JFP in PA
  1. A quick scan of the car with a Porsche diagnostic tool would give you better information, but it may be the sensor.
  2. Hello Loren; Thank you for your reply; EEPROM is still working; reading and writing; but it has been deleted, so it is empty. Do you think a dealer can reprogram the key? The car is programmed to accept the key, which is what Loren is referring to.
  3. Not really, some of these "stealth" units would be so difficult to remove, it simply isn't worth while, and their removal would actually diminish the car's value.
  4. If it is a radar detector, the sensors have to have a line of sight front and rear. I'd start looking into the front grills with a flashlight.
  5. So how much was the labor? -- peer I hope you realize that you are responding to a nine year old post................
  6. Welcome to RennTech :welcome: The tank is molded plastic.
  7. The indy came highly recommended by other Boxster owners, and seems to me to be operating genuinely in the best interest of the car. They went over the complete refilling operation with me and they say they did all the correct steps for proper fill - correct temperature, shift the gears, fill again, etc. I only question because I didn't see it with my own eyes so I'm including this in my list of "could it be this?". Well, not to slight your shop in anyway, but one of the most common problems with the Tip is both fluid choices and filling procedures; more often than not, we find recently serviced Tips with problems are not filled correctly, or have the wrong fluid in them. Because the filling and testing procedures take time, a lot of shops seem to try and short cut them to save money. Point taken. I'm not invested in defending nor persecuting this shop because, so far, I have no evidence of malfeasance. Fluid level is something I am very interested in checking, so I'm gearing myself up for being able to do so the weekend after this. I've read up on good ways to place the car on jack stands so I'm pretty clear on that. What I'm not sure about is which fluid I should get. Is the factory fill a ZF or Pentosin? because I'd like to use what was in the tranny from new because it did its job so well. Look at it this way: ZF makes transmissions, not fluids, so they are buying it from someone (most likely Pentosin) and relabeling it with their name.
  8. The indy came highly recommended by other Boxster owners, and seems to me to be operating genuinely in the best interest of the car. They went over the complete refilling operation with me and they say they did all the correct steps for proper fill - correct temperature, shift the gears, fill again, etc. I only question because I didn't see it with my own eyes so I'm including this in my list of "could it be this?". Well, not to slight your shop in anyway, but one of the most common problems with the Tip is both fluid choices and filling procedures; more often than not, we find recently serviced Tips with problems are not filled correctly, or have the wrong fluid in them. Because the filling and testing procedures take time, a lot of shops seem to try and short cut them to save money.
  9. That product is listed as being for a VW with a Tip transmission, so it would seem reasonable it should work, although the factory fluid is usually either a Pentosin or ZF product rather than the Febi product they used. As for correct fill levels, you need to ask whomever did it to explain how they checked it as there is a specific procedure that entails running the trans through the gears while getting it up to a prescribed temperature.
  10. Possibly, reset the code and see if it returns.
  11. P2189 Oxygen Sensing Adaptation, Idle Range, Bank 2 (RKAT2) - Above Limit Possible fault cause: - Incorrect main charge signal - Intake air system leaking - Fuel pressure too low - Volume supply of fuel pump too low - Mechanical fault in injection valves - PCV valve leaking - Cap of oil filler neck leaking - Leaks in exhaust system - EVAP canister purge valve mechanically faulty (hangs open) - EVAP canister purge valve output stage faults I would start with the easy ones - the oil filler cap and the PCV.
  12. You can't, the exhaust system needs to come off.
  13. Just remember that if the car turns out to be the 22MM center bolt, you can still them remove the rear seal on the IMS bearing so that it is lubricated by the oil mist inside the engine. While not a perfect solution, it does seem to improve the longevity of the oversized IMS bearings,
  14. 2005 was a transitional year for the M96/97 engine's IMS bearing. Some of the cars carry the single row serviceable (read can be changed without disassembling the engine or even removing it from the car), while other carry the oversized non serviceable (read the engine must be disassembled to retrofit it) bearing. The car's with the serviceable bearings carry the single row bearing, which has the highest failure rates percentage wise, cars with the non serviceable large bearing have a low failure rate, but are still known to fail. In reality, any M96/97 engine with a factory IMS bearing has some probability of IMS failure, but some are more prone than others with the 2001-2005 single row's being the worst. Unfortunately, the only proven method to know which bearing is in the engine it to pull the gear box, clutch, and flywheel, and look at the IMS bearing flange center bolt. No other methods (VIN, build date, engine number, etc.) have proven even remotely reliable. The oversized non serviceable bearing used a 22 MM center bolt and was the only one to use that size, so it is easily recognizable once it is uncovered.
  15. There should be no condensation above the coolant tank in the rear trunk, that sounds very much like you have a bad tank cap. The latest revision tank cap ends in "-04". The cap could be the entire source of your coolant loss issue. The aftermarket coils should not have been able to damage the car in anyway other than to make it misfire. You comment about having to weld up you catalytic converter is very important, because a leak in the exhaust system, even a small one, will often cause an engine to show an overly lean condition because it allows air into the system which the O2 sensors see as a mixture problem. You need to go over the exhaust system from the cylinder heads to the second O2 sensor looking for any signs of a leak (he can use his smoke wand for this). As for where you can get your EVAP valves, as well as a new tank cap, give board sponsor Sunset Porsche a call, great pricing and top notch service. D chunking shows up usually with coolant in the oil. Unfortunately, because of where this fracture occurs, you usually can only find it either with a bore scope, or by pulling the engine apart.
  16. Yes, you can smoke test components on a running car, you need to do it with a small wand which you place near the suspected item and see if the smoke is drawn in. The EVAP check valve is like a light bulb, it either works or it does not. You pull it out and see if it closes when it should; if it does not, replace it. Usually, they are stuck open by carbon build up, which cannot be cleaned out. D Chunking is the failure of the cylinder liners near their ends. This is an extreme example of what can happen: In its early stages, the chunk is still there, but the liner is cracked and allows the engine to pull coolant into the cylinder. I have addressed your other questions in a PM.
  17. Just be aware that source has made more than one mistake in their instructions. If you want a quality technical source, get the Bentley 996 manual, which is much better.
  18. Welcome to RennTech :welcome: That 11MM below the fill hole only applies to 5 speed Boxster transmissions; yours should be filled until it comes out the fill hole. And be sure they only refill it with the factory lubricant, not aftermarket stuff.
  19. If that smoke is coming from the air filter box, which is not evident in the video, it is normal. As I mentioned, the problem of small vacuum leaks is that their cumulative impact can be large; you need to track them down one at a time and eliminate them. These cars are rife with plastic vacuum lines that chafe or crack with age and drive shops nuts trying to track down the leaks. When we get a bad case in the shop, we often resort to pulling off the intake and running all new plastic and rubber lines, just to eliminate all possibilities. Not a cheap remedy, but one that works. You need to also be careful about where replacement parts come from, particularly the vacuum reservoir tank and the AOS. We have had so many issues with aftermarket units that we no longer will use them. The AOS is particularly bad in this respect. Even with factory units, we still vacuum test every AOS we install, just to be sure, as we have also had some problem OEM units as well. A fresh, correctly functioning AOS should pull between 4-7 inches of water on a cold start, then settle down to around 5 inches as the car warms up. If we put one in and it does not meet those criteria, it comes back out again and another new one goes in, otherwise you can get problems ranging from vacuum leaks to high oil consumption. We have also seen vacuum reservoirs that seemed good in the car, but completely fail a bench vacuum test as well. You also need to be aware that there are systems that are not in their normal operational modes unless the car is running, the EVAP control system is a perfect example. With the car shut off during a smoked test, the control valves are not in the same position as they are when it is running, which can lead to erroneous conclusions. There is also a EVAP check valve under the intake that is notorious for causing problems which can only be tested on the bench. So a static smoke test cannot be the sole determinant of what is wrong, you need to dig further. Your comment about the coolant system concerns me. Early Boxsters with the 2.5L engine had cylinder liner issues that ranged from liner slippage to complete liner failure (commonly referred to as "D-chunking"). A completely tight cooling system can go literally years with no additional coolant required. Something is not right; youe cooling system needs to be pressure tested, and you need to find out where the coolant is going.
  20. Without knowing the volume of air they are passing, and answer is not possible. But they are leaks that should not be there, and leakage effect is cumulative across all leaks, and in the second video you had considerable smoke billowing up at the beginning of the video, which is not a small leak.
  21. In general, your thoughts about a failing cooler leading to oil in the coolant are correct, but when you shut the car off, there is no oil pressure but there is about 18 PSIG of coolant pressure so it can also go the other way, albeit slower. As for the AOS, you can pressurize the coolant system to 18 PSIG and pull both hoses off the AOS, and you should hear or feel a leak.
  22. I think you have leak that needs to be fixed.
  23. OK, as for the lines to blow out, refer to my system diagram above, you want to blow out lines 1 & 3 after disconnecting both ends of the lines. As for your mechanic's comment that "those two small leaks are not significant enough", I'm sorry but that is nonsense. Any vacuum leak is significant, this system has to be tight. You could easily have a few "small" leaks that are in fact equivalent to one massive leak. And by your comment about the AOS J line, are you referring to the one that runs from the top of the AOS to behind the throttle body, or the long one that runs from the other side of the AOS and under the intake manifold?
  24. You have three possible ways to get coolant into the oil: 1. A crack somewhere in the cylinder heads or engine case; which you appear to have eliminated with your leak down. 2. Your oil cooler may have failed (it is an oil to coolant heat exchanger), which can be tested by pulling it and running a vacuum test on it (if it is good, both channels should hold high vacuum). 3. Your AOS.
  25. Did you attempt to read other channels as well? Never mind, I see that you have already tried that. I would say that the system controller is having issues or for some reason the Durametric system cannot communicate with it.
