JFP in PA
  1. 2000-2001 was a transitional period where the car could have either a single or dual row bearing; the dual row was stronger, but still failed, just not in as large number as the single rows did.
  2. Welcome to RennTech :welcome: If all that is bad is the key head, it can be replaced without having to reprogram. Purchase a replacement head, and switch over the key shaft and the little RFID button into the new key head, and your in business. The second key, however, is going to involve programing and cutting.
  3. Durametric, which is a Porsche specific tool, will correctly activate the ABS/PSM during a hydraulic system flush and bleed.
  4. You are not going to be able to properly bleed the system after changing the ABS unit without a Porsche diagnostic tool. If you do not have access to one, I would suggest not taking the car apart until you do.
  5. The Durametric software will also activate the ABS/PSM system during a flush.
  6. That's where it goes. thx.that tube doesn't go to anything and I am looking at a diagram that shows it going to no where. are you implying this should be tied into the washer system somehow? Perhaps we are looking at different tubes, can you annotate your photo to indicate which one you are referring to?
  7. I think you are looking at the head light washer solvent line, and yes, both should have one.
  8. It is the outside air temp sensors, it clips into the grill opening.
  9. Well, a full year subscription runs about $5K, but you can also buy access to one page at a time if you choose and for a lot less money. Info here: https://techinfo2.porsche.com/PAGInfosystem/VFModuleManager?Type=GVOStart
  10. They are useable, as long as you respect that they may not always be the current information. We keep a library of these service manuals, and when they were still in print it nearly a full time job to keep them currently updated, which is one of many reasons Porsche, like all the other OEM's, went to online systems which are always current.
  11. First of all, the PDF files (if they are the ones I have seen) were very early versions (1999 if memory serves) and had none the dozens of updates released later to correct misinformation contained in the originals. The Bentley manuals have also contained some incorrect information as well, and they have also released correction's on their website, so the inconsistencies you are seeing are not at all unusual, and why we often caution readers about using old and potentially incorrect information. Seat fasteners should be torqued to 65Nm or 48 ft. lb. Motor mounts should be torqued to 65Nm or 48 ft. lb.
  12. Welcome to RennTech :welcome: There is a specific section of the forum (Lost Radio Code) for the sole purpose of obtaining radio codes, please repost there.
  13. Try the EBC Red Stuff pads (ceramics) for your vehicle. I have several customers running them and they seem to like them.
  14. I would not be so quick to dismiss dirt/debris in the oil. Even the cleanest of these engines have particulate matter in the oil, including small plastic bits from the chain wear pads; any of which can plug a vital passage in the cam control system and cause no end of headaches. The vanes are the sealing strips the manual is referring to. You indicate that the cams are advancing properly, have you confirmed that using your Durametric? The various components and their function for the VarioCam + system are explained in the 2002 Technical Information Book (about four pages is memory serves), which is available to contributing members (Go to Downloads > Contributing Members Only > Service Information Books).
  15. Welcome to RennTech :welcome: Let's start with the code itself: P0021 Adjustment of Inlet Camshaft in relation to Crankshaft, Bank 2 – Signal Implausible Possible cause of fault - Dirt in oil circuit - Sealing strips on inlet camshaft adjuster faulty - Oil pressure too low - Mechanical fault in inlet camshaft adjuster - Magnetic hydraulic valve faulty. I would start with these before any parts are replaced or attempting to reset the cam timing. I rather doubt you are suffering from a stretched chain. While that can happen, it is not an everyday occurrence. More often, something in the VarioCam system is acting up (components listed above). Very few of these cars sit at 0 cam deviation values; in reality, anywhere between +/- 6 degrees is just fine. You also did not note if the cam angle changes with the VarioCam active, which would provide more data about what is going on. Your Durametric can activate the system for you. I have never seen a chain for these engines with master links, and would be concerned about their reliability in these engines. With everything else going on in this cam drive system, they really don't need anything else that can act up.
  16. Welcome to RennTech :welcome: Bentley manuals are good value and cover a lot topics, but not everything, Topics like the X51 or Turbo can get rather intensive and quite specific, and most 996 owners would not really be interested anyway.
  17. +1 on the B&M. I have one nearly as old as Loren's and it is still perfect. I've also installed a lot of B&M's over the years for customers, never had a problem with any of them.
  18. Rather than focus on the approved list, you can also use credible independent rating systems such as ACEA A3, B3, B4. Manufacturer published data often is culled to hold their product in its best light, but what you really want to know is how does the product hold up to high temperature/high shear environments, which is where the ACEA system comes in.
  19. I think you are going to find that those that have acquired engine assembly tooling are not going to be interested in lending or renting them out. You might want to search around as there have been posts concerning fabricating these and other Porsche specific tools.
  20. Try this: http://eni-agip.ru/upload/docs/PORSCHE%202012_A40.pdf
