JFP in PA
  1. According to all the related industry literature I've read, and what my shop's legal consul has told me personally, it is a Federally mandated safety system, meaning that if you disable it, or show someone how to disable it, and the vehicle is subsequently involved in an accident, whomever did it (or showed someone how to do it) can be held both criminally and financially liable. And in many states, the vehicle is considered "unsafe" and would not pass local inspection standards. The same thing would apply to removing seat belts or disabling or removing the air bags. Proceed at your own risk..............................................
  2. Just take the bulb out.
  3. You can also look for a shop with a system called an “electronic ear”, which uses six separate noise sensors mounted at various parts of the car that can quickly triangulate an isolate the location of the sound. We have successfully use this system to locate very hard to locate sound sources.
  4. By far, the larger issue with the power steering systems on these cars is heat, not debris. More power steering pumps fail from overheating than anything else. There are a couple of aftermarket companies producing add on coolers because of this issue.
  5. On thing you are not considering is that the control module itself may be involved. If that is the case, you are going to need a sharp tech and access to the PIWIS system.
  6. Welcome to RennTech As noted above, Porsche, like may other OEM's, has restricted what repairs are permitted in the field with their SMG (read PDK) transmissions. Dealer techs are limited to a very short list of things to check, including software updates, before they resort to replacing the gearbox. And, like other brands, there is no plans for an exchange program where the vehicle owner gets anything more than a core value for the used gearbox because it would be impractical for Porsche or any other OEM to tear down and access the level damage to the components in a timely manner, so a value retention program is little more than wishful thinking. Porsche, again like other brands, has also dramatically restricted the availability of parts for these transmissions, partially because aftermarket vendors were purchasing them and then significantly modifying them before selling them to the public. The wet clutch assembly is a good example; Porsche had made it available as an over the counter part number for around $5K (US), but stopped doing so when cars came in with the modified clutches failing and damaging other component's in the gearboxes. Net result is that you can now only find sump pans, filters, and fluids for these gearboxes; anything beyond that gets very expensive very quickly.
  7. Consider the $600 "tuition"......................😉
  8. A belated welcome to RennTech While I hate to say this, you have just joined a lot of other people that discovered the exact same thing: Nearly every aftermarket exhaust system ever made for the 986 has droning issues. Perhaps even worse, before and after dyno sessions have repeatedly also shown that most of these system do not add any measurable level of performance, and some actually lose horse power. All they consistently do is make noise................
  9. No, but it very well could be the "speed gong" associated with the on board computer.
  10. Shouldn't be an issue if you use a good ball joint separation tool.
  11. All of the larger cables are susceptible to this problem. The longer the cable, like to the starter, the worse the problem because their length exacerbates the resistance issue, leading to larger voltage drops. The only real trick to checking each one with either a multimeter or Power Probe unit (Power Probes actually have a specific setting for checking voltage drops, plus the Power Probe's long leads back to the battery make the testing process easier).
  12. 👍Glad you got it sorted. This is exactly why we always suggest running voltage drop tests on the primary cables, they are a known issue with these cars and even Porsche released "new & improved" cables to try and address the issue.
  13. Welcome to RennTech It came from the factory without that bolt. Adding a new one is fine, but not necessary.
  14. Bilstein is the factory strut cartridge supplier.
  15. The bulb chart for the Cayenne list the fog as an H11. What is the exact year and model of your car?
  16. Welcome to RennTech I think you need to check Amazon again: H11 LED bulbs
  17. A long time ago, someone a lot brighter than me commented, "Speed cost money; how fast do you want to go?" 😉
  18. First of all, LN Engineering's IMS Solution is a LOT more than just an oil feed line; the bearing insert is a solid bearing (no moving parts) with annular oil passages just like the almighty Mezger turbo engines used, the IMS shaft is plugged to prevent oil accumulation and the balance problems associated by running the shaft full of oil, the replacement rear IMS flange is coated with a Diamond like coating for strength and longevity, and the oil feed is sourced at the oil filter to get clean, cool oil rather than where some others have sourced it. Perhaps one of the biggest advantages of the Solution is that it never has to be replaced like other IMS retrofits, it is the ONLY permanent fix for IMS related headaches. We have never has any problems with the LN IMS Solution; it simply works, period
  19. That is the steering angle sensor, which contains the clock spring on your car. You need to also be aware the code you have indicates you may have a harness short, which replacing the steering angle sensor may not correct. More diagnostics are required, and if the steering angle sensor is the issue, the new one will need to be calibrated after installation.
  20. Welcome to RennTech Sorry, but the clock spring is not the issue, it is the steering angle sensor: P4420 Possible fault causes - Short circuit to B+ in wiring harness - Short circuit to ground in wiring harness - Short circuit between the signal and ground lines of the rate of turn sensor - Open circuit in electric circuit - PSM(TC/ABS) control unit faulty NOTE: Calibration of the steering angle sensor must be performed on a measuring platform. The steering angle sensor must be calibrated after work has been carried out on the running gear in the area of the front axle. The security code is required for calibration of the steering angle sensor. The security code is read with the PST2 under menu item "Actual values". Calibration is described in⇒ Rep. Gr. 4560; Calibrating steering angle sensor.
  21. These switches are a common electrical fault source in these cars; fortunately they are not expensive and are a common DIY project.
  22. No, it is located on the fuel rail and is a mechanical device. The ignition switch is a cheap electrical part of the key assembly that requires no programing to replace. It is a pain to access, but controls ALL electrical functions in the car: A DIY how to here: How to change 996 ignition switch electrical section Be sure to buy the factory part, aftermarket versions are notoriously bad..............
