JFP in PA
  1. I'd suggest using board sponsor Sunset Porsche's online parts site ( http://www.sunsetporscheparts.com/ ) to check part numbers for both vehicles; if they are the same, the part is the same.
  2. With the 9A1 engine, the IMS is gone and no longer an issue. Only downsides (customer comments) is the car's race car like ride, which can sometimes get old for everyday use. The car should also have center lock wheels, which can restrict aftermarket wheel selection. The ceramic brakes, while terrific on the road, can get very expensive to maintain.
  3. We have seen a couple, and heard or read about others. While not an everyday occurrence, when it does happen the results are devastation with broken rods and/or crankshafts and split cylinders. Not pretty.
  4. Welcome to RennTech :welcome: It is not at all unusual for some early Boxster to go a lot of miles before the I/M Readiness test clears, we have seen customer's cars go a couple hundred miles before it reset, which is why we caution owners not to try to fix problems, or experiment with diagnostic systems right before going for emissions testing.
  5. Failures of recently installed, and even right out of the box AOS units is unfortunately an all too common occurrence. We test every unit we install, and the one on every car that comes into the shop; some seem to last forever, others not so much, and to date we have found no way to separate one from the other. While a bad or failing AOS can inhale more oil than a good unit, the larger concern is having the engine ingest liquid oil and hydro lock. Long term burning of excessive oil can shorten cat life, but the liquid oil issue is far more critical.
  6. If you have a leaking cam tensioner, they do have crush washers underneath them. That said, you cannot just remove the tensioner and replace the washer, the process is more complicated in order to prevent the cam timing from moving during the process (item # 6 & 12 ) : I would first try torqueing the unit to 30 Ft. Lbs. and see if the leaking stops. If not, the washer will need to be replaced.
  7. While these cars are well known for not liking aftermarket gas caps, you should get a different code (large EVAP system leak) for a bad gas cap.
  8. You need to disconnect the long line under the intake at the purge valve (#1) and canister ends, then blow air through to clear it, I would also check the valve itself, and they have been known to stick as well.
  9. P0446 is typically the EVAP system purge line is blocked, or the EVAP canister itself has high flow resistance. Usually addressed by disconnecting the purge line and blowing it out with compressed air. I think the actual code you are referring to when you say P1133 is actually P1130, which is for O2 sensor adaptation, idle range, bank 2, below limit. If so, this code is indicating that your mixture is overly rich, usually due to a MAF signal problem, high fuel pressure, a leaking injector, or the EVAP purge valve hanging open.
  10. Sure; first, never disconnect the battery to clear a code without first reading it. Doing so loses all of the accumulated systems diagnostic data that could have identified the problem and helped get it fixed. Second, now that codes are back, get the car scanned and let us know what you found.
  11. We have a couple customers running Fabspeed cats, which seem to be working well.
  12. Just about everything Porsche sells is grossly over priced, but is also often found in the aftermakret for considerably less. Shop around and look at online resources as well.
  13. Welcome to RennTech :welcome: While you are preaching to the choir when it comes to spending wads of cash to try and getting big horsepower out of normally asperated Porsche engines, you are also replying to a nine year old thread.........
  14. On your Boxster, you can remove the axle assembly without removing the hub or exhaust system, but it is a bit "fiddley". Partial removal of the exhaust on the affected side will give you more room.
  15. Welcome to RennTech :welcome: P1120 is a signal interruption in the egas throttle control system. Possible candidates are the wiring (assuming a break or ground condition), or the throttle position sensor itself. I would Make sure the throttle valve connectors are secure and clean. Check for cuts or other damage. Reset the codes and see if they come back.
  16. Welcome to RennTech :welcome: On North American cars, it is under the passenger's seat, so I'd look under your driver's side.
  17. A Durametric is not going to help you with that; and I'm not sure how much the PIWIS or PST II can alter those as well.
  18. Does your pump look like this:
  19. Based upon customer experience, a TPMS will give you some alert time if the tire loses air slowly; but if the tire simply blows out catastrophically and loses all the air suddenly, the TPMS would not give you a chance to pull over from highway speeds before the tire was toast.
  20. Not to take anything away from your OBD II scan tool, but there are systems on these cars that a "global" OBD II scanner simply cannot access or read. If your lady Porsche specialist has the diagnostic tool, I would let her have a look at it and the sensor she is questioning. Without reliable diagnostics data, we are simply guessing and throwing out ideas.
