JFP in PA
  1. The bracket is probably just rusted in place, give it a wack and it should come loose.
  2. Welcome to RennTech Probably a couple of unrelated things. You have an alarm fault (double beep), a scan with a Porsche specific scan tool will list the last ten faults. You probably also have an ignition switch problem, a well know issue with these cars. Parts are cheap and a search will turn up several DIY's on how to change it out.
  3. Possibly a bad ignition switch.
  4. What you should be doing is running a voltage drop across the primary cables; anything more than 0.5 V means the cables need to be replaced.
  5. It is not a matter of your infrastructure, it is a matter of people being lazy here. A lot of US companies will not even ship into Canada, simply to avoid the customs issues and costs.
  6. Not really, other than confirming your fuel trims are out, which the codes have already done. In this case a smoke test would be more useful. Finding air leaks that throw the mixture off can be a major headache. These are handled strictly on a “time and materials” basis in the shop; it could take 15 min., or it could take four hours.
  7. I think they just did not want to get involved shipping parts to Bulgaria.................
  8. Start looking for air leaks on your intake and vacuum lines.
  9. Porsche’s service manual say 59 ft. Lbs.
  10. Porsche changed their ways after getting burned years ago. In 2001, every car that rolled off the assembly line had cruise control and the on board computer capability literally built into them, even if it was not ordered as an option. The theory was that if someone later wanted to add it, the dealer would charge the exact amount of the original option and simply activate the desired option with the PST II or PIWIS system with minimal actual mechanical modifications. Problem was that (1) People caught on to the fact that the options were already there, and (2) People refused to pay Porsche what they thought they were due, and either activated the options themselves using the Durametric software , or paid a lot less to have an Indy do the deed. Some of the few that actually paid Porsche to activate the system sued PCNA, claiming they were paying for something they already owned, and the courts agreed with them. Porsche subsequently stopped putting inactive options, and their associated harnesses, sensors, etc. into the cars unless they were originally ordered that way, making updates later more onerous.
  11. The color is not unusual. As a shop owner, I tend to leave things like O2 sensors alone until they tell me they have a problem. We have customers that have gone over 200K miles on a 986 with the original units. Others seem to have issues earlier. Like catalytic converters, it seems to be more related to the quality of the fuel people use than miles. At a gathering of shop owners, a discussion of cat and sensor life’s got started, and those with shops in urban areas with stiff local fuel taxes observed that they see a lot more failures than those of us out in the sticks, leading several owners to observe that customer’s in the high fuel tax environments buy the cheapest fuel they can find, which raises the question about the quality of those cheap fuel supplies, and what that may be doing to emissions components. While not a scientific examination, it was an interesting observation.
  12. Glad to hear you got it sorted. Often, what appears to be a complicated multiple issue problem is actually simple if you stop and look at what the codes are telling you.
  13. No, we use anti seize compound on these fasteners before torquing them. Because they are rather small, and adjacent to coolant, there is strong possibility of corrosion over time, which will result in snapped bolts on the next pump swap. A little precaution now can prevent hours of grief at a later date.........
  14. Sorry to hear of your predicament. The PDK is ultra complex internally, with even the dealer techs limited to what they can do to repair them. These internals require very specialized fixtures and tooling, which is beyond even the dealer’s capabilities. Good luck with your next steps.......
  15. I sincerely hope that day never comes. But you have shown why those of us that fix these things for a living regularly tell people to stop trying to cheap out with aftermarket components; your Gates pump is a poster child for why we say what we do, and why we depend upon factory parts.
  16. No such system exists. Just about every OEM has areas of “proprietary code” which require a dedicated system to pull codes and conduct diagnostics. Porsche is one of the worst in this respect, with several major systems “off limits” to many diagnostic systems. As far as the Durametric seeming expensive, the next step up in Porsche diagnostic systems, the current version of the PIWIS system, starts at $20,000 a year.
  17. Clear all remaining codes and go drive it like you stole it...…………….
  18. We only apply the "blue wrench" when hanging on a 40 inch breaker bar won't budge them, in order to prevent removing the threads with the sensor; usually they pop loose with enough grunt.
  19. They do take a heat set after years of thermal cycling, which is why anti seize is needed. I don't remove the wheels, but I am working on a lift. If you don't have the car on ramps, it MUST be on jack stands, not jacks...…………..
  20. I can be done on jack stands. One of the beauties of the 986 is that these are exposed from underneath: You are going to need a sensor socket (about $10 on Amazon) that is open on the side to allow the pigtail to hang out while doing this, and you are going to need some anti seize for the sensor threads:
  21. These hydraulic tensioners should be torqued to spec (59 ft. lbs.); if they still leak, they need to be removed and have the crush washer replaced, then retorqued. Removing them requires locking the engine at TDC and locking the cams to prevent them from jumping time.
  22. I would not write the MAF off just yet, and Sunset is well known for quick shipping and great customer service.
  23. Bank1 is the passenger's side on the Boxster.
  24. You can talk to anyone, just tell them your are from RennTech.
  25. Your part number is correct except for the M14 at the end, which tells me it is a Pelican number. Don't buy it from them, they a known for swapping out non OEM for the real thing. Get it from board sponsor Sunset Porsche.
