JFP in PA
  1. That is because you need to have access to a Porsche specific scan tool like the PIWIS Porsche factory tool; a "global" European scan tool won't be able to access this system, and won't see anything wrong. Some independents have this tool, all dealers have them.
  2. As that engine is a VW variant, a VW shop with the VagCom should also be able to clear it.
  3. I do not believe that the Durametric software supports this function, but you can check with them directly on that. You may need to have a dealer do a code clear with the PIWIS.
  4. Reductant Consumption is the Diesel Exhaust Fluid (DEF) that is used to assist in converting leftover exhaust particles to harmless gases. Are you sure your DEF tank isn't empty?
  5. Then using the basic rule to always go back to the last thing you worked on, the intake plenum.
  6. I would check to make sure you reconnected the coil packs, both completely plugging them in, and not having crossed any.
  7. The correct filter dimensions are 113 MM height, 65 MM outside diameter, 24 MM inside diameter. If the filter they sent you does not match these, do not use it.
  8. It sounds like something is not connected in the door you worked on, which can disable the remote. I would start with checking what you took apart.
  9. You should be running the car one or two bars below the full mark on the electronic display. I would also seriously consider replacing the AOS unit with a new factory unit, they are known for not liking liquid oil in the diaphragm area of the AOS system. I also am not aware of any atmospheric "vent" in the AOS, so check to make sure something is not connected properly.
  10. Glad it straightened out and passed. As I said above, I have seen some of the early cars go some distance before coming around, but you now officially hold the mileage record for this, so congratulations 🙃
  11. Just follow the brown wires. I would start by checking the ground terminal inside the light and see if it has continuity to ground using a multimeter.
  12. Most common problem for this is poor or non existent grounds (usually a brown wire).
  13. Some of the early cars had a real problem getting the IM Readiness test "not ready" status to change without resorting to the PIWIS, even after all the necessary repairs have been completed. I have personally seen cars go more that 200 miles of daily drive cycles before the system switched to "ready", but I have never seen or heard for one going 2,400 miles. I would have to agree with Loren on this one; something is still not right. If the O2 sensor ahead of the cats goes to a straight line zero, or near zero voltage while the SAI pump is running, the system is functional. Before repair After repair
  14. Jake's company is Flat Six Innovations, and has done all of the development work for M96/97 component's for LN Engineering , which is owned by Charles Navarro. Jake does complete engine rebuilds, from mild to wild, and only sells educational materials such as the DVD mentioned, as well as the only existing complete engine torque spec manuals in print, but Flat Six no longer sells any hardware, only complete engines. LN manufactures and sells all the hardware (Nickies cylinder liners, IMS retrofits, piston sets, etc.), and also sells Jakes torque manuals which are excellent reference sources. LN will also provide machine shop services such as installing all new Nickies cylinder liners.
  15. There are just too many things that could be wrong as you really do not know what happened to it during its tenure in the automotive class, or before it even got there, anyone of which could reduce it to a boat anchor in one Hell of a hurry. Always better safe than sorry. Good luck with your project.
  16. You are in the correct forum. Before putting an engine that has been used in class for years, I would be prone to pull it apart to make sure everything is there and no one has dropped a screw or nut into the internals. An engine that has been dormant that long may also have corrosion built up on the crank journals from sitting.
  17. Welcome to RennTech PIWIS is the Porsche factory diagnostics system, and is only available as a lease for $20,000 for the first year.
  18. The 1997 to 1999 Boxsters had two microswitches. One of those two microswitches was the black lever microswitch, which is mounted on top of a bracket that surrounds the electric motor. The bracket is also covered by a black plastic cover with a slot on top of it where the black lever pops up. The electric drive motor for the convertible top is located directly in front of the third brake light, on the rear wall of the convertible top well. This switch stops the electric motor when the top is down. The second switch is on the drivers side B pillar and is the one that turns the dash light off. It is a simple on/off switch that can be tested with a multimeter.
  19. On a 99 Boxster, the top down limit switch is on the rear of the driver's side B pillar.
  20. What year is the car? The red clip is also depressing the limit switch in the top catch, which also activates the sensors.
  21. Welcome to RennTech From the sounds of it, the company in CA sent you a different unit which does not recognize your keys. You need to either get your original unit back from them, or you are about to spend a lot of money for keys, immobilizer, and programing at your local Porsche dealer. These units cannot simply be swapped, they have to be programmed to match the car and keys.
  22. It is either that, or your top limit switch has failed. The red clip only came on cars with the factory hardtop.
  23. Do you have the red clip installed where the convertible top latch normally goes:
  24. Welcome to RennTech The DME MUST be the correct one for the car, and the car’s keys, immobilizer, and DME must all be coded to work together. That will require access to the PIWIS system to complete, after which you will need to address all of the car’s system control modules to get everything successfully talking to each other.
