JFP in PA
  1. Reason I asked is that vacuum leaks almost inevitably cause specific codes to appear, which you have not mentioned. You should also note that your MAF had almost no impact on the car's idle conditions. Do the coils and let us know how it panned out.....
  2. Two approaches: 1) Use a smoke gun; or 2) Use a butane or propane source on slow bleed around the suspected areas. Note of caution: Obviously propane or butane are highly flamable, do it outside on a relatively calm day and you should be fine. And NO SMOKING........ Smoke will get sucked into the leaks with the car at idle, showing you where they are visually; propane or butane will cause a sudden jump in RPM's for the same reason.............. What gives you the impression that you have a vacuum leak? Next time you need Porsche OEM parts, give board sponsor Sunset Porsche a call (toll free), they will probably surprise you with their pricing...........
  3. I'm afraid you went in the wrong direction when you tried to epoxy cracked coil packs, which simply ain't gonna work. They will open up again. Pull the coil packs; replace any they look even remotely bad; if they are all original to the car, you may want to just do them all.
  4. The OEM design uses a composite impeller, which seems to harden and become brittle over time, eventually coming apart and strewing impossible to find or remove debris through the cooling system. These "bits" often plug small passages, leading to hot spots that can cause cracking in the heads or case. Obviously, you want to swap out the pump before this starts. Aftermarket pumps use metal impellers, but these start to wobble, hitting the aluminum engine case wall and damaging it; so you don't want to go there either............
  5. Start by taking it to a qualified body shop and getting an estimate for both the damage you can see, and what is hidden. It is nearly impossible to qutoe an accurate estimate based upon two pictures............
  6. AOS= Air Oil Separator IMSB= Intermediate Shaft Bearing Porsche uses water pumps with impellers made of a synthetic material that starts to bread up over extended periods of time. Aftermarket pumps with metal impellers tend to be shorter lived and tear up the block with the impeller gets loose with wear. Stay with the OEM pump, change it and the coolant at least every 4-5 years. At the same time, change your thermostat to a 160F unit.
  7. The injector and the fuel pump are on different electrical circuits, if the pump shorts out, it has no electrical effect on any of the injectors. You have an issue on the injector circuit, not the pump circuit.
  8. I have to agree with Logray here, if there was a problem with the system, it would throw codes and cause running issues. And knowing how much replacement components cost, I wouldn't be randomly applying voltage to see what happens unless the system is already acting up and throwing codes, you may not like what happens next.............
  9. P1225-1230 are all "short to ground in wiring" codes for the fuel injectors by cylinder numbers, so I am not convinced it is a fuel pump issue. You can quickly check the fuel pump by following the factory test procedure for correct pressure and delivery volume by connecting a test gauge to the test port on the fuel rail; but the codes are going to require running electrical tests on the injectors and the injection wiring looking for a short to ground somewhere in the system...........
  10. You should also note that Porsche lists the specific amount of system oil to expect to have to replace when working on these systems; each compomponent has an amount of lubricant retained that needs to be accounted for during the recharge.
  11. Your oil system is normally running under a vacuum condition of about five inches of water; it has to be air tight.
  12. Why are you even considering shipping it, sounds to me like a lovely weekend drive down the Pac Coast Highway is in your future..................A trip a I have some very fond memories of........................
  13. After you select the vehicle, you should see a page that has a left panel that displays various control modules, if tire pressure is supported on that vehicle, it will be listed there. Click on the "+" symbol next to "tire pressure", and it should display what functions are available for the vehicle. If tire pressure is not listed for the vehicle you have selected, it is not supported in the software version that you have. On page 8 of the attached manual, you will see the list of modules supported on a 05-09 997, which shows the tire pressure function: http://www.durametric.com/Durametric_Software_Instruction_Manual.pdf Not all control modules, or individual module functions are supported for all models and years, each update seems to add more, but everything is not yet supported.................
  14. Both the inside and outside door opening handles are mechanical; not electronic. We have seen door handles that did not work when the mechanisim broke or became disconnected, but that did not involve the window or mirrors. We got the door open by dropping a wire down into the door alongside the window to trip the release.
  15. The only way to reset the service indicator is either a PIWIS or Durametric system, nothing else works..............
  16. Yes. LN's owner openly and quite willingly shares the data he has with anyone that asks for it.......................
  17. If you are going to use the drain plug, you may as well just pull it and drain the system; you should replace the crush washer every time the plug is loosened, which is why dumping the filter was suggested as an alternative..............
  18. Watch which Pentosin, factory specs the CHF 11S (full synthetic) for these cars, and Pentosin tech literature states “If vehicle specifications state CHF 11.S there is no substitute, however, if vehicle specifications state CHF 7.1, CHF 11.S can be substituted.” Pentosin CHF 7.1 is mineral oil based. Pentosin CHF 202 should only be used in 2005 and later Cayennes. A handy Pentosin PDF application guide: http://pentosin.net/...GUIDE3_Rev1.pdf Most NAPA stores now carry Pentosin products................
  19. Not really, there is too much stuff (baffles and air separators) in the way; there was a recent post where an owner tried to do this, could not get the hose down to the oil level, but did manage to get the hose stuck in the engine, requiring a flat bed to the shop where the sump cover was removed to get the hose out. If the engine is slightly overfilled, change the oil filter which will remove a bit less than a quart from the system. If it is way over filled, just drain it and start over again. In any case, do not run the car with excessive oil in it, it can get sucked backwards thru the AOS and smoke like Hell, or even lead to a hydro lock and a dead engine. Fix it..............
  20. If the PSM system is not cycled, a very tiny amount of old fluid may remain in the control unit, but even that will be flushed out by all the new fluid circulation in the system after a change out and normal usage. Just for a reference point, many dealer's do not cycle the PSM system during a system flush; it simply is not necessary unless air has gotten into the control network, and the amount of oil fluid it extracts is not meaningful. Near 60K would be a worthwhile time frame to do the water pump; which also provides a great opportunity to flush out the old coolant, up date to a 106F thermostat, and add the "S" oil cooler if the car is a base model (best $200 you can spend on these cars).
  21. You can use the Motive system on any Porsche; activation of the ABS/PSM system is only needed if you have gotten air into the ABS/PSM control system..................
  22. A TSB does not necessarily compel an OEM to do anything or to repair a car free of charge, unless the system involved was already covered under a warranty, and the warranty on the vehicle is still valid. It is an announcement of a change or update in how something is to be done (e.g.: part # XXX is now superseded by part # YYY), it is not a recall, so the new part will not be installed until the old part needs to be replaced. If the vehicle is out of warranty, all the TSB does is change how they would go about fixing it, but the owner would still have to pay the going service rate plus parts
  23. If it is the pulley, the pulley is one Hell of a lot cheaper than a replacement alternator.......................
  24. I'd also check the alternator to see if it has the de-clutching style pulley, which can also make quite a bit of a racket when it craps out and can leave the alternator unable to put out enough voltage.
  25. I'd wager that the codes are for RKAT values would indicate an overly lean O2 codes for banks 1 & 2 at idle.
