insufficient Flow Possible cause of fault - Electrical fault in power supply or line between relay and secondary air injection pump - Secondary air injection pump relay mechanically faulty - Mechanical fault in electrical secondary air valve - Pneumatic secondary air valve faulty/sluggish - Electrical fault in secondary air injection pump - Mechanical fault in secondary air injection pump or secondary air injection pump blocked - Vacuum system leaking - Air hose to secondary air injection pump slipped off or constricted
  18. You should look at the classified section of this website and other Porsche related sites for used ones, you can also check flea bay as well. Amazon also sells them, but only new ones.
  19. Probably your best bet is the Bentley manual for the 996, which is in book form only. You can also look around for a set of the factory 996 manuals, but they are expensive and harder to find as they have been out of print for many years now. Be cautious about pdf files, they tend to be woefully incomplete and/or out of date (there were many updates to the originals over the years), plus as most are illegal copies of Porsche copyrighted intellectual properties, and subject to legal action. This website does not condone trading in such materials.
  20. Manual gear box Boxster had a declutching alternator pulley that make a racket when the clutch is on the way out. Fortunately, the clutch is available separately and is not too expensive.
  21. The way we do it is to disconnect the sway bar and the lower strut mount in order to gain enough space to remove the outer and inner hub assemblies. Once that is.done, it is a simple matter to remove the bearing. As we use the SIR tool, I cannot comment on the OTC method, but there is probably a DIY using it online somewhere.
  22. Yes, the wheel bearings can be replaced without removing the carrier from the car, but it requires special tooling such as the SIR set up. It is always advisable to mark suspension components when working on the car to aid in getting back somewhere near correctly so you can drive to an alignment shop. And yes, I would always advise an alignment check after doing this type of repair.
  23. The reason for replacing it all is that nothing is forever, particularly "lifetime" coolants. They all break down over time, lose their additive packages and thus pH and corrosion control. Realistically, coolants, even so-called "lifetime" systems need to be replaced every 5-7 years, or earlier if they show signs of failing.
  24. You are only going to get about 80-85% of the old mix out by simply gravity draining it, if you want to get more out you will need to do at least one or two flushes, preferably with distilled water. As for the new water pump and thermostat, I would just install them and then do the flushes.
  25. The original coolant in early 986 Boxsters was green and was superseded by pink years ago. While the pink is backwards compatible with the green, I would dump the entire system and start with a fresh 50/50 mix with distilled water for maximum protection and life expectancy.
