JFP in PA
  1. All engines are happier breathing cooler outside filtered air. I would locate the missing parts and reinstall them.
  2. The year and model are always helpful when addressing these questions. For the most part, brake light bulbs for the 986 are P21W for the corners, and W3W for the center. Both are readily available online or from parts stores.
  3. P0507 is a throttle position actuator code, indicating a higher RPM than expected. While intake air leaks will cause similar problems, they typically result in other codes (overly lean mixtures). Your throttle body may need cleaning or replacement.
  4. From what I can find, that pump is only available as a complete assembly, and retails for around $3K: ABS PUMP ASSY - 2001 Porsche 911 (996355955BX) List Price: $3,428.24 You Save: $586.74 (17% off) Sale Price: $2,841.50 Core Charge: $772.84 Genuine Porsche Parts Manufacturer: Porsche Part Number: 996-355-955-BX Part: ABS PUMP ASSY Replaces: 996-355-955-52, 996-355-955-54, 996-355-955-62 Part Notes: 2WD, W/STABILITY MNGMTPARTS: Order by description.
  5. Year and model is always helpful. You would need the car's wiring diagrams. The Bentley manual has a set for most 996's.
  6. Year and model would always be helpful, as would recognition that not all parts are sold separately, either by Porsche or the aftermarket.
  7. Yes, but it is much easier, and can actually be quicker, to drop the engine before starting as you will be doing full cam allocations on both banks.
  8. Current fuel blends, particularly with 10% ethanol in them, can degrade pretty quickly. StaBil makes inexpensive additives that can stabilize ethanol blended fuels for up to two years. Worth a look, we use their "Storage" product on all vehicles put up for the winter here, and have never had one act up in the spring.
  9. Watch for noise or vibration, or torn boots on the CV joints. There is a CV joint at both ends of the axles, under the boots:
  10. Pricing on these cars varies with climate and geography, so you would need to do some research in the area in which you live to get an idea of how they are priced.
  11. First, welcome to RennTech :welcome: As for the value of the car, what a car is worth is what someone else is willing to pay for it. That said, when considering buying a Porsche, you need to shop around to get a feel for the realistic sale prices of the model you are looking at. There are also several online services that will give you some idea of pricing in your area. Some sellers would like to think that a 15 year old Boxster with 75K miles on it is worth $25K because it is clean and they took care of it; I can assure you it is not. Secondly, once you find one in your price range, it is imperative that you have an independent Porsche specialist of your choosing do a complete pre purchase inspection on the car. While a good PPI can run several hundred dollars, the money is well spent as the inspection will reveal any pending issues that will need attention, giving you considerable negotiations leverage on the final price. Good luck in your search.
  12. Easy to tell by looking at it, the OEM plug is silver in color and has an 8MM Allan key way; the LN unit is black and uses a 10MM Allan. I think I know what happened. Some neanderthal did not have an 8 mm allen available so he, or it could be a she i suppose, used a T50 Torx which left its imprint on the soft metal leading me to believe it was always a Torx. Funny thing is it works just fine torqued to spec. Go figure. Some Torx bits closely approximate Allan key sizes, but they are not a perfect fit and will lead to deformation of the plug keyway with usage.
  13. A lot of the Durametric problems with the Cayenne line has to do with the use of Siemens made DME's in those models, which apparently use a different diagnostic logic. From what I have read, VW diagnostic systems, which do not work on other Porsches, seem to do a better job with these cars. I was informed by Durametric not to use VW diagnostics ( such as Ross-tech )on the Cayenne as it can cause CANBUS faults. I have also read that but we have several customers using VW diagnostics (Ross Techs VCDS) instead of the Durametric system on late model Cayenne and seem to have gotten by without problems as far as I know.
  14. Good to know and I'll ask them to make sure they replace that filter as well. Thank you for this. You don't think this would be the problem do you? Without seeing the filter out of the car, it is hard to tell; but clogged fuel filters can and will act like a dying fuel pump at times.
  15. An additional thought: A 2004 996 Turbo has an external fuel filter (part # 996-110-253-52); when was the last time yours was changed? I would also suggest that if you are going to replace the pump, put a new fuel filter on it as well.
  16. Low fuel pressure or volume delivery will definitely make the car run soft.
  17. This is why the should both be tested in tandem; a bad CPS would also give you no fuel pressure, but if you then jumper the fuel pump at the relay panel, the pump should run, even with a bad, or no CPS.
  18. If they tested the fuel system and got low pressure and/or delivery, I'm afraid the answer would be yes.
  19. Well, I'll be! JFP was right. The temp sensor checked out OK. The coolant reservoir sensor was the problem. The wire and connector were attached OK. But the sensor kind of goes into the bottom of the tank with a half turn. It had become dislodged from the tank and was just kind of hanging there. My guess is that when my mechanic installed the new tank last fall, he must not have securely screwed in the sensor and the pothole jolt was enough for it to finally come loose. I'm surprised it didn't fail sooner. Thanks everyone for the assistance and especially to JFP who was right on the money about where to look. Managed to swap out my air filter while I was checking the temp sensor, so double plus good. Warm weather coming soon! :) Best. There are only a few things that it could be; glad you got it sorted. :thumbup:
  20. The purge valve is under the intake manifold runners, as noted earlier in this tread. Item #20 in this diagram:
  21. Problem usually isn't with the factory oil coatings, but rather with the amount of oil put on the filters when they are first cleaned by the owenrs. Done right, they should not cause problems.
  22. Any decent aftermarket car stereo shop should be able to point you at multiple choices that fit. You can also look up the Crutchfield audio site where you can type in what car you have and the site will list various options that are known to fit without modifications, as well as other options that require some specific modifications to fit, as well as retail prices.
  23. If possible, I would recheck the car with a more current version of the system, Reason I say that is there was a rash of Chinese clones of the Durametric system, all of which were old versions (current is 6.5.0.7), and many of which were questionable to the point of actually damaging some cars. So unless you know the provenance of the system you used, I would recheck it just to be safe, and because if the code is real and live, the next moves will be more complicated and possibly expensive.
  24. Thanx JFP, I think you mistyped that last sentence and I think you meant that if one actuator was a bit lazy, it would throw a code. It is not throwing any codes at all. This issues is the classic hesitation at around 2700-2800 RPM that various folks have complained about... I know of no one who replaced these actuators.... I was just thinking of a hail mary pass and was thinking of trying it. Thanx for the advice. Using the Durametric for this advanced stuff makes me nervous but I will give it a try when the weather improves here in Philly. Peace Bruce I don't see why you should ever be afraid of the Durametric Pro system; you are not altering anything, you are just reading data that the car is generating. I would also warm the car up fully before testing it by taking it for a 20 min. or so drive first.
  25. If the code is real, basically all of the CAN Bus modules are off line. What type of diagnostic tool did you use to obtain it? What may be necessary is to reset all of the modules, which will require the use of a PIWIS system.
