JFP in PA
  1. Welcome to RennTech Check your serpentine belt and pulleys.
  2. Replace them. And out of curiosity, exactly why are you replacing the head gaskets??
  3. An automatic engine will not have a pilot bearing in the back of the crank as the torque converter does not need it, but one can easily be added for use with a manual trans.
  4. Simple: the hill holding system is slipping the clutch to hold the car in position. Rather than burning up the clutch, use your brake pedal and forget this system exists, or expect an early clutch replacement.
  5. I think the very first thing you need to familiarize yourself with is which engines and years will work in the car with the least grief. Different models and years had different fuel systems, different DME’s, some used CAN Bus communications, which your car does not have, different VarioCam systems, etc. etc. While a lot of engines will bolt in, the electronic and fuel system differences will turn the project into Frankenstein in a heart beat. Do your homework before buying anything.
  6. I don't believe the bolt is available separately, only in a complete cable. You may be able to find an aftermarket from someone like Dorman that would fit.
  7. Guys, enough with the weird work around Magiver repairs; if you cannot drill the bolt and remove it, you need to drill out the insert and install a new one, but this time put some antiseize on the fasteners and this will never happen again.
  8. P1502: Throttle jacking unit, spring test, above limit. Diagnostic conditions: Ignition on approx. 30 seconds. Stationary vehicle. Engine not running. Engine temperature greater than 5C. Intake air temperature greater than 5C. Possible fault causes: Throttle part. Diagnosis/troubleshooting: Replace throttle part. Erase fault memory. Perform adaptation: Switch on ignition. Wait one minute. Actuate accelerator pedal. Switch off ignition for at least 10 seconds. Read out fault memory.
  9. Looks like something has happened to your immobilizer under the driver's seat. I would start there.
  10. No, they are not "universal", Porsche used three totally different design bearings. The LN family of ceramic bearings (or IMS Solutions) covers every style Porsche used, but you need to start by knowing which one you need. None of them are interchangeable. Yours could be either a single or dual row style, but the only way to be absolutely sure is to take the car apart and look.
  11. The LN Engineering ceramic IMS retrofit bearings are not sealed, they are open on the flywheel side to allow oil mist lubrication, which is how they stay alive. They also have the largest successfully installed base of any retrofit. The IMS Solution may cost a bit more, but it is the only permanent IMS replacement, and it can is also the only retrofit that can be moved to another engine. The Solution also has the second largest successfully installed base of any retrofit, and is the only retrofit Jake Raby uses in engines his shop produce. I am not a fan of the DOF. Multiple reports (one out of my shop) of valve train noise and VarioCam issues caused by where it sources oil (one of the dirtiest and hottest oil sources in the engine) which promptly went away when the oil line was removed and plugged. It also results in oil flooding the IMS shaft, which is not necessarily a good thing.
  12. Check and make sure your coil connectors are fully seated, this is one of the most common misfire problems,
  13. Some “mayonnaise” like build up on the oil cap is normal and not necessarily a sign of anything. Before giving the car a Viking funeral, do some diagnostics first, such as pressure test the cooling system and leak down the cylinders. You could just have a cracked cylinder head, which is not uncommon and a relatively easy fix. You need more data before making any decisions.
  14. I’ve never done one that way, so I cannot comment.
  15. The fourth stalk can be added.
  16. Simple: The cooling system operates at 18 PSIG; the oil system runs 50-70 PSIG; which way do you thing the fluid would move?
  17. The specialty hose is nowhere near that expensive, but not commonly found in auto parts stores. It uses special barbed fittings that require no clamps to hold the hose on the fittings. And no, you cannot use common auto parts hose in its place, the hose will blow off and spew gas all over your hot engine, resulting in an instant Viking funeral for your car. Either get the correct hose, or buy the entire assembly from Porsche; your car and insurance company will thank you.
  18. That is a specialty hose for use with non removable barbed fittings.
  19. I don't offhand, but board sponsor Sunset Porsche's part website will.
  20. The car actually has several different "computers" that control different functions. The DME should not impact brake light functions, but the ABS/PSM unit might. The 991 618 145 is the electronic parking brake control unit.
