JFP in PA
  1. Usually, these problems are caused by the starter Bendix drive hanging up due to corrosion or build up on the starter shaft. Pull the starter and clean the Bendix drive with something like WD 40, then dry it and lubricate it with DuPont Dry Teflon spray and reinstall the starter. We do this all the time with customer cars with very few actually needing an expensive new starter.
  2. Usually, P0102 is a wiring break or short, and you should be checking the wiring from the MAF to the DME (where it gets its power), not the ignition switch.
  3. 5 inches of water, or slightly below, should be fine. Is the new AOS factory or aftermarket? I ask because we have had no luck with non factory AOS units, way too many were bad right out of the box; although the ones that failed also showed high vacuum as well. Have you pulled the intake boots and checked for oil residue?
  4. If you do that, you have a "Frankenstein" car with a significantly reduced value. If you are not going to do a proper transplant, sell it as a roller to someone that will.
  5. In a very large plastic bag on the passenger's seat.
  6. The short answer is that some of these products do at least temporarily stop leaks, but also can gum up the system, much the way fix-a-flat fills a tire with goop. A better way is to trace down the leaking part and replace it.
  7. The answer is no, only a PIWIS or PST II can program the door locks.
  8. OK, you have a five chain engine, which by design is less prone to jumping time during service. You will need to pin the crank pulley at TDC, then pull the cam plug on the driver’s side rear cylinder head and install the shorter of the two cam locks. Once that is done, you can remove and replace the hydraulic tensioners one at a time.
  9. Welcome to RennTech Anytime you hit the limiter, it is recorded in the DME, regardless of the circumstances.
  10. Welcome to RennTech What is the year and model of the car?
  11. Unfortunately, there are no after market tools as the application is just too small. Shops like mine are stuck buying the factory unit. It can be done using a tool fabricated from four inch plastic pipe unions and using your old flywheel bolts, but all the photos of that have also been lost.
  12. The new design PTFE seal must be set to a critical depth in order to work properly, and all surfaces must be absolutely clean. Even a finger print can cause leakage. The blue plastic sleeve is designed to hold the seal in the correct shape and protect the surface, the factory tool allows the seal to be installed into the tool with the sleeve still in place, and the sleeve is retained in the tool after the installation is complete. Absolutely NO sealants of any kind should be used as they will also cause leakage. All of the pictures in the above posts were lost when Photoucket changed their rules, they cannot be recovered.
  13. Using too much sealant is a common DIY problem on these engines. Along with blowing out the cam plugs, we have seen oiling issues that were traced to a spaghetti like clog of the main oil pickup in the sump from the excess sealant that breaks off. As others have noted, first the mating surfaces must be scrupulously clean, and then only the bare minimum (a couple of MM) of sealant applied. Unfortunately, trying to work on these surfaces while lying on your back with oil dripping in your face, and while you can't even properly see the surfaces, leads to a multitude of issues. Along with blocking oil passages, when too much sealant is applied, subsequent repairs become problematic because the covers are not just sealed, they are cemented in place. When that happens, people end up breaking the cam covers trying to get them off. Then they discover that you cannot just substitute another cover because the cover and cylinder head is machined as a unit. Now you are in the market for an entirely new cylinder head assembly, which is both a major pain as well as a major expense.
  14. +1 We have several terminal extractors around the shop, but this is the one everybody reaches for.
  15. Don't be hard on yourself, this is not that uncommon a mistake for someone doing this for the first time. Fecal matter occurs, just be happy you have not caused bigger problems.
  16. I would get under the car and look at the cables and their mounts on the gear box; when these come loose, all Hell sets in............
  17. As I mentioned, one with at least 20 Amps out put; in the shop we use a commercial charger that can throw over 100 Amps when needed. I would look for one with what is called "smart charging", which simply means it uses modern electronics and software to control the charge cycle.
  18. It is a common misconception that a battery maintainer is capable of recharging a severely discharged battery. In reality, the maintainer simply cannot produce the current (read amps) necessary to recharge the battery, if it can be recharged. Many times, a deeply discharged flooded cell battery simply cannot recover and will not take a charge. Try recharging the battery on a real charger capable of 20 amps or more. If it does not recover, replace it.
  19. Fault code 4460 -- Pressure sensor Possible cause of fault - Short circuit to ground/voltage or open circuit in circuit to control module terminals 25, 26 and 42 - Plug connection on stop light switch faulty - Adjustment of the stop light switch not OK - Wiring/ plug connection faulty - Pressure sensor faulty (replace hydraulic unit)
  20. Welcome to RennTech Have that cylinder bore scoped, looking for usual wear on the thrust side.
  21. Welcome to RennTech Probably the cables used by the shifter to select gears, which may have hung up due to recently being taken apart. I would not worry about it unless it happens again.
  22. Have you actually replaced the bad vacuum lines or are you still running with them patched?
  23. I do not believe the internal filter is available as a separate part.
  24. Depending upon how the vehicle is equipped, you will probably need to lower the engine slightly.
  25. Welcome to RennTech If you are referring to the M6X35 bolt that hold the manifold to the cylinder head, it should be 10Nm or 7.5 ft lb.
