JFP in PA
  1. Because of your low mileage, I would first bleed and evaluate the slave cylinder. How? Thread, topic, video you recommend? Thx. There is an extensive thread on the subject: http://www.renntech.org/forums/topic/7064-brakeclutch-fluid-change-and-bleeding-instructions/page-1?hl=+bleeding +clutch +slave Normally, most people bleed the clutch slave as part of the brake hydraulic system flush, which should be done at least every two years, sooner if the car is tracked. Both the clutch and brakes share a common hydraulic reservoir in these cars, so it is a great time to flush and bleed both systems if yours has not been done in a while, or if you do not know when it was done last. Not flushing these systems regularly can allow air to build up in the system as moisture collects in the fluid. IF that moisture is not removed, it can actually boil, leading to spongy brake and clutch pedals. The moisture is also absolute corrosive Hell on some very expensive component's in the systems.
  2. Because of your low mileage, I would first bleed and evaluate the slave cylinder.
  3. Just got it confirmed by a Porsche Master Mechanic - same oil. Good to know, thanks.
  4. Just got it confirmed by a Porsche Master Mechanic - same oil. Good to know.
  5. You need to test the circuit for both continuity and correct voltage, but do so with care. Porsche would do it by connecting a hyper expensive "pin out" box to the harness, you are going have to do it using a multimeter across the harness section.
  6. Again, you need to be careful in doing this type of test as even a static discharge from your body can be enough to trigger one of these system. As for your diagnostic tool, while it appears to be a good one, Porsche uses some unique diagnostic systems in their cars which can easily fool scanners that are not Porsche specific (PST II, PIWIS, Durametric). This is a common problem that has tripped up more than one DIY repair.
  7. If it is not the sensor, then as Loren pointed out above, there has to be a fault on the sensor circuit leading back to the control unit. You need to start checking that circuit for correct voltage and continuity (shorts). You also need to do this carefully as this testing could easily trigger the air bag. Disconnect the battery for several min. before disconnecting the sensor and airbag in question, then start testing the harness.
  8. To correctly remove air from the system, you need the use of a vacuum filling tool. While it may be entrapment, it could also be a thermostat issue.
  9. Before ordering any parts, you need to get the vehicle up and verify where the leak(s) are first. There are several potential points where it could be leaking.
  10. Reason I ask is the 1128 and 1130 are commonly occurring code pair caused by an air leak (overly lean mixture condition).
  11. Are you sure the code are P1130 and P1138, or could they be P1130 and P1128?
  12. Don't really know, I've only seen the one spec for the PDK oil as posted above.
  13. Don't really know, I've only seen the one spec for the PDK oil as posted above.
  14. We ain't much warmer here, 20F overnight tonight. Thank God for garage heat..............
  15. Yes, but it is a little more complicated as you need to adjust the fluid level when the transmission fluid is in a specific temperature range. There is a DIY in the 996 section (the procedures are exactly the same for a Boxster) that details how it is done.
  16. I realize that these systems exist for the benefit of emergency vehicles, but I would not want to be around when the local constabulary catches a private passenger car messing with the traffic lights.......
  17. A C4 should hold about 64L of fuel total, it is possible that your gauge is not calibrated correctly as you should be down more that half a tank when the light comes on.
  18. And I'm sure that won't get you in trouble either......................... :eek:
  19. If the car is level, and it ain't running out of the overflow when at temp, you are still low.
  20. That should be hot enough.
  21. What temperature was the ATF at when you check the level?
  22. If you try to put a Tip into park after running it in gear, some internal component's may still be turning if you have not totally stopped the drive line using the brakes. When this happens, the "pawl", which is the mechanical lock that drops into place in park to keep the trans from turning starts skipping from tooth to tooth until everything stops turning and it can drop into place. When this happens, it makes a ratchet like clicking sound. Completely normal. Normally, when you run the Tip in gear with the car up, only one wheel may turn. Again, this is nothing unusual. Now a question: Did you run the car until the trans came up to temperature and then adjust the fluid level? If not, the trans may not be full, or it may be over filled. Because these cars do not have dipsticks, you need to follow the warm up procedure to do the fluid level correctly.
  23. I notice it states amber and not the red third stop light can be pulsed. Can the third brake light (RED) be replaces with an amber lens and still conform to state laws? I believe the Federal standards for tail lights are red for brakes, amber for turn signals.
  24. While the Europeans are more open on this subject, the state laws here on blinking lights are kind of all over the place on this; some limit the color of the lights that can blink (often amber), the location of the flashing lights on the vehicles, others the rate and/or number of total flashes allowed to flash, and many only allow changes in illumination levels (the light can get brighter or dimmer, but not totally go out between pluses). I am aware of one owner that put small blue LED valve stem cap lights on his wheels (no, I have no idea why) and got a ticket for having moving lights on a non emergency vehicle, which he fought and subsequently lost in court. Flashing lights on passenger cars are somewhat like Forest Gump's box of chocolates..........
  25. Just be aware that aftermarket strobe lights are illegal on non emergency vehicles in many states, and ticket bait in many others.
