JFP in PA
  1. OK, first you need to measure the vehicle's calibration point values and determine what the values should be: http://www.photobykent.com/downloads/cayenne/Cayenne-Level_Control-Calibration_Points.pdf Nest you need to connect your Durametric system: 1) connect your ODB-USB cable and open up your Durametric program. 2) browse down the tree on the left side to "Level Control" and select it 3) then select "Adaptation" to be on the calibration screen 4) select "read" . The box below the channel number will say "wait..." Your air suspension will go up and down. 5) when the suspension stops moving and the box changes from "wait.." to "enter". Enter the measurement (in mm) from the wheel displayed. Believe first is "FL" or Front, Driver. Then hit "save". If it accepted your entry, the value in the box will change from "enter" to "learned". If not, then will have to reenter or restart the program/laptop. 6) click the channel "up" button to move on to calibrate the next wheel. 7) do this same step to the other 3 wheels 8) Once all 4 wheels have confirmed "learned", press the channel "up" button one more time to channel "5". Enter "1" to save changes. If the system accepts your changes, it will say "control position learned" in under a minute. If it just sits there and does nothing, you may have to start over from scratch. Sometimes it takes a few times to stick. 9) You will then hear the air suspension adjusting to your new settings - hopefully that means air purging. Enjoy.
  2. If you wish to have an off line conversation, send me a PM. During normal business hours, I am usually way too busy in the shop to take phone calls. Not to underestimate your capabilities or facilities, but you also need to take into account that all of this work will require a lot of specialized tooling, as well as considerable technical knowledge. The IMS swap alone will require removal of the transmission, clutch, and flywheel just to be able to see which type the engine is carrying.
  3. For those looking to the aftermarket to say some $, stay with well known suspension component suppliers like TRW or Moog and you should be fine. Quite often, these suppliers are also OEM to Porsche (TRW for one is). But to jagman1's point, also check with board sponsor Sunset Porsche, and you just may be surprised at the prices you can get the actual Porsche parts for.
  4. Welcome to RennTech :welcome: TRW is a quality brand, you would be fine with them.
  5. An entirely different can of worms. The M96/97 engine Porsches (basically all of them with the exception's of the Turbo and GT cars which use a different engine) have an intermediate shaft that is driven by the crank, and which drives the cams. On the back end of the shaft is a bearing which gets replaced with an aftermarket hybrid ceramic bearing as the OEM bearing is prone to failure. The process to do this is known as an IMS retrofit. For a more detailed explanation: http://imsretrofit.com/
  6. Yes, because your cam deviation values are way out of whack before the VarioCam activates; that is a sign of tensioner pad wear. When we get a car in for IMS retrofit, the first thing we do is check the cam deviation values; if they are out of spec, we won't do the IMS unless the other issue is addressed as well, because we know where this is going and it ain't pretty, plus we don't want to be held accountable for that when it happens. We don't do things half assed, we either do it right or not at all.
  7. You definitely have a timing problem, as your can deviation values are way out of spec at idle, which is before the VarioCam does anything. This is most likely the tensioner wear pad issue. Your VarioCam system is not activating on bank 2 (cam angle does not jump to over 20 degrees), so either the solenoid or the VarioCam unit itself is out. Did you hear the "click" I mentioned when you activated the VarioCam on bank 2? If not, I would start with that solenoid. In any case, you need to get to the source of the out of spec cam deviation values; your timing is far enough out that you could get into serious trouble if it moves further. This is going to require pulling cam covers to inspect the wear pads, which will need special cam holding tooling (the cam cover forms one half of the cam bearings, so a holding tool in needed to keep from potentially snapping the cam in half when the covers are removed). This is a "home made" version of the same tooling in place on an M96 with the cam cover off:
  8. Welcome to RennTech :welcome: OK, let's start with the basics: Did you put the system into its "service mode" before jacking it up and working on it? Did you change any of the system sensors while doing this repair? Did you recalibrate the leveling system after the repair? JFP, I replaced my upper control arm and in doing so, I had to detach the air hose on the suspension to the air inlet valve. I put it all back together again but as I drove around I get an air suspension fault. I thought it had to do with the fact that I didn't replace the air inlet connection to the valve so I bought a new valve all together. I replaced it yet I still get the error after driving around for about 2 minutes. I did NOT put it in "Service Mode" because I didn't know I had to. Is there some sort of re-calibration I have to do? I have a Duratech analysis tool but I didn't see an option for the air suspension. Any help would be greatly appreciated!! Year and model of the vehicle is always useful when answering these questions. And yes, the Durametric system can recalibrate the ride height control system, and yes you should have put it into service mode before jacking it up or working on it.
  9. That was were I was coming from. Actually, there was a report of a "typo" in the Durametric software that reported codes with transposed digits for some codes. I would suggest two things: 1 Recheck the car using a loaner OBD II scanner from an auto parts store, many do this for free, and see what codes it sees. 2 Contact Durametric and let them know exactly what their system found and what the OBD II system saw. I would also like to know what you find as well. You may have something minor that the system is misreporting.
  10. The Durametric system is enormously capable, much like the car itself. It is capable of both evaluating and in many cases activating systems for test purposes. Along with being able to individually activate the VarioCam units, it can show you the real time effect on your cams, and even plot the data as a graph. It can also test run a lot of systems, such as running the front cooling fans on both their high and low speeds, as well as running the engine compartment exhaust fan. Dig around in its various menus and look at what it can do, it is a quality diagnostic tool.
  11. Ok, let's start with some basics: When you say the cam angle is -11 degrees and the other cam is 15 degrees, are this "actual cam angles" or "cam deviation" angles? Your cam deviation specs are +/- +6 degrees at idle; if your engine is at 11 & 15 degrees (cam deviation values) you have a more mechanical issue as your cam timing is way out of whack. As you car is a 2000, it is a five chain motor, meaning that it has an extra set of cam tensioning paddles between the two cams (note the small chain connecting the two cams with the green arrows, about half way between the two green arrows you can see the wear pad of the five chain tensioner): The small wear pads can literally fall apart, throwing the cam timing off (these are worn pads next to new ones): I would suggest rescanning the car, looking at the cam deviation values at idle When these pad get beat, the cam deviation values go way out of spec, and the car throws the code you are seeing. You would also find small yellow/brown plastic bits worn off the pads in both your oil filter and sump. If the sump contains green plastic bits, they would be coming from the VarioCam unit itself, which can also do this, but is much less common than the chain paddles. While you are rescanning the car, also activate the VarioCam solenoids one at a time at idle; you should hear a pronounced click, followed by a major movement in the cam timing, along with a big change in how the car idles; this will show you if the VarioCam solenoids and the units themselves are functional. Your air bag fault points to an open circuit in the system, possibly in the steering wheel air bag or clock spring assembly.
  12. You might be surprised, AAA were one of the first to train their drivers on how to correctly use the OEM tow hooks to flat bed Porsches without damaging them. Call your AAA rep and ask them about your battery concerns.
  13. We do this all the time, so here goes: Tools 1 & 2 are an engine support bar (you must support the engine while removing the transmission from the car and leaving the engine in). Tools 3 & 4 are used for the torque converter unbolting process and then retaining it with the transmission while removing the trans (you really do not want to drop a converter, it gets very expensive very quickly). Tool 5 are hose clamps for the transmission cooler lines that have engine coolant running thru them.
  14. P0430 is pretty specific. Before assuming it is the O2 sensor, I would check the voltage curves on the sensors for that bank with the engine running. If the voltage curves are following each other, the cat is gone. As the cats are rather expensive, I would also clear the code(s) and see if they return before jumping into changing any parts.
  15. I don't think he has ever been here.
  16. Remove the coolant drain plug near the thermostat housing (you will need a new crush washer for it). Disconnect the hose going from the thermostat housing to the front of the car. Realistically, unless you are going to refill the car with water, run it, and re drain it a couple of times, you are only going to get 80-85% of the old coolant out. You are going to need a minimum of 90 PSIG sustained air pressure to correctly run one of these vacuum fill systems. Your recharge mix should be a 50/50 mix of fresh coolant (we only use Porsche's stuff) and distilled water (about $1 a gallon at the supermarket); never use tap water. In a 5 gallon bucket, you can comfortably mix 2 gallon each of coolant and distilled water.
  17. Check with them and ask if they did a PIWIS reset of the system, you may find that they did not and just wrote the PCM off as needing replacement. The reset only takes a few min. of diagnostic time, which has got to be one Hell of a lot cheaper than a new unit.
  18. PIWIS ( Porsche Integrated Workshop Information System) is the name for Porsche's computer diagnostic system, it is capable of analyzing every system in the car and resetting various systems when they act up or need to be replaced. All dealers and many independent shops have them.
  19. "Check the rubber stops on the rear lid after racing"? Wonderful.............
  20. Welcome to RennTech :welcome: OK, let's start with the basics: Did you put the system into its "service mode" before jacking it up and working on it? Did you change any of the system sensors while doing this repair? Did you recalibrate the leveling system after the repair?
  21. P0430 is often an aging cat code, but can also be triggered by an intake of exhaust leak. I would clear it again and see if it returns, if it does, and you are sure there are no leaks, you are going to need a cat.
  22. P1128 and 1130 are bank 1 & 2 codes for an over rich condition. While it could be MAF related, it can also be fuel pressure too high, leaking injectors, or the EVAP purge valve being stuck open. Your surging idle is probably caused by disconnecting the battery, which puts the system into a "relearn" mode. If you want to test your MAF, use a Porsche diagnostic tool or other capable OBD II scanner to read its air flow readings.
  23. Knowing how much effort (and cost) is involved in trying to make more proven power with the normally aspirated versions of the 996, you need to take most claims for large improvement from intake, exhaust system, and DME reflash with a really large grain of salt, particularly when starting from a stock configuration.
