JFP in PA
  1. Ummm......How about "Welcome to RennTech"! :welcome:
  2. Sounds like you may have a vacuum leak. I would recheck everything you did when you removed the throttle body.
  3. When you've got that much money, you can be as irritating as you like.............. :eek:
  4. Well, if it makes you feel any better, the Special Toll 9609 would not have worked anyway, you needed Special Tool 9699 and 9699/2 to do the new style seal: These are hard to find items even here, and will set you back over $500 (US) if you could find one. Get the plastic pipe coupler...........
  5. This has been covered before, but it can be done using a 4" diameter plastic pipe coupler (has a ridge half way down the inside that the old flywheel bolt heads can rest on, then tighten slowly in a crosswise pattern to pull it in evenly.) The trick to getting the new design PTFE seal to work where the older design did not is being absolutely scrupulously clean, not even finger prints on any parts, and no sealant of any kind. You also have to install it at an unusual depth, 13MM from the flywheel mating surface of the crank, not 14MM. Wonderful! I've considered to fabricate a tool like this (did a crude sketchup), which is a bit wider than 4" but still fits. Don't know how to thank you enough JFP! You are not the first to attempt this:
  6. This has been covered before, but it can be done using a 4" diameter plastic pipe coupler (has a ridge half way down the inside that the old flywheel bolt heads can rest on, then tighten slowly in a crosswise pattern to pull it in evenly.) The trick to getting the new design PTFE seal to work where the older design did not is being absolutely scrupulously clean, not even finger prints on any parts, and no sealant of any kind. You also have to install it at an unusual depth, 13MM from the flywheel mating surface of the crank, not 14MM.
  7. The clutch lubricant is circulated to a oil/water cooler on the side of the gearbox, the controls are internal to the PDK control computer. The clutch oil pump is inside the bell housing, not unlike an traditional automatic transmission: Porsche manual vs PDK cutaway.jpg Changing the clutch oil flow requires activating a valve inside that pump, hence the use of the PIWIS to control it. Nice picture JFP. Where are the solenoids that operate the gear box and clutches?? I hope they are easy to get to as they are the most likely parts to fail. It is cool that the gear boxes are almost identicle! I wonder how it gets itself into first gear in sub zero temps? The first shift at -10 degrees is like rowing through molasses. Does it go to bed in first gear? A lot of the control system is internal to the gearbox and operated remotely by the computer, which is why a lot of independent's are kind of stuck on servicing the transmission (at this time, there is not an aftermarket system such as the Durametric that can even do the clutch oil change out, which happens with twice the frequency of the gearbox lube itself, due to the necessity of a PIWIS system). The transmission is decidedly not technician friendly, and the dealers are not going much beyond changing both oils and re-flashing the computer before swapping out the unit for a replacement when problems occur. Because the trans is basically an "automated" version of the manual 7 speed, I think the trans stays in whatever gear it was shut off in (probably to facilitate the new auto start/stop function), but there is no real way of telling as it seems to go through a series of diagnostic checks as the car starts. Here's one out of the car, and there really is not much to see: What is that Blue knob at the top rear on the driver's side? What is that black knob down low a bit to the front with the diagonal grooves with the sheet metal bracket under it?? In general how are these boxes holding up? I'm hoping that they have most of the bugs worked out by now. Any weaknesses I should know about? I assume when you send these back they send you a rebuild and give you a core charge? How much?? I believe it is the clutch oil fill. Some of the early cars had software issues that caused surging complaints, but they have updated the system. Because these are an offshoot of Porsche Motorsports, these things should be very strong. It's hard to get the dealers to give you straight numbers, but what I have heard is that the twin clutch unit (parts only) is $5-6K, and a replacement transmission, sitting on the ground in a crate, is about $15-17K. I have not heard any core swap numbers. As you originally asked about the control system, thought you might enjoy this video of Jay Leno taking one apart and then beating Hell out of a car with one. Be sure to note what looks like an over sized valve body on the table by the opened up trans; that is your control system: http://www.youtube.com/watch?v=R0t2xia8xxs&feature=player_embedded
  8. The clutch lubricant is circulated to a oil/water cooler on the side of the gearbox, the controls are internal to the PDK control computer. The clutch oil pump is inside the bell housing, not unlike an traditional automatic transmission: Porsche manual vs PDK cutaway.jpg Changing the clutch oil flow requires activating a valve inside that pump, hence the use of the PIWIS to control it. Nice picture JFP. Where are the solenoids that operate the gear box and clutches?? I hope they are easy to get to as they are the most likely parts to fail. It is cool that the gear boxes are almost identicle! I wonder how it gets itself into first gear in sub zero temps? The first shift at -10 degrees is like rowing through molasses. Does it go to bed in first gear? A lot of the control system is internal to the gearbox and operated remotely by the computer, which is why a lot of independent's are kind of stuck on servicing the transmission (at this time, there is not an aftermarket system such as the Durametric that can even do the clutch oil change out, which happens with twice the frequency of the gearbox lube itself, due to the necessity of a PIWIS system). The transmission is decidedly not technician friendly, and the dealers are not going much beyond changing both oils and re-flashing the computer before swapping out the unit for a replacement when problems occur. Because the trans is basically an "automated" version of the manual 7 speed, I think the trans stays in whatever gear it was shut off in (probably to facilitate the new auto start/stop function), but there is no real way of telling as it seems to go through a series of diagnostic checks as the car starts. Here's one out of the car, and there really is not much to see:
  9. This "flushing" is boiling them out in a pan of Marvel Mystery Oil, right? I'm waiting for warm weather so the rest of the car is warm compared to the IMSB from the freezer. If they are nasty we put them in a pan of very warm Mystery oil or in an ultrasonic cleaner; otherwise we just flush them with clean oil.
  10. Have they checked the crank position sensor? A bad one will stop the car from starting.
  11. Step 16 is a fix for a loose bearing or out of round shaft. The bearing itself should be a press fit, hence the removal and installation processes. But sometimes you find really loose bearings in cars, which is when you would use the Loctite. The bearing goes in dry; if cold enough, no lubricant is really needed.
  12. While you may not have noticed it, when you were prepping for the extracting the old bearing, you pulled the shaft slightly towards the flywheel. When you hammered in the new bearing, it moved slightly the other way, but it will straighten itself out.
  13. That looks fine. The entire IMS shaft can move back and forth a bit, so don't be overly concerned about that. This could be completely bogus and I am not going to do this, but feel free to wonder the following.. When you tap new bearing in, IMS moves slightly away from the flywheel side. After we torque IMSB stud nut on step 22, IMS cannot move back to its original position anymore. However, before step 22 when IMSB flange is secured but IMSB stud nut is still loose, why don't we reinstall tensioners and perhaps even remove cams + crank lock and rotate engine a few times to let IMS, chains and paddles settle better before continuing with the step 22? Once again, I do not suggest that anyone tries this, I am simply trying to learn something :lightbulb: It feels a bit strange to move IMS a bit (manually) and then secure it to such place. Can be that it is simply the price that one has to pay when doing bearing upgrades. You could do that, but it is not really necessary. First of all, the IMS shaft will relocate itself just fine all by itself when the engine starts to turn over for its first restart. Secondly, we normally flush out the hydraulic tensioner's if they are not being replaced, and then hand pump them in clean oil just prior to reinstalling them with new sealing washers, so they have some tension on them at first start. Third, we normally pull the fuel pump relay out (so that the car won't start), and then spin it over with the starter until it develops oil pressure, which also allows everything to settle. Then, after one more inspection for anything that was missed, put the relay back in and light the car off.
  14. We have seen a lot of people try this trick, and quite plainly it does not work. Xmac is on the money when he notes that by the time you see the ripped tie rod end boot, the damage is already begun. Dirt, water, road salt, and whatever else happens by has already gotten in there and is slowly started chewing the unit to death. The time you would spend trying to tape up the joint and lubricate it would better be spent replacing it.
  15. The oil fillers do crack in all sections, with the center section failing most often.
  16. Yes, the differential in inside the gearbox (see the cutaway photos in my post #10 above). Except for the gear selection controls, the gearbox is very similar to the manual seven speed gearbox, but the larger issue is changing the clutch oil (which is different) and requires the use of a PIWIS system to accomplish.
  17. That looks fine. The entire IMS shaft can move back and forth a bit, so don't be overly concerned about that.
  18. So a PST2 or PIWIS and not the Autologic system that my indy uses? It is impossible for me to know if the tool your indie use is accurate or not, but based upon our experience with the results of some other highly considered diagnostic tools which were supposed to be able to do this calibration and did not, I would suggest caution on how the calibration is done. The PST II, PIWIS, and Durametric a known to be able to do it, other systems not so much. What is known is that your tank was not completely empty before running the test, and from your memory they added 13L of fuel, which would appear to indicate that there may have been more fuel in the system than should have been for the calibration, and which may have thrown it off. I'd suggest that your indie rerun the calibration with the tank completely dry, 12L of fuel, and their Autologic tool; the outcome should answer your question.
  19. I stand corrected. Further research had demonstrated that Loren's information is correct, and I should also note for future reference that multiple information sources, including Bentley's 996 manual, have proved to be incorrect on this point. The publisher has been notified of the correct information.
  20. It is also for the C2, you just have to be more careful with the C4 because there is more places for residual fuel to hide due to the unusual tank shape. Plus the two tanks are close enough in capacity (the manual says 16.9 gallons for the C2, 16.6 for the C4) that there should be no real difference. 28 liters is the correct fuel quantity, and you also should not be using anything other than a Porsche specific diagnostic tool to do this, we have had to redo several that were supposedly done correctly with another system, only to have problems. Done correctly, the cars were fine.
  21. The factory calibration procedure is to use 28 liters (7.3 US gallons), not 13 liters. It is also important that the fuel tank is completely empty before starting this procedure. "Calibrating fuel level sensor system 1. Disconnect the battery and cover terminal or battery. 2. Remove cap over the fuel level sensor system. 3. Remove fuel level sensor. Removing and installing fuel pump. 4. Using a fuel extractor, completely drain the fuel tank through the fuel level sensor opening. 5. Make sure that the two recesses on the left and right hand sides of the tank are emptied completely. 6. Reinstall the fuel level sensor and, with "ignition off", fill the tank with exactly 28 liters of fuel. 7. Perform tank calibration with the Porsche System Tester 2 (PIWIS or Durametric): - Select vehicle type (911 Carrera) - Select control modules - Select instrument cluster - Select menu item "Tank calibration" - Confirm calibration 8. The fuel level sensor system has now been calibrated."
  22. As long as the coupler had sufficient ridge to catch the flywheel bolts, and the coupler rests nicely on the seal, you are golden. Couple of points on installing the RMS seal: Everything must be scrupulously clean, not even finger prints, no sealer or lubricants of any kind should be used as they will cause the new seal to leak. Clean and dry. The PTFE seal has a different installed depth: 13MM from the flywheel mating face of the crankshaft.
  23. What tooling did you use to pull the hub? Heat may be your friend here, heating the remaining section will expand it and it should come off with some "encouragement".
  24. And Snap-On sells the special tool for about $18: https://vw.snapon.com/SpecialToolsDetail.aspx?itemid=10720003 This is also the same tool used on the Cayenne.
  25. I see now. I tried the same before briefly and found the threaded stud somehow locks in place even after both nuts are removed. I'm also curious to know if the stud can be removed. I believe that threaded stud is press into the shifter handle while it sits inside the blue aluminum central housing. You might want to contact B&M and see if they can replace the bushing or even the entire shifter. I don't think this is going to be a DIY project.
