JFP in PA
  1. First, I would not switch gear oils; this subject has been covered many times and the OEM fill is still the best route. Besides, if the gear box had a problem like a bad bearing or the like, new oil is not going to fix it. It sounds like you have an engine/drive line vibration that is showing up in the shifter. Problem is that you need to try to spot the source either by having someone else drive the car while you crawl around and try to find it, or run the car on a dyno and look for it. Sometimes these annoying problems are difficult to find and can chew up a lot of shop time in the process simply because there are so many possible candidates..............
  2. I have to believe that the actual source of the vibration is not the shifter itself as the shifter is bolted to the floor and not solidly attached to anything else. I'm afraid you are in for an "Easter Egg Hunt" to find this one..............
  3. +1 on this, you really do not want to get involved with CAN-BUS headaches...................
  4. I can't wait to have to explain the price quote to change the air filters.......................
  5. I am not sure of the numbers for the tools, but both Samstag and Baum list a "3383 double sealing ring installer tool, 3384 Assembly Mandrel, and 3385 Sealing Ring Installer" for VW transmissions..................
  6. The ABS and PSM MIL lights going on with no related codes is often a battery or charging issue; test the alternator's out put and have the battery load tested.
  7. I can fully understand your frustration; I have also had to wait on multiple occasions to get tooling to complete customer’s cars. A couple of suggestions on tools for Tiptronic transmissions: these transmissions were used in VW’s, Audi’s and Mercedes cars; so start scouring the net for tool suppliers for these marquees such as Baum or Samstag and the like. I’d also be searching enthusiast websites for the brands as well; you cannot be the only one that has looked for these tools, you might even be able to locate reasonable priced used tools………..
  8. As the individual you appear to feel “lambasted” you previously, I have to also agree with Loren on the diagnostics for this code; you do not have a bad cat, you have a small wiring harness or connector issue with the sensor behind the three way on bank 1 (cylinders 1-3). Perhaps if you price out a replacement three way cat, you would see the potential advantage of looking at the sensor wiring…………… As for us operators of the havens out here for “spoiled rich boys”, just remember that we at least know what we are doing.
  9. Obviously, you have a leak. I would not be driving the car until you find out what is leaking and get it fixed, it is not going to heal on its own; and a sudden coolant dump could end up seriously overheating a very expensive to replace engine. Get the car looked at.................
  10. No, I have never had to change out the valve, but I have blown a few out over the years.
  11. It really doesn't seem to make a lot of difference which end you put the air in as long as the line is clear.............. Getting at the line and purge air valve under the manifold is not fun, as you have discovered. I have not seen it written up anywhere other than the OEM service manual set.
  12. At least every year if the miles are low, and change it before it gets put away for the winter.
  13. Thought so; glad to be of help..............
  14. Pretty well from what we have seen. We noticed that fuel contamination of the oil was higher than pre-DFI cars (as expected), so we have shortened the oil change intervals to reflect what we have seen, and will be logging more data to see if we need to readjust. There have been some occasional fuel pump issues (the DFI cars run 120 bar or 1,740 PSI fuel pressures), but because the cars are so new, they have all been warranty problems. I have also heard some dialog about a couple of problems with the front crank bearings, but I do not have first hand knowledge on the specifics what that is about or how wide spread a problem it is. A bigger concern for us is the total lack of diagnostic support for the independents to deal with the PDK, only thing available is the factory PIWIS lease, which remains exorbitant…….
  15. I don't even want to think what the insurance bill would be for that..................
  16. All well and good, but some do not have a choice in the matter; my customer's employer sent him on a multi year assignment in Asia and he did not want to leave his Ferrari and Turbo Cab for his two teenage sons to "warm up once in a while" to keep the oil circulating while he was 12 time zones away. Both cars survived prolonged storage without incident, which is more than I can say for his sons..........
  17. Not to my knowledge, as far as I know, the last time I checked, these were the old and new numbers: 996-105-180-54-OEM Old style IMS tensioner 996-105-180-56-OEM New style IMS tensioner 996-105-051-58-OEM Old style 1-3 tensioner 996-105-186-01-OEM New style 1-3 tensioner 996-105-053-58-OEM Old style 4-6 tensioner 996-105-188-01-OEM New style 4-6 tensioner That said, I think Logray went through this dance and found out that some parts had been superseded yet again so God (and Stuttgart) only knows what the latest parts are. Suggest giving Jeff at Sunset Porsche (board sponsor) a call, he is usually up on the latest changes
  18. I’m afraid I cannot agree with this. For years, we often store cars for some of our better customers for several months at a time (some have winter and summer homes), during which they are never started. I can honestly say that I have not seen any indications of prolonged storage causing any oil leaks in cars that were not leaking before being put away. We had a Ferrari (F458 Italia) sit for over two years while the owner was overseas, no leaks, and started right up after turning the engine over into oil pressure. Been a couple of years since it was stored, car is doing fine as a “fine weather” daily driver. As for “dry starts”, pull either the fuel pump fuse or relay out of the car, spin the engine into oil pressure, put back the fuse/relay, and start it up, letting the engine warm up before driving. We have been doing this for years, never had an issue…..
  19. Actually, some of the 05's also have the "final solution" IMS, which unfortunately cannot be updated with out a total engine tear down............I hardly call that an "improvement"............... And before you ask, no, there is no way of knowing which IMS is in the car without taking it apart.
  20. Really? Then what would you suggest for the cars that have no dipstick?
  21. The M96/97 engine can blow a puff of oil every now and again and be considered "normal", but not every morning. Sounds like you may have and AOS on the way out; try removing the oil filler cap with the engine running. If it comes off with little difficulty, you are fine; if it does not want to come off, you have too high a vacuum in the sump because the AOS is toast.......
  22. Yes, two: A torque wrench (which you also need for the oil plug) and a cup style filter housing wrench (many sources).
  23. Use clean motor oil; we do it on all these we install. Also be sure that after you torque the adaptor in, you also lube the gasket on the new spin on filter with oil, and then only tighten the spin on filter 1/2 turn past hand tight. You cannot imagine how many people try to torque the filter on to the OEM specs, and then wonder why the adaptor comes off with the filter. Put the lubed filter on as described and you will not have that problem..............
  24. You need to also check that all this hardware supports the signal type that your phone uses as European phones use different frequencies and telecom data protocols.
