JFP in PA
  1. If it actually is the same, and I do not know that as a fact, it is also around $13 per 1.5L container, so it also costs more (at retail) than Porsche coolant.
  2. If you look at where the drain plug is, the baffle is on stands cast into the pan, so the baffle is well off the sump floor, and there is even a cut out for the drain plug in the baffle. So unless the plug you used is unusually long, it should clear:
  3. When you have the oil out, take a small section of metal rod, like from a coat hanger, and measure how far up you have to push it before it hits, marking the rod. Then compare that distance to the length from the mating face of the magnetic plug to the tip of the magnet. Should give you a reference point of how close the plug comes to hitting.
  4. Next time you change your oil, shine a small flashlight up in the opening and see what is there. There really should not be any interference.
  5. Sorry, my mistake. The 9A1 sump cover has the drain off to one side a bit, with the internal baffle above the drain plug opening, but it should also be a bit higher up and not come into contact. In LN parts, both engines(M96/97 and 9A1) use the same drain plug:
  6. There should not be anything directly above the drain plug that the plug can reach. The oil pickup is above and to one side, but should be well far enough away to clear, as would the stock baffle (sump cover on the left): We have installed quite a few of the LN style magnetic plugs and I cannot say that we have ever had one hit anything:
  7. Not really. Porsche was an early adopter of the OAT technology, and has had a spotty history of not playing nice with some other brands of coolants, often resulting in gel formation in the cooling system. You need to proceed cautiously when mixing coolants as the results can be very expensive to clean out.
  8. Check the car's service records for the last time the brake hydraulic system was flushed, if it was more than 2 years ago, you need to flush the system.
  9. Cam end plug is a cheap and easy fix, the old one pops out and the new one pops in. Dried coolant on the water pump is an early sign of pending pump failure; the water pump should be replaced.
  10. Cylinder locations: P0203 indicates an injector malfunction on cylinder #3, P0267 is for a low circuit on the same injector. So it looks like #3 injector went off line and created the misfire. But neither of those faults explains the oil in the intake or on the other plugs.
  11. Right side of the engine bay, behind the recirculation fan, near the oil fill cap.
  12. The filler tube is in a bit of a tight space, but is doable with simple hand tools. It is under vacuum (or is supposed to be when everything else is sealed up), so you poor idle and noise are most likely caused by the bad filler tube.
  13. +1. You are overheating the PDK and probably boiling the brake fluid due to moisture build up. Get your brakes flushed, and do a preemptive PDK service (clutch and gearbox fluid change), both should help.
  14. I like the Solution from LN, they are well designed and made, and are the only permanent fix on the market. Not cheap, but if you are going to keep the car, it is the best option.
  15. An additional thought: If your car turns out to be a single row, and you are considering going with the new LN "Pro" dual row replacement for the OEM single row bearing, be sure the shop owns the Faultless Installation Tool that is required to do one of these swaps. You should not attempt to install the Pro dual row bearing without one.
  16. Everybody is entitled to an opinion, but history has proven many of them wrong. Your car could go either way. That said, the really good shops that do a lot of IMS retrofits would stock both. Just something to think about........
  17. Because of the year of the car, you need to proceed cautiously. 2000-2001 was a transitional period during which the engine could have had a dual row or a single row, and there is absolutely no way to know which is in the car without taking it apart and looking. All of the so-called published methods (VIN, build dates, engine numbers, tec., etc.) have proven inaccurate, and as most vendors will not accept a return on an IMS retrofit kit, you will be running a large risk by ordering before the car is apart..
  18. Potential buyers need to be aware that the RND engine program are not Jake prepared engines, but basically quality stock rebuilds with an LN IMS update and better cylinders (LN Nickies), but otherwise stock with quick delivery and a core exchange program. This interesting program should help those with dead or dying engines by offering a quicker way to obtain and quality rebuilt engine and at a lower price point than one of Jake's ten-tenth's units, which also require a much longer lead time. This is also not a retail level program (read they do not sell to the public), but one that supplies engines to shops that do business with the supplier, SSF.
  19. I would also shop around, looking at the LUK product line (an OEM Porsche supplier). I have seen reports of online purchases from other auto suppliers for as little as $350 for a new pressure plate and disc.
  20. Obviously, I have no idea how they came to their diagnosis. To test for a bad VarioCam solenoid, you would normally use Porsche specific diagnostic software, which can actuate the VarioCam units one at time on observe the change (or lack thereof) in cam angles. The IACV needs to "learn" throttle position and some other information from the car in order to function correctly, which is what that procedure is all about.
  21. I don't think you misunderstood my response, I am not referring to getting a new VIN number, but rather a replacement VIN tag or plate for the car. This is much more than just getting someone to do a re-pop of the original tag. I many states, it difficult, or even illegal to replace any VIN tag on a car without the state DMV approval. When state police or DMV officers show up at car auctions, one of the first thing they look at is the VIN tags and how they are mounted. If it appears to be a replacement, tampered with, or is missing, the car cannot be sold until the owner proves the car's provenance to the police and DMV; and in some cases the police will impound the vehicle until they are satisfied the car is legitimate. You need to contact your state's department of motor vehicles and get clarification on if and how you can do this. In the state where I live, the state has to issue an approved replacement plate once the title for the car is clarified, anyone trying to do this in the marketplace is subject to arrest; only the state can issue the plate. And cars with state reissued VIN tags have that fact noted in their owner's title, which stays with the car forever. This is not just a simple replacement, which is why I mentioned that you may also have recourse against whoever sold you the car.
  22. You need to check with the state authorities on this as it could be opening a real can of worms. In some states, getting a replacement VIN tag put the car in the same category as kit cars, which could make the car difficult to sell. You may also have recourse against the person that sold you the car.
  23. RPM, are you saying that the 997.1 C2S has a different clutch than a "standard" C2? If so, is it still a dual mass type that cannot be resurfaced? j - 78,000 miles on my '06 C2S still going with the original clutch. Cheers, Johan No dual mass flywheel should be resurfaced. If it is beat up, it needs to be replaced.
