JFP in PA
  1. Next change, add a magnetic drain plug; cheap insurance and a diagnostic tool all in one.
  2. I checked the cam deviation values. Both are steady at 0 degrees. With that being the situation, most likely it is not the IMS bearing. To find the source, you are going to need to do some digging. Have you pulled the sump cover off yet?
  3. There are a multitude of potential ferrous sources in these engines, but I would pull the sum cover and also check the cam deviation values as well.
  4. Oil temp is the most important of the two. Because these cars use an oil to water oil cooler system, and the fact that oil will always take longer to warm up, the oil temp will always lag the coolant until everything is at full temp. Then the oil will always be hotter than the coolant.
  5. Every time someone calls the shop about removing "a simple broken bolt", I cringe. As Mike noted, this job could go either way: simple or horrific. You never know why the bolt broke; was it the wrong bolt (very common on these water pumps) and it bottomed and also cracked the case before breaking? Was the bolt the wrong thread size/type, and buggered the hole before failing? Basically, you have no idea what you are going to get into until you get there……
  6. the letter is written in a typical Japanese business letter format and Porsche Japan is used in the body of the letter as well as at the top right corner. the phone number in the letter corresponds with Porsche Japan's customer care center. my car has been to the dealer and the contents of the letter confirmed with them. I see the use of Porsche Japan on the letter head, but could you highlight where it appears in the text? Perhaps I missed it.........
  7. Actually, the “official” PCNA position remains that you cannot replace any IMS bearing without splitting the cases…….. What intrigues me is that all “official” letters from Porsche I have ever seen always reference the authority issuing the notification (Porsche Cars, Porsche Cars North America, etc.) somewhere within the body of the text; this one does not.
  8. With the car at idle, try and remove the oil filler cap; if it is extremely difficult, your AOS is dead.
  9. You should be able to get at that and remove it once the water pump is out of the way. Before considering dropping the engine, I would buy either a right angle drill chuck adaptor or a right angle drill (cheap one from somewhere like Harbor Freight), which would give you access without moving the engine.............
  10. Not sure on that one, may want to do a DIY search here to see what others have posted.............
  11. Depends upon which cable is bad, none of them are any fun to change, but you can ususally get at them without dropping the entire engine. Small hands, patience, and getting some things out of the way helps. Not a difficult process, but a time consuming one.
  12. I'd be looking at those cables, we replace them fairly frequently due to high resistance; plus they are cheaper than a new alternator, which still would not work properly on bad cables.
  13. A perfect (e.g.: brand new or totally rebuilt with new diodes, etc.) will idle over 14+V with nothing on. As more stuff is switched on, it starts to load the alternator and pulls the output down until the voltage regulator kicks it back up, but it still would stay in the high 13's to low 14V range. Your alternator sounds like it is OK, but not fully up to snuff as it is dropping the voltage down to near battery only voltage levels (12.4V) with a heavy current draw on it, or 13.5V after the car is warmed up, but without load. 13.5V is right at the bottom of the acceptable range. I would be taking a look at both your power and ground battery connections, looking for signs of corrosion or any significant resistance (use a digital multimeter to test); these cars are well known for having cable end problems. If memory serves, I think there was a TSB on the subject as well as "improved" battery and starter cables released to address the resistance problem.
  14. Guys, aren't you making this just a little over complicated just so you can use your iPad? I mean, a computer talking to another computer just so the data looks pretty? At the end of the day, if the software says "P0491" on a Turbo car, it does not matter if it came from a Cray super computer or a yard sale laptop, question becomes what do you do next to fix the car. With the world going more towards tablets every day, Durametric will follow suit in some fashion eventually.............
  15. I, for one, would love to see a translation from Kanji. If this is correct, and from a legitimate Porsche authority, it would be the first time I have ever seen their acceptance that there really is an IMS problem. Most dealers here will not discuss the matter, and many still claim that it is not possible to update the pre 2006 IMS without disassembling the entire engine (PCNA's "official" position).
  16. Most of the start up related noises in the M96/87 engine family have typically been related to the cam drives. Some have had cam follower (read lifter) problems, but that is a noise that does not always go away. Do a search on the subject of the paddle wear pads, it is a common item that causes noise, cam deviation values out of spec, and debris in the oil filters. Sometimes they even totally fail:
  17. Wear pads on the chain tensioner paddles................
  18. When the system has settled (everything has switched off after about 1 hour), you should see 40-60 mA. Here's a list of what various systems draw when active, and the typical current draw vs. time:
  19. I'm not sure it should do that, it is supposed to only run at start up to aid cold start emissions...........
  20. Simple: The radio draws current to retain your personal settings (saved stations, etc.).
  21. There are several possible sources of small plastic bits, including sealant, cam tensioner paddle wear pads, seals, etc. The most common are the wear pads (black or brownish) and sealant (brown or green). There is no way to confirm the seal condition of the IMS without pulling the trans, clutch, and flywheel out and then pulling the IMS cover after locking the engine down; and at that point you may as well just replace it with the LN unit. I would not be overly concerned about the few bits you have, this is a fairly common find during an oil change.
  22. Changing out the voltage regulator has been written up a couple of times, it is a simple DIY project. The regulator is inside the back of the alternator. In the US, most auto parts stores will also happily test the alternator out of the car for free as well. For a system in good shape, we typically look for idle voltages of 14V or slightly higher. When the regulator or diodes fade, we usually see voltages in the mid 13's or lower, which is starting to get weak when you consider that there is no real current draw (head lights, stereo system, etc.) on the alternator during the test. Often, just switching on a couple of these systems will pull the voltage down further, which is not good.
  23. Most likely a bad casting, or something possibly kicked up and hit it. You can find an exploded view of it in Porsche's PET, along with all the associated parts. I would also suggest locking down the engine as if doing the IMS bearing, and adding the LN oil pump drive for the reason stated. Not a difficult DIY, but it is going to take some time, effort, and specific fixtures (to lock the cams) to do it. The price I used was from Loren's latest list, but if you can get for less at Sonnen, by all means do so. I would also look carefully at the oil pump, they sometimes show some wear depending upon miles, etc.; so this would be an excellent time to update the oil and water pumps, as well as the thermostat while you are in there.
  24. Looks like #996 107 012 58, recently updated to 996 107 012 60 which is the main housing casting for both the oil and water pumps. If it is, this is going to be a fun job to replace............... And it goes for about $465.
  25. Tis the season for batteries to start crapping out. Have the battery fully charged and load test it, also check the specific gravity of the electrolyte. Most auto parts stores will do the load test for free if you lack the necessary equipment.
