JFP in PA
  1. Go back to my #2 post above and go down the list, all the possibles are there. Sorry, that was pretty obvious I suppose :) From what I can find, fuel pressure should be 4 BAR (58 psi)? Incorrect main charge signal = MAF? Should I give it and its connector a cleaning? I'm away from the shop at the moment, but I think that fuel pressure is close if not correct. I think they are referring to your charging system, but cleaning the MAF never hurts.
  2. Go back to my #2 post above and go down the list, all the possibles are there.
  3. As you might imagine, daily driver's in PA tend to look like they have been sandblasted, thanks to PennDOT's road care procedures. And being a legendary "pot hole paradise", we also tend to keep suspension component companies in business as well. I recently had a customer sell his 458 Ferrari Spider because he could not find decent roads to drive it on during good weather and simply got tired of trying to avoid pot holes.
  4. Not what I was inferring at all. You seem to be saying that there was a difference between what you thought the car should have gone mileage wise and what the system says. I was asking if the difference between those two was about 5% as the factory sets the speedometer slightly higher than reality (most estimates are in the 4-6% range). Now that I have read your other post, I think you are questioning if the miles shown on the dash odometer in relation to the "total distance" captured in the DME. Going by the total hours run time, and using 27-30 MPH as an average speed (this comes from having read a many cars over the years which seem to fall in this range), your car should have shy of 31K miles on it, so the 32K you see seem about right. As for why the DME shows the total distance at 6215K or 3,800 miles, that I am at a loss to explain. If you think there is something wrong with your 32K display mileage, check the running hours on the air bag module, it should approximate what the DME sees for the car, but is recorded separately, so it is a good double check for someone trying to alter the cars miles.
  5. The 6215 is in kilometers, so it is around 3,800 miles give or take. What did you expect it to be, and is that value around 5% different? Reason I ask is that all speedometers are set around 4-6% high from the factory, which would translate into a trip odometer reading higher than the actual mileage driven. I would also note that a PPI should have included and DME report.
  6. Is the difference between your odometer and the "Total Distance" read around 5% or so? Or does the car's service records indicate that the dash cluster has been worked on?
  7. OK, thanks JFP. I found the Pelican photos too but it is not obvious from the photos alone that the unit can be loosened enough to remove the fan without disconnecting the hoses and removing the whole assembly. If you look at the exploded parts diagram above, you will see that the fan is mounted into a shroud, which is then held in by a couple of fasteners. You do not need to drain and remove the radiators, or the AC heat exchangers, they remain in the car.
  8. Next time, try looking up the parts in the Porsche PET system. Your passenger's side fan is available as a separate part, #99762412802, and retails for a tad under $450.. Thanks JFP; I was aware that the fan can be bought as a separate part but was asking if the replacement of the fan alone can be done without removing the whole unit from the car. Sorry for confusion on the question. You can access the fan and radiator by removing the front fascia and wheel well liner, and then moving a couple other items out of the way. This is from a 996, but yours in not that different:
  9. The outer CV joint can get pretty hot during track days, and cause some excess grease to vent out. The hotter the day, and sticky tires often accelerate this. It isn't really a problem as the amount of grease is typically quite small, but after a lot of track time, it might be a good maintenance item to repack the CV's.
  10. Next time, try looking up the parts in the Porsche PET system. Your passenger's side fan is available as a separate part, #99762412802, and retails for a tad under $450..
  11. I want to call this one solved! The cold weather start this morning was flawless! It has power and responsiveness I didn't know it had. This has been a long one, Plugs, tubes (leaking and cracked), boots (Cracked and torn), AOS, TB and intake tube cleaning (oily and dirty), lots of data logging and three MAF's (probably should have just been one!!!!) and I think its finally over! While there were some contributors that probably were not helping, I'd say the primary issue was the non-Bosch MAF. This should be a PSA or sticky, just because it looks identical doesn't mean its made identical. Bosch MAF's ONLY in these cars!!! A Big thank you to Ahsai and JFP for sticking it out with me, giving me feedback and reviewing my data! I would have been lost! Don't be down on yourself about getting the wrong MAF, a lot of people have learned the same lesson the hard way. I'm just glad it is finally sorted.
  12. I'm sure they have to have some loss, but as everyone has to run one, it should not be a factor.
  13. And I've been wondering about that MAF since this conversation began.
  14. The ABS light on your dash is a "malfunction indicator light" or MIL; it should only come on if the system malfunctions, but it should light up when you turn the key on but do not start the car. The rubber boot that Porsche was describing is where the rod connecting the pedal goes into the master cylinder up under the dash, you will not be able to see it from inside the boot.
  15. We don't see that many traction control cars here, PSM was much more common so I will be going from distant memory. That said, and if memory serves, on a rear wheel drive car the pump is on the opposite side from the master cylinder; while on a four wheel drive car it is next to the master cylinder.
  16. OK. I understand where you are. The pumps are very quiet, but not silent; they should also get warm if they are running (which is why they don't want you to run them for long periods). I would try to make the pump run (don't try and actually bleed the system) while touching it to see if it gets warm. At the end of the day, the pump could be bad.
  17. You can start by looking at the plugs, I would also plan a leak down on all cylinders, along with a pressure test of the cooling system. Depending upon how the plugs read and the leak down, I would then bore scope the cylinder's that are the most likely candidates. What worries me is the combustion by products in the coolant; there are a lot of ways for coolant to leak out of an engine, but when you start seeing combustion gases in the coolant, it is decidedly more serious and usually leads to a crack somewhere. If it is in the cylinder head, it may be repairable, or the head can be replaced. If it is in the cases, it becomes much more serious.
  18. If you used the lower fill plug, the trans cannot be over filled, and the gear oil is not the source of your other problem.
  19. If you used the forward plug, you have probably overfilled the trans and have gotten oil on the clutch. You are supposed to add fluid through the lower plug to the right, and should have used around 3L of fluid. Try removing the lower plug to the right in the photo and let the excess fluid drain off. You may just get lucky.
  20. Sorry, but I do not understand how a failing water pump allows combustion by products to enter into into the cooling system in quantity; do you have an explanation?
  21. The current poster (HELLAS59) has tested positive for combustion by products in his cooling system in addition to losing coolant and having condensation above the tank area; which points to something a bit more serious than a failing cooling tank.
  22. No...you are just a c0ck [emoji12] , there is a serious chance that this gentleman's motor has taken a turn for the worst and a smart Aleck keyboard warrior like yourself must be some kick ! OP have the car towed and good luck! We do not tolerate this type of personal attack on RennTech; this is a clear violation of the forum rules and will result in a permanent ban if repeated.
  23. Changing the gear box and/or diff fluids should not have any impact on the clutch operation. Are you sure that you used the correct fill opening, some 996/997 actually have two plugs. http://www.renntech.org/forums/topic/48480-9972-transaxle-oil-and-capacity/ http://www.renntech.org/forums/tutorials/article/64-manual-transmission-oil-change-instructions/
  24. From your vacuum signal video, there does not appear to be excessive vacuum inside the engine cases. There will always be some oil residue inside the intake system, that is just a fact of life with these engines and this AOS. I would change the AOS simply because (1) You already have it, and (2) Porsche has improved the internal components, so your new one should be better made. A couple of caveats: Remove the small "J" tube that runs from the top of the AOS to the intake, and carefully examine it for any signs of cracks, etc.; we have seen these fail way too often. Secondly, I would also have good look at the long hose that runs from the lower AOS connection under the intake runners and over to the PCV unit for the same reason you would be looking at the short hose. Problem with this long hose is that you need to disconnect it at the PVC and tie a thin but strong cord to it before extracting the hose from the AOS end. By doing this, you will have the cord to snake either the existing hose (if it is good) or a replacement back into place after checking it.
