JFP in PA
  1. If it is a car built for the US market, you should see cam movement on both sides.
  2. Could be any number of things; you could still have a coil breaking down under load, which could be eliminated by swapping with another coil and checking to see if the misfire moves with the coil. Bad injector would do the same thing, and could also be isolated by swapping test. You could have a bad valve spring on that cylinder that is hanging a valve open at high RPM. Afraid this is going to require some more digging and using the process of elimination to narrow down the problem.
  3. Consider adding a UV dye to your coolant, then run the car around for a bit. Take a look around the engine bay with a blacklight source and it will become very obvious where the leak(s) is/are.......
  4. To follow up on Logray's comments, he is correct that because the AOS does not carry pressurized oil, an AOS failure intermix is a one way deal, coolant into the oil. Personally, I have not seen this, but a local dealer had an intermix car in, and after dropping the engine and pulling both heads and the oil cooler looking for cracks, discovered a very small crack in the AOS body that was leaking coolant backwards into the oil sump. Needless to say, the service manager was just thrilled over the number of hours wasted trying to track down the leak. So, while not at all very common, it can happen and is worth making note of for future reference purposes when encountering an intermix for which you cannot track down the source.
  5. Normally, we do as well. But some customers want to try other things, which lets us learn how well those products work; in this case, the Denso plugs have done an exemplary job, so they make a viable alternative to the factory plugs.
  6. Thanks Loren,The fix itself isn't a problem, I trust my Mechanic's solution in that JB Welding will get the job done. I was wondering if anyone has figured out how to get around the issue of access to the part and was able to snake the fitting back into the casting without having to drop and dismantle the engine? One of the castings is easier to get to and only requires removal of the alternator. The casting in question requires about 15-20 hours of labor to get to. Because of the number of fittings, and the level of pain to get at them with the engine in the car (if you can), the better approach has been to drop the engine out and do it on a stand. Overall, takes less time, and everything is pretty much out in the open.
  7. Make sure you have the "A" style in Loren's post above, or you will snap off the nozzle trying to adjust it if it is the "B" style.
  8. On a 996, yes, a bad AOS can cause intermix because the AOS has a water passage in it. It is not a common type of AOS failure, more often you start sucking oil into the intake and billowing smoke. But it can happen.
  9. Try 8956
  10. Glad to hear you got it worked out. Sometimes you just have to bit the bullet for the expensive parts of these cars.
  11. We have had excellent performance and life from Denso Iridium's IXU22 in the Cayenne Turbo.
  12. Changing the oil is not necessary unless intermix has occurred. That would be obvious, as the oil (or coolant) would have a “hot chocolate like appearance due to the formation of an oil/water emulsion. If the oil (and coolant) is clear and clean, you are fine.
  13. To my knowledge, there are no published diagnostics for this module other than through the Durametric system or the PIWIS, so I am not sure you will get anywhere testing inputs and outputs as there are alot of CAN bus communications involved........... On the Kessy system, you have 3 interior antennas, and 6 exterior antennas. All four door handles have an antenna in them, and the rear bumper has two. Communication path for Keyless Entry - Opening VehicleTouching the door handle (proximity sensor) leads to sending a key query signal in the area of the vehcleProximity sensor in door handle detects a hand touching it and sends a wake-up signal on the line between the door handle and the Kessy/Immobilzer control unit. Kessy activates a search for a valid key in the area via the integrated antenna in the door handle. The carrier signal is a 125 KHz field that is brodcast by the door handle antenna. The search signal is modulated on this signal. The search takes place only on the side of the vehicle that the wake-up-signal was triggerd on.The key transmitter answers the query from the Kessy using the alarm radio frequencythe key receives the 125KHz transmitted, evaluates the signal and sends a corresponding answer using the alarm remote frequency (315 MHz, USA market) A normal 125KHz signal without the correct requesting vehicle information will not wake up the key; this reduces the quiescent current draw of the key.The vehicle receives the alarm remote key signal through the alarm remote antenna in the rear spoiler.The signal sent by the key received and evaluated by the kessy through the alarm remote antenna in the rear spoiler. The answer from the key contains a vehicle specific data so that only keys assigned to the vehicles kessy control module are woken up and this after the vehicle implemented wake up.The Kessy evaluates the key data and commands the central locking system to unlock via the rear control module.The communication between the kessey and the Rear control unit is via the comfort CAN bus.Communication path for Keyless Entry- Starting VehicleConfrimation within the igniton switch starts the search for a key within the vehicleWhen the ignition key is inserted in the ignition switch and rotated the "S" circuit is actuated and the switch position is detected (KL15, KL50,) This initiates a search for a transponder in the interior of the vehicle. The search takes place at the same time on the outside of the vehicle by the interior antennas.The key answers the control midule request on the alarm remote radio frequencyThe key receives the 125KHz signal, evaluates this and sends an appropriate response via the alarm remote frequency 315 MHz.The vehicle receives the signal sent by the Kessy and releases the steering lock and enables starting in the DME and KESSY.The signal sent by the key is received by the kessy and evaluated. If the key is confirmed as assigned to the vehicle the starter operation is allowed and DME enable signal (via CAN) is sent. The starter engages and the engine starts.Communication path for keyless entry-Leaving VehicleOperation of the door handle micro switch leads to a key query being sent to the outside area of the vehicleThe micro switch is hardwired to the door control module and the door opening signal is sent to the kessy via the Comfort CAN. The kessy initiates a search for a valid key in the exterior area of the vehicle via the antennas that are intergrated in the door handles.The kessy evaluated the key data and controls the central locking system via the rear control module. The key data is evaluated in the kessy and then a command to lock the vehicle and actuate the alarm function is sent via the Comfort CAN. See? All very simple...............
  14. Kind of difficult to diagnose this, I think you need either the Durametric software or a PIWIS scan for more detail.................
  15. Welcome aboard! :welcome: Try 0464
  16. Good point Mike, I had not noticed that the OP did not post fuel pressure and delivery data, so I would at least check that before doing anything. And if I found no fuel pressure during a check, I would bridge the terminals on the fuel pump relay to force the pump to run and check it again to be sure it is not something else like the relay or the CPS, which causes the DME to shut the fuel pump off when the crank position sensor dies
  17. Sometimes spending a few extra bucks can eliminate having to do a nasty job twice............. :jump:
  18. But is it an OEM quality pump (VDO), or a Chinese knock off? We have changed out several short life aftermarket pumps that did not make the grade…………..
  19. They probably already were bad; the multiple moisture exposures just pointed that fact out. We often find coil packs with small cracks and often electrical tacking marks as well, so this is nothing unusual.
  20. Never said they were cheap. Shop around, but I think you will find Sunset to be competitive.
  21. Except for physical damage, these hoses are pretty long lived; we have a couple customers with over 100K and 200K miles on the factory units. If they look bad, have soft spots or blisters, change them out; but as others have noted there are a lot of hoses in these cars, and you basically need to disassemble the car to get at them all.
  22. I don't understand where he is getting his data from, but unless physically damaged in some way, they are pretty long lived.....
  23. Seems a bit low, I would strongly recommend getting the battery load tested.
