JFP in PA
  1. OK, D7 has been used for hazard warning lights and/or the spoiler, but at some point someone may have cut into it to add something. In general, the spoiler or hazards should not be drawing current when not in operation, as you showed when you disconnected the plugs. You need to trace the circuit and look further.
  2. Welcome to RennTech Year and model of the vehicle please
  3. Just make sure the converter us fully seated into the gearbox before reinstalling it. If it is all the way in, it should spin freely with the gear box in place; if it binds, it is not all the way in.
  4. If you scan the car with a Porsche specific tool, it can tell you what triggered the last ten alarm trips.
  5. It is air bound, you should have pulled a vacuum on the system to get the air out and then (still under vacuum) refilled the system.
  6. Welcome to RennTech Just be aware that your system operates at 18 PISG at 210F, conditions that blowing into it can never replicate.
  7. Long before I would be spraying deodorant all over an engine, I would add Uview UV oil dye to the oil and trace it with a black light; works like a charm but does not smell as nice.....
  8. Just don't expect it to deal with many Porsche codes, which most generic OBD II scanners cannot even see...………..
  9. Without a good look, it is almost impossible to say where it is coming from. A good start would be to clean off the engine and then monitor it for leaks...…..
  10. Then give them a call, it may be part of the wiring harness that only comes with that section of the harness.
  11. Welcome to RennTech Have you tried looking the car up on board sponsor Sunset Porsche's parts website? They have the entire Porsche parts system diagrams on line.
  12. Yes, egas is electronic throttle; and there are no such things as stupid questions
  13. Your car is an e-gas model.
  14. Let's start with the obvious: If you blew a head gasket, you are the very first one to ever do that. The multi layer steel head gaskets in these engines are stronger than the block or heads, and never fail, ever.
  15. Which is interesting as Porsche never printed them in the first place...………….
  16. Welcome to RennTech When the converter is properly inserted into the front pump housing, it engages muplitple shafts and should turn easily and smoothly, and the pin should insert easily as well. When the pin did not fit properly, it was an indication that the torque convert had not been properly engaged with what it should be. Because the system internals operate on hydraulic pressure, turning the out put shaft or shifting gears really does not do anything, so being able to realign the converter is more a matter of coincidence than correcting the problem. If the car were in my shop, I would pull the trans back out, and make sure the converter is properly aligned. If you start one of these cars with the converter out of alignment, you are going to do some serious damage to a very expensive converter and transmission. There is only one way the converter is correctly installed, but may ways that leave it on the edge of creating a major nightmare.
  17. All these parts have been superseded with upgraded pieces: Piston 997.107.125.01 Spring 996.107.127.53 Gasket 996.107.123.50 So for less than $20 at retail, you get better low RPM oil pressure. The new piston also has a bevel on its upper edge as well, and the spring is slightly longer
  18. Could just be a coincidence, the only thing I can think out that could crap out during an oil change is the by pass valve in the bottom of the filter cannister, these are very prone to failure but the fix is simple: Buy a new cannister as the valve only comes with it.
  19. I would start by checking the car with a proven mechanical pressure test gauge to make sure it is low pressure and not a failing oil pressure sensor. If the oil pressure is good, you should replace the pressure sensor, and I would also replace the oil pump pressure regulator piston and spring with the updated version Porsche released a couple of years back to address low oil pressure issues. All in, the pump pressure regulator parts will cost about $20 (US), and it is very worth while update.
  20. Welcome to RennTech I stand by what I told you over on Pelican, you are attempting to replace an electronically sophisticated engine with an earlier version that miss matches on everything from the fuel system to the VarioCam systems to the DME version. Can it be done? Yes, with enough money, time, duct tape and welding equipment, anything is possible. The end result will be a time and money pit with significantly reduced resale/trade value as only one person knows how it all works. You will be infinitely better off getting a better matched engine.
  21. The DME and sensors are very capable of making adjustments within their design bounds for most modifications; if you have gone extreme, you may need to look at the tune vs. the A/F ratio, timing curve, etc.
  22. The DME uses the CPS signal to control the fuel and ignitions systems, no CPS signal, no fuel pressure. You need to check the CPS at the connection near the bell housing.
