JFP in PA
  1. It really isn't necessary, but you can do it using a product called Fogging Oil:
  2. Time to run a parasitic drain test, which has been written up multiple times, but there are also a ton of online videos : . Basically, after the car has been sitting for about an hour or so, there should be a 45 - 60 milliamp current drain on the battery from necessary things like the clock and the alarm system; any higher than that and you have a parasitic drain on one or more of the electrical circuits.
  3. Loren showed you a section of the exploded parts diagram for the vehicle, which you can find on multiple public websites such as board sponsor Sunset Porsche.
  4. According to Porsche, item #24 in the pillar is the "antenna booster", while the item you posted the photos of is item #27 is the "Antenna Diversity Control Unit" for the PCM navigation
  5. Ever think it could be the ignition switch? The antenna amplifier is located on the right A-pillar, behind the trim which is easy to remove
  6. As the codes seem random, I would start by looking at the fuel trims and MAF signals.
  7. Welcome to RennTech Without the actual codes the car is throwing, anything would be a guess.
  8. Or whomever did the replacement did not torque the new units with the car sitting on its wheels.
  9. When looking at the lower pulley on the front of the engine, which direction did you attempt to turn it, clockwise or counterclockwise?
  10. Welcome to RennTech You have a potentially major issue here; if the crank cannot be turned by hand with a wrench, either the engine is seized, or something is mechanically jamming the rotating assembly (are you sure the trans is out of gear?). If the trans was in neutral, you need to do further diagnostics into why it won't rotate, which could get into serious disassembly, including dropping the engine out. In almost any permutation as to why this is happening, you are looking at some serious $, and trying to force it to rotate will only worsen the situation. Good luck.
  11. Sometimes you simply have to go with the factory system due to what Porsche sees as "proprietary". Glad you got it sorted 👍
  12. Depends upon why the compressor failed, and what it damaged in the process. At a minimum, the drier, and if metal is present, the expansion valve (after the system is properly flushed to remove the metal). You will also need the correct PAG oil for the new compressor.
  13. If the compressor had seized, you would have no cooling, and when the clutch engaged, the pulley would simply stop turning and the belt would start slipping.
  14. The AC system clutch can be replaced separately, project was covered previously: https://www.renntech.org/topic/32732-replacing-ac-compressor-clutch/
  15. You would need to check each of the four circuits for continuity at the DME, there is no voltage on the circuits, and I am not aware of any resistance ratings. Another way to find it would be to create a "jumper" that you could hook up at the DME end of each circuit, as soon as the bad circuit was replaced by the jumper, the signal should stop. It is really a process of elimination.......
  16. Porsche brake pad wear sensors function on continuity; each wheel has a wire loop running to the sensor and back to the DME. If there is a break in that loop anywhere, not just at the pad itself, you will get the sensor warning. As this sensor system runs all over the car, and the insulation is a vegetable-based coating, it is a favorite "edible" for rodents, which leads to wires getting cut.
  17. Welcome to RennTech and Happy New Year! For street use, semi rigid motor mounts are probably a bad idea; noise and constant vibration.
  18. It probably is the low-pressure switch, which you can unplug and jumper temporarily to get the compressor to run.
  19. You can pressurize it with dry nitrogen or argon with the dye for testing to limit the amount of freon leaking into the atmosphere, unless you have access to a freon recovery system, then you could use freon because you can limit the amount that escapes the system. When we get a depressurized system in the shop, we do not use freon until we know we have found and fixed any leaks, and we have a freon recovery unit.
  20. If you had no pressure in the system to start with, there has to be a leak somewhere that has vented the gas off. At that point, just adding gas is not going to work; the system leak has to be found and repaired, then the system needs to be evacuated to a high vacuum level to get the air and moisture out before recharging with both gas and the correct system lubricant.
  21. Welcome to RennTech, and Merry Christmas Most times the sunroof related leaks start, it is because one or more of the four corner drains is plugged and it is retaining water that would otherwise be on the ground under the car. When the car is moved with the water still in the sunroof tray, it sloshes around and shows up on the headliner. I would start by blowing low pressure air thru the drains to see if they are plugged.
