JFP in PA
  1. Try 9133
  2. If you are going use anything on the input splines and throw out bearing collar, a light coating of white lithium grease will do the trick.
  3. If the dust collected around the IMS flange is dry, just clean it off and leave the flange alone. If that is all the crud built up in 58K miles, the IMS seals are doing OK.
  4. Quite often,the occasional MIL for both ABS and PSM turn out to be voltage related (weak battery and/or alternator). Get your battery load tested and have the alternator checked as well.
  5. Both LN Engineering and Jake Raby have moved away from direct support of the aftermarket (read DIY), primarily due to the simple fact that even though they supplied fully detailed instructions and specialized tooling, there are simply too many ways to screw up and only one way to do this correctly. And as nature always sides with the hidden flaw, which is this case tends to be those that either cannot, or will not, read and follow directions; they found themselves spending 90% of their time trying to unravel 10% of the IMS installs that went south. So they now tend to be less forth coming on information. Get the correct instructions, read them, and follow them. To do otherwise may be to dig yourself a hole that maybe difficult to get out of…………..
  6. If you intend to remove the IMS cover flange, you need to prep the engine as though you were going to remove the bearing itself (crank locked at TDC, cams locked, tensioners removed, etc.). If you do not do this and remove the cover flange, the shaft will be pulled to one side and you will never get the flange back on again. If the cover flange shows no signs of leakage, I'd leave it alone.
  7. Believe me; they will feel a whole lot different when the metal impeller starts boring a hole in the engine cases, filling the cooling system with fine metal filings that are nearly impossible to get out of the system. Even if you could clean up the mess, and the cases aren’t totally destroyed, the new water pump will not be able to move the coolant effectively due to the damage (the gap behind the impeller is now too large), and the car will want to run hotter than it already does. It is not about OEM vs. aftermarket, but it is about not killing things unnecessarily…….
  8. Then take a look a the Durametric software for Porsche, it won't run off a phone, but it is by far the best sofware available for a Porsche short of the PIWIS system.
  9. Some of the 996's suffered from out of round openings in the case where the RMS sits (Porsche actually developed a tool to check the cases to see if the opening is round or not), which will continue to leak oil after replacing the RMS. Unfortunately, when you find a car with this problem, the out of round condition cannot be fixed, the engine has to be replaced. That said, one of the biggest problems with the new PTFE RMS seal is that people do not know how to correctly install them; they are very susceptible to leaks from something as small as a finger print getting on them, and they should not be installed with any type of sealer (the sealer actually works against the new seal and causes it to leak). There was a very detailed article on the new seal, installation problems and failure causes in "Excellence" magazine a year or two back. It also showed how to test the case opening and examples of cases that will never seal. Black smoke is ususally a sign of an over rich mixture, but it is usually not a fatal problem and would also usually throw codes as well.
  10. You should not need any "prodding", it should slide right out. How are you supporting the engine while removing the gearbox?
  11. The bottle may have hit a wiring connector under the seat and either disconnected it or left it loose.
  12. Probably one of the cheapest sources is Sunset Porsche in Beaverton, OR.
  13. We do not use anything except the OEM Porsche coolant; it has proven to have a very long life (we have seen it go 8 years without issue) and do an excellent job. It is also not all that expensive, and readily available. It is also well known to have compatibility issues with some aftermarket products, which can lead to a gelatinous mess. Most shops are aware of this and stay with what is known to work, and like us will only add distilled water to any car that they do not know for a fact has the OEM coolant in it.
  14. Try 4638
  15. These fuel pumps do not like to be run dry as the fuel also cools the pump itself. As yours is a 2000 model, I would also run a fuel pressure test as running the pump dry tends to pick up any accumulated crud from the bottom of the tank and jam up the fuel filter (yours has an external filter under the car). You may just need a new filter. As Loren has already noted, you may also have a dead CPS, which would also turn off the fuel pump.
  16. Not really, unless the engine blew, but there are a myriad of other things that could do it....................
  17. Very. Porsche uses a composite impeller rather than a metal one for a very simple reason: When the water pump shaft bearing wears and begins to wobble (and they all do), the composite impeller will break up but not do any damage; a metal one on the other hand will do severe damage to the engine case in the rear of the water pump housing. There is also nothing wrong with Porsche's OEM coolant; mixed with distilled water, it will last for many, many years
  18. The M12 bolts are 63 ft. lb; the hex head M10 bolt is 33 ft. lb.; and the M10 multi tooth bolt is also 33 ft. lb. If you do the AOS while the gearbox it out, it is out in the open.
  19. Normally, fuel level calibration is supposed to only needed if the tank and/or sending unit is replaced, or the instrument cluster had been changed. That said, we have encountered instances where prolonged battery disconnection has also led to this type of problem. While time consuming, the procedure is not overly complicated. The tank sender has to be removed, and the tank completely drained of fuel, being careful to get all the fuel in the 4WD cars with saddle style tanks. Once drained, reinstall the sender, return 28 liters (7.3 gallons US) of fuel to the tank, and run the “tank calibration” function in the instrument cluster section of the Porsche computer system and you are done.
  20. 1. Do not touch the case bolts above and below the RMS unless you intend to split the cases for some reason. 2. You will only get about 90% of the coolant out of the car. 3. Do not use any other gear oil but the OEM stuff, we are constantly draining transmissions of "lube experiments" gone bad. Simply ain't worth it. The Porsche product is a full synthetic designed for Porsche, which has no true aftermarket equivalent. 4. Not really, you just line them up 5. Nearly all, if not all of these torque specs can be found by conducting a quick search. In most cases, they are the same as 996 values, but do not use the values for the Metzger design engined cars you mentioned (GT, Turbo), those are different as the engine is completely different.
  21. Cleaning your MAF won’t do much as the oil is behind the throttle body, inside the intake runners themselves. The MAF is upstream of where the AOS connects to the intake system. When one of these AOS failures gets out of hand, it can actually flood the intake with liquid oil, causing terminal hydraulic lock of the motor. Do a search, this has been covered many times on multiple sites.
  22. Depends upon how much oil built up in the intake runners, and how effective you were in cleaning it out before starting the car. Along with smoking, the oil will not be doing your O2 sensors or cats any favors.........
  23. Go here: http://www.6speedonline.com/forums/attachment.php?attachmentid=144330&d=1298219279 it will show you where it hides (helps to rotate the PDF file clockwise after opening).................. You can also find the same info on page 198 of the GT3 owner's manual PDF in the "Documents" tab at the top of this page.
  24. They are stiffing you on a very expensive part, the cars do come with the socket (the missing owner's manual would show you where it is stored in the front trunk), but little else: Another handy device is this aftermarket wheel aligment tool to help you get the wheel back on the car:
