JFP in PA
  1. Rear main seal, IMS upgrade, water pump, oil fill tube, 160F thermostat, new AOS at a minimum.
  2. Start by checking your fuel pressure and delivery rates, and when was the last time you changed the fuel filter on the car? Another possibility is a crank position sensor on the way out.
  3. Silver_TT is correct; both ABS and PSM MIL lights are not uncommon when one of these cars goes into a low voltage situation, and they typically clear themselves once the voltage is back up and require no further attention.
  4. What you need to do is have the car diagnosed on a Porsche specific system; swapping around the sensors is more effort than it is worth when you can plug in a computer and see how they are doing. Get the car checked.
  5. P1324 is the big one here, that indicates that the intake cam on Bank 2 timing is below the lower limit, meaning the cam is out of time. One problem is that many "generic" OBD II scanners spit out ghost codes along with the real ones. If the car was in my shop, I would run the cam deviations values (spec is +/- 6 degrees) to see where they really are. That requires the use of a PST II, PIWIS, or the Durametric diagnostic tools to accomplish. Either a cam position sensor has gone bad, or more likely one of the VarioCam components on that bank is on the way out. All of these systems can test the VarioCam components on the car as well. Because you do not know if the problem is a major shift in cam timing or not, I would not be driving the car at all, and would suggest flat bedding it to a shop with the correct tools to do the diagnostics. If the cam really has moved beyond the lower limit, you could be only a few degrees away from piston to valve contact, which will be fatal.
  6. Let's start with the basics: Model year and car model, engine type, and general location of the photos.................
  7. When the car spins over, is it making any attempt to start, or just spinning over?
  8. While you did not state the actual codes, the one for the cam timing being out on bank 2 is worrisome. Please post your actual codes and the system used to obtain them (Durametric, PIWIS, PST II, OBD II scanner, etc.). The individual bank solenoids can be tested in place with the correct diagnostics tool.
  9. How are you testing the plug wires as they are all hidden inside the cam covers? Are you just testing for voltage going to the coil packs or are you actually testing the high voltage side of the coils for discharge? I am trying to understand your problem by understanding what you have tested and how...........
  10. How did you determine it has fuel pressure and spark?
  11. You do realize that you are asking a question on a thread that has been dormant for 4 years................
  12. This happens to be from a VW Tiptronic, but the principals are the same: And this is the actual valve body out of a 996 tip:
  13. You are "hijacking" a thread that has be dormant for nearly seven years, so don't expect a quick response. A quick and obvious solution is to remove the LED bulbs, they have a different resistance than incandescent bulbs and often cause issues when used on circuits not designed for them.
  14. It sounds like it may be one of these "hidden" installs where there are sensors in the front and rear of the car that need to be wired to the inside receiver.
  15. It is much like building a ship in a bottle; patience is the critical tool.
  16. I always go back to the last thing touched when codes sudden show up. As mentioned, P0455 is the "large leak" EVAP system code, which obviously includes the gas tank; one neat trick in this department: Jury rig a rubber stopper or something similar to replace the gas cap (we actually took a new cap, drilled and tapped a hole in it that we then screwed in a threaded fitting to connect to a vacuum gauge) and check for a steady low vacuum on the tank with the car idling. If it is intermittent, or non existent, or worse yet there is pressure, there is a leak somewhere that has to be tracked down. (Emphasis added) You can still have a loose connection on the O2 sensors as a vacuum leak is more prone to cause the car to throw overly lean O2 codes rather than a poor electrical connection code. Simply ingenious! Thanks for the tip. I'm going to add it to my limited diagnostic bag of tricks! :thankyou: Regards, Maurice. I have my moments; also did something similar for the oil fill to check the AOS.
  17. Um, I am familiar with the oil seal arbors that Sir sells for Porsche, and to my knowledge they do not have the correct one for the PTFE RMS seal. Which arbor number did you purchase? I have the P250 tool. The seal fits nicely on the tool. That may be, but I think that tool is for the seal design prior to the PTFE seals used now; if it is, it will set the seal at the wrong depth, which is critical. I think you need to check with Sir to be sure it is machined to set the PTFE seal.
  18. Um, I am familiar with the oil seal arbors that Sir sells for Porsche, and to my knowledge they do not have the correct one for the PTFE RMS seal. Which arbor number did you purchase?
  19. Pedro, correct me if I am wrong, but doesn't your flow diagram show the oil to the DOF adaptor passing through the oil galleys on one cylinder bank before it reaches the adaptor in the lower portion of your diagram?
  20. That is actually the point of the discussion, some use "just filtered oil" while others do not. And, perhaps more importantly, where is the oil coming from, and what other component's may be suffering as the direct result. While I do not want to encourage an online pissing contest between the designers of these systems, I do want car owners to stop and think about how these different designs function before spending their hard earned cash.......
  21. Do you know if this is a common problem with Boxsters? I plan on taking it to my local porsche independent mechanic to have it checked. When you say expensive, how expensive are we talking about? Thanks for your reply, Gilbert Not common, but not unheard of either. The throttle body is about $300 or so at retail, the throttle pedal potentiometer is in the $100 or so range. You need to know which one is the problem before swapping out parts.
  22. While continuous lubrication of the IMS bearing appears to be an attractive idea, you need to be careful here, there are considerable differences of opinion on where you can draw oil from to lubricate the IMS without causing other potential problems. Some of these opinions are based upon several years of testing different oil source locations and evaluating their impact on other engine components as well as the IMS bearing itself (e.g.: valve train components, etc.), other opinions are based upon considerably less real world data. Most people do not realize that the IMS bearing in the M96/97 is actually partially submerged in engine oil when the engine is not running, and that there is considerable oil volume that splashes up into the IMS area as the car goes through its normal running conditions. This is why many astute engine builders have recommended removing the rear seal on the 2005 and later engines as an option to extend the OEM bearing's life expectancy. Many owners of have followed this pathway with success. While pushing pressurized oil seems a logical idea, over the past several years, multiple people have experimented with the idea using different sources for the oil, and running the design for prolonged periods, both on the dyno and installed in cars. Some these experiments were obvious dead ends, while others were more promising. While spraying oil directly onto the rear of the bearing should offer both cooling and lubrication, unfortunately some methods of oil supply demonstrated the law of unintended consequences of new ideas. Some resulted in more dirt and debris getting into the bearings (which is not good), as well as accelerating wear in the areas of the engine the oil is sourced from (the valve train areas of these engines are already weak in the lubrication area, which is one of the reasons that abnormal lifter wear is common in the factory engines). Do some in depth research on this subject, and talk to the people that have done the development work before settling on the direction you choose. Just because something is new does not necessarily mean it is better...........
  23. These cars have an electronic throttle set up, so it is often hard to access what the actual outcome is of a physical depressing of the pedal. The system uses a potentiometer on the pedal to send a signal to the DME, which responds by moving a servo motor at the throttle plate. Either could be the source of the issue, but because they are both expensive, you need to run diagnostics to determine what is going on. Best first move would be to hook the car up to a Porsche specific scanner (PIWIS or Durametric) and look at the actual throttle position data in response to throttle pedal movement. You can also scan the car for pending codes related to the egas system at the same time.
  24. The old manual sets (986, 996, etc.) ran 13-15 volumes before they stopped printing them. The OBD II manual alone sold for over $1,300. The last Boxster set printed was 14 volumes and hundreds of pages, plus updates, diagrams, etc.. As I said, I do not believe that your model year service data exists in print, Porsche (like most OEM's) stopped printing all technical information around 2005-2006 and went electronic subscription only. The object of "per page" subscriptions is that they cost less than a $5K+ yearly access expenditure for whenever you need it.
  25. Durametric is a little strange when it comes to alarm system diagnostics. Some model and years seem to have complete access, and other years or models have limited or partial access. Unfortunately, there does not appear to be an obvious pattern, you just have to plug it in and see what happens. I've read that Porsche may have sourced the modules in the cars from different sources (read manufacturers) which could be part of the issue. When Durametric suggests you create a file and send it to them, by all means do so. The system is a continuous "work in progress" as they try to figure out what Porsche has done now, so they are always playing catch up to some degree, and the data you send them is helping not only you, but every other user out there as well.
