JFP in PA
  1. And, if you have replaced any componentry, you may need to adjust the oil level in the system as well. Porsche has a table that lists the proper amounts of PAG oil to add for each component replaced.
  2. Posted results When we get a car with a suspect cable problem, we disconnect the cable and check it for internal resistance using a digital multimeter. These cables should have no resistance; if we find any, the cable gets replaced. This is a fairly common problem. You can do the same thing by measuring voltage drop to get to the same place, but you need to be cautious because that method cannot pinpoint which cable is the problem if the harness has more than one cable or a connector in it. So comparing the results from the Durametric to the voltage reading at the battery + terminal won't offer confirmation ? As an update, checked the Durametric voltage at DME and it reads anywhere from 12.96 to 13.12 with AC, Radio and front cooling fans and engine at idle. Voltage at battery + terminal under the same conditions varied between 13.10 and 13.56. Engine was fully warmed up. A system that is in good shape (battery fully charged, cables good) should show a static voltage (engine not running) of around 12.6V at the battery. Engine running on a system in good shape, you should be seeing 13.5-14.5V at the battery. At a minimum, your voltages are a bit low. Check the system again, engine running but everything else turned off; if the Durametric voltage is not in the 13.5-14.5V range either there is an alternator/regulator problem, or one or more of the cables are high in internal resistance.Posted results, with everything I could turn off turned off, in above post. Many thanks for your help. The voltage readings you listed where most helpful and the first time I have seen them listed together presenting a much clearer undersanding of what I should belooking for in the results. As noted will post retest results once I install he new harness. Elimination of my starting issues further supports the fact that this issue is not limited to the '05-'06 models. Hot starting issues associated with internal cable corrosion are unfortunately all too common across several model years; Porsche actually released updated cables with improvements designed to address this exact problem. While the replacement cables are not all that expensive, the confined spaces they run through make replacement a bit of time consuming but otherwise not difficult job.
  3. Because they still carried the dual row bearing, which was the least failure prone style.
  4. It would probably be best to flush and bleed the system last to minimize any chance of problems. Be sure to properly bed your new pads and rotors when everything is done. Which fluid you use is important; we strictly use the ATE brand at the shop due to its high boiling points and excellent performance history. Look around a bit, a lot of retailers that focus on the performance market carry it, and it is readily available online as well.
  5. I think he is referring to the rattle and noise you get after switching to a single mass lightweight flywheel, which is a common complaint, and an indication of the loss of dampening.
  6. When we get a car with a suspect cable problem, we disconnect the cable and check it for internal resistance using a digital multimeter. These cables should have no resistance; if we find any, the cable gets replaced. This is a fairly common problem. You can do the same thing by measuring voltage drop to get to the same place, but you need to be cautious because that method cannot pinpoint which cable is the problem if the harness has more than one cable or a connector in it. So comparing the results from the Durametric to the voltage reading at the battery + terminal won't offer confirmation ? As an update, checked the Durametric voltage at DME and it reads anywhere from 12.96 to 13.12 with AC, Radio and front cooling fans and engine at idle. Voltage at battery + terminal under the same conditions varied between 13.10 and 13.56. Engine was fully warmed up. A system that is in good shape (battery fully charged, cables good) should show a static voltage (engine not running) of around 12.6V at the battery. Engine running on a system in good shape, you should be seeing 13.5-14.5V at the battery. At a minimum, your voltages are a bit low. Check the system again, engine running but everything else turned off; if the Durametric voltage is not in the 13.5-14.5V range either there is an alternator/regulator problem, or one or more of the cables are high in internal resistance.
  7. The O2 sensor readings were for both pre- and post-catalytic converter. Attached is a screenshot of the O2 sensor readings from Durametric when warm. The low values seem to be lower today than yesterday. Getting cold numbers is a bit more difficult due to working in the morning, but I will try to provide those when I can. Unless you mean "Oxygen sensing cylinders 1-3" and "Oxygen sensing cylinders 4-6", I am not seeing how to measure the O2 sensor voltage of a specific bank. And the oxygen sensing reading for cylinders 1-3 is 1.01 to 1.05 and for cylinders 4-6 s 0.99 to 1.02, which seems out of the sweet spot if that value does reflect an O2 sensor - unless maybe the value is scaled so that 1.0 is 14.7:1...? Sorry about that. My car is a 1999 Carrera C2. It does have a fuel pressure regulator on the fuel injector rail. Looks like I need to order a fuel pressure and vacuum gauge. Regarding the MAF, darn. I didn't think so. It's never the relatively cheap part that is easy to access... So if it does turn out to be fuel injector related, what are the odds that sending the injectors to be professionally cleaned would fix them versus having to replace one or more injectors? Thank you! Yes, the injectors can be refurbished, there are a lot of shops that do this, so look for one in your area.
  8. You also need to do a search on problems associated with the use of single mass flywheels on these engines. Porsche even release a tech bulletin about not using them due to loss of torsional and harmonic dampening, which is what the dual mass is there for. Some engine builders will not use them unless the engine is first properly rebalanced. I know someone will chime in and tell you that they have had one for years and not had problems, but I can assure you that is not always the case, and the results can be disasterous. This is what happened to a 3.6 X51 engine that was not rebalanced before using a light weight single mass flywheel, if you want to read more about it, start here: http://www.flat6innovations.com/index.php/broken-crank
  9. When we get a car with a suspect cable problem, we disconnect the cable and check it for internal resistance using a digital multimeter. These cables should have no resistance; if we find any, the cable gets replaced. This is a fairly common problem. You can do the same thing by measuring voltage drop to get to the same place, but you need to be cautious because that method cannot pinpoint which cable is the problem if the harness has more than one cable or a connector in it.
  10. The DME monitors the output voltage of the alternator, should be in the actual values section. What exactly are you trying to accomplish? You mentioned changing cables; if you are having issues with the charging system involving the cables, you should be looking at resistance, not voltage, as corrosion inside the cables causes the resistance to rise, restricting current (amperage) flow. This is often difficult to catch by monitoring voltage, but easy to see when looking at resistance. And you cannot read resistance off of any scanning system I am aware of, you need a multimeter and access to the cable, which means pulling the alternator if you cannot get behind it.
  11. Well, you could hook it up to the Durametric software and read it.
  12. The P1123 Code "Oxygen Sensing adaptation range 1 Cylinders 1-3) Lean limit" is referring to the fact that DME has reached its limit is trying to lean out that bank and the car is running too rich as the result. Usual two suspects are either high fuel pressure or a leaking injector(s) on that side. As you have not identified your year or model, in some cases is can also be a defect fuel pressure regulator on the injector fuel rail, depending upon the year, as some models do not have the external regulator. There is little probability of the MAF being involved in this issue. Step number one should be to get a fuel pressure reading off the test port on the fuel rail, should be 55+/-3 PSIG engine off; 48+/-3 PSIG engine running. If it is an early car with an external fuel pressure regulator, pull the vacuum line off the regulator and read the vacuum on the line, should be around 15 inches of vacuum. Checking the individual injectors is a bit more difficult; for a DIY, probably the easiest approach is to pull all the plugs on that bank and check their color. If one or more are overly dark, those would be your suspect injectors.
  13. If you buy an LN Engineering magnetic drain plug, the torque specs are 19 ft-lbs. Very important to remember or you will be rewarded with your "following the Porsche torque specs" diligence with the privilege of starting your own "how to remove stripped drain plug?" thread. :blink: Wrong! Read the Porsche Service Manual. The torque specs on the oil filer is 19 ft-lb. The torque on the oil drain plug is 37 ft-lb. Perhaps we need to drop a note to Charles Navvaro as his website states the following: Uses O.E. sealing ring Porsche part number 900 123 106 30. Torque to 19 ft/lb. Replace sealing ring every time you re-install the drain plug. Could just be a typo......
  14. Yes, the chain rails between the cams are a good option. You will also need specific cam holding tools to remove the covers with out risking damage.
  15. Almost correct, the cam cover has to come off: I think the two fasteners that the OP may have been referring to are the seal O-ring cover that bolts to the cam cover.
  16. Codes are saying you are running overly rich, as your fuel pressure looks OK, I'd look at the fuel pressure regulator to make sure it is not acting up. The Durametric system can be a bit quirky, after selecting your engine option, try the other ABS and cluster options, sometimes they work.
  17. Correct on the two fasteners. Believe it or not, Porsche has a special tool to get them out; but we use a small set of channel lock pliers to pop them loose. Just don't get overly ambitious as the cam cover is irreplaceable, so you don't want to damage it.
  18. Whose manual is it (Porsche, aftermarket, etc.)? My OEM looks just like what Loren posted and if you read item #6, it tells you to fill the trans via the charging port: Note: To undo and tighten the cap nut for the charging valve, counter with an open-ended wrench. 5. Screw off cap nut for the charging valve. 6. Screw connection hose No. 9507/1 A onto charging valve. Top up with ATF via the charging valve until surplus ATF runs out at the control screw bore. Note: All instructions and test conditions for "Checking and topping up ATF fluid" must be observed for further work steps>>> 37-1 "Checking and topping up ATF (as of model year 2002)". The Bentley manual also says the same thing.
  19. I have no idea why, are you sure the manual is correct for the car and year?
  20. Good, then we are making progress. Look at the smaller insert in the upper right of this photo: In that inset photo, the red arrow is pointing at the A or drain plug, the blue arrow is pointing at B or the overflow port. Now if you look directly to the right of the red arrow, you will see a larger hex cap (looks like and AC service port cap) which is covering the charging port, where the line to fill the trans connects.
  21. OK, as that is the way we have been doing 2002+ 996 Tips since they first showed up, then let's start again with the basics: What year and model is the car?
  22. You do not fill thru either A or B, on a 2002 and later car you fill it via the charging valve (looks like an AC charging port at the corner of the trans sump) using a special hose with a fitting for the charging port until the fluid comes out of port B with the car running and fluid at around 40C. If you have aces to a Bentley manual, look at page 37-12 and all will be revealed.........
  23. It is possible, but with that little wire left you may be better off just replacing it with a new one. The two screws are all that is holding it in.
  24. There is a special tool, but you don't really need it if you follow Mike Rentner's really good set of DIY Litronics install instructions that have been around for a quite a bit, but may help to clear things up: http://www.pelicanparts.com/techarticles/box_litronic/litronic_pg1a.htm
  25. OK, the P0175 is often a code often caused by something as simple as the fluid level being a little too low; are you sure the fluid level is correct? If the fluid level is correct, the speed sensor in question is mounted to a conductor plate on the top of the valve body in the transmission: Thanks.... Hi JFP, the thing is that the dealer replaced transmission and differential fluid in January using their highly precise method for doing so....by the book so as to speak, and I have tile flooring in my garage and would have seen leaks....so I'm thinking the valve body may be shot - hopefully it doesn't mean a full rebuild or reman unit :- I would still check the fluid level first, it would not be the first time I've seen a car right out of the dealer's that was low on fluid. Checking is a bit convoluted due to where the transmission is, but can still be done as a DIY; do a search in the archives for servicing the Tiptronic, it has been written up more than once. The speed sensor itself may be the only thing that needs changing, but unfortunately that entails removing the valve body to get at it. Not hard, but not fun either. JFP: dealer called back. The fluid is ok, it appears to be speed sensor which is in the valve body or the TCU or both. They said valve body is a $2500 or so part. Now the problem is that I don't think they can just change the speed sensor - appears they'd replace the whole valve body. If I were to just replace speed sensor n3, where can I buy such a part and how much would it cost? If i were to have to replace entire valve body do you know where I can buy it and cost? Thanks Both items are Porsche parts, suggest contacting Sunset Porsche in Beaverton, OR (503.641.8600) for pricing. VW and Mercedes also use the same parts as well. ok - called Sunset Porsche, they are saying that the valve body can be ordered, but that there are other parts like solenoids that can be ordered separately - he couldn't find an item called a speed sensor or rpm sensor on the transmission. Do you by any chance have an idea what the part number for just the speed sensors could be, or am I better off just buying the valve body? thanks No, I don't have the part numbers at hand, but I did do some research and found this: P0715 Speed comparison n2 with n3 implausiblePossible cause of fault- Short circuit to B+/ground/between wires or open circuit- Speed sensor n2 or n3 faulty- Tiptronic control unit faultyNote: The speed sensors are housed in the electrical part of the hydraulic control unit. If a speed sensor is faulty, the complete electrical part of the hydraulic control unit must be replaced. So it looks like the entire electrical section, often called the conductor plate, has to be changed out as the sensors are not available by themselves anymore. This device sits on top of the valve body, but is separate from it. You may want to now go back to Sunset and ask about the electrical section and see if that comes by itself or if you need to buy it with the valve body.
