JFP in PA
  1. Here is your problem: Porsche coolant does not always play nice with some aftermarket formulation, resulting in a gelled cooling system which is a bear to clean out. So, if you don't know what is in it, or how old it is, just use distilled water until you can drain and flush out the system. Then you can use just about any product meant for alloy engines.
  2. Please do not repost in attempt to "bump" your post, it is against forum rules.
  3. Personally, I'd like to hear why the engine needed the front oil seal replaced twice, and why it needed new cams. Very low probability repairs that rarely occur, and they both occurred on this engine. Strange...………..
  4. Welcome to RennTech You've got something wrong in the slave install; pull it and reinstall it. If anything, and new slave should be very easy to depress.
  5. The fans are pulse width modulated type, which is built into the fan motor and not serviceable.
  6. Pull the oil filter, that will drain off around 1/2 quart/liter.
  7. Check your VIN on board sponsor Sunset Porsche's parts web site, that's should tell you what you need.
  8. If you think you damaged the trans, drain it and check the oil; it should be full of metal if you wacked something.
  9. Typical one piece flywheel noise; when you removed the dual mass flywheel, you also removed all harmonic dampening from the system.
  10. Check and make sure one of the tires is not making contact while turning and backing up.
  11. The correct filter for an early 996 is the 986-307-403-00, which was also used in the Boxster.
  12. Take a moment to remember the sacrifice of those that made what ever you are enjoying possible...…..
  13. Just tell them you have swapped clusters, they should be able to take it from there.
  14. Get the car scanned with a Porsche specific scan tool (Durametric or PIWIS), the system stores the last 10 alarm faults and will point you to the problem.
  15. You want the cap that ends in -04, 996-106-447-04.
  16. Unfortunately, the problem with DIY on AC systems is the cost of the proper service equipment; to properly vent one of these systems, you need a recovery unit which can cost well north of $3K, a vacuum pump to properly evacuate the system before charging, oil and dye injectors for service, and an accurate pressure gauge system for evaluation its performance. All this hardware is usually well out side the budget of all but the most serious DIY'er.
  17. You risk major problems. If you are unsure how much oil is in the system, it can be flushed clean with a special solvent and than recharged from scratch, but that takes special equipment.
  18. Could be something as simple as a failed AC hose, or it could be the compressor itself. If you are not equipped to handle it, take it to a pro.
  19. It is more than just glare, my license to conduct what you would call an MoT inspection requires me to fail cars with modified headlights or headlights components that lack our DOT approval marking. Police here can also require the vehicle be towed and repaired to factory specs before being allowed back on the roads.
  20. And which contains multiple incorrect assumptions...……………..
  21. Removing the real seal will lubricate the factory bearing without any junk additives.
  22. This is exactly were everyone that thinks they can do better themselves goes wrong. The LN ceramic hybrid bearings cannot be "sourced from hundreds of places for a variety of prices". The LN bearing is the final result of a lot of R&D, trying out various bearing materials until they fail, to identify the best selection of components for the final bearing. And as that design is produced exclusively for them, you are going to have a very difficult time replicating their results Good luck...…………..
  23. If the engine was a 2003 (you can tell from the numbers on sump rail), it would have the small, serviceable single row IMS bearing from the factory. If the paperwork does not mention the IMS, it was not done.
  24. Welcome to RennTech Low apparent oil pressure can have multiple causes; the dash gauge can be bad, the oil pressure sending unit can be bad, and so on. First step is to connect a known mechanical gauge to check the car’s actual pressure. There is even a cheap (around $20) factory kit to update the oil pump pressure control piston and spring to address this exact issue. But first you need to know where the engine really is at. Good luck.
