JFP in PA
  1. The DME gets the single from the temperature sensor and communicates with the cluster via CAN Bus. Disconnecting the temp sensor throws a "no sensor" code, but does not mean that the sensor is good by default. The coolant temp sensor can be read live (actual temp values) using a Porsche scan tool. If suspect bad, replace it, it is not that expensive or difficult.
  2. LN Engineering has just announced online access to their database of installed retrofit bearings. You can search by the LN door sticker number, or by VIN number to see if an LN bearing has been installed, when it was done, who did it, and the mileage at that time it was installed. Caveats are that the installer had to register the installation, which not all did, and assumes the same engine is still in the car. This should help those looking at used cars with claimed installed retrofits determine if the claim is real. http://imsretrofit.com/ims-check/
  3. The only method I am aware of is to use a PIWIS unit.
  4. If there is a large amount of ferrous metal, it really does not matter where it came from, the engine has to come apart.
  5. Usually more like the other way around. When the valve lift system goes haywire, you can get strange O2 sensor readings as the mixture has gone off kilter. Look at the valve control system first. You may still have a failing O2 sensor, but I rather doubt it.
  6. When the Durametric triggers the VarioCam units, you should see the real time values jump as well. .
  7. Sorry for the typo, it should have read "fluid temperature sensor" The DME monitor's the sensor electrically and converts that signal into temperature; when the limit is reached in the DME's softweare, the fans switch on until the temperature drops.
  8. To my knowledge, there has never been an IMS recall on any model. Porsche was hit with a class action over the IMS, but that did not result in a recall.
  9. Pull the oil filter and check it for debris. If you find any, check to see if it is ferrous (attracted to a magnet). If you find ferrous debris, you have a major issue, if there is none, I would start investigating the noise further.
  10. Welcome to RennTech First of all, posting in all caps is considered rude by many posters, and is completely unnecessary. Most likely, your problem is a filled temperature sensor on the engine, but I would not be driving the car until a shop can confirm and repair the issue. These engines are very sensitive to damage caused by overt heating, and with an inoperative dash display you really don’t know where the actual temp is.
  11. Basically, there are two types if retrofits: Those that did LN Engineering, and those that wish they did. LN & Jake. Raby invented the retrofit when Porsche said it could not be done, developed the necessary tools and procedures, and worked with bearing engineers to find the optimum ceramic hybrid replacement. Jake even tested designs to destruction to prove the concept. Everyone else now in the business have an off the shelf, “me too” fix; some of which have no real history, or a very limite one. LN has been successfully retrofitting for many years now, with over 25,000 retrofits on the road. In addition to the ceramic hybrid ball bearings version, they also make the IMS Solution, which is an oil fed solid bearing which is the only “life of the engine” retrofit, and the only one that can be moved to another engine. Not the cheapest retrofit, but definitely one that draws attention at resale time.
  12. If you are referring to Version 6.5.4.8, it has been out for nearly a month (Sep 27, 2017).
  13. The tool you used is designed for the Viton RMS seal, not the later PTFE seal, and will install the later seal at the incorrect depth. Currently, only Porsche makes the correct tool for the PTFE seal, or you need to make your own.
  14. Unfortunately, that diagram is copyrighted material, so posting it would be a violation of intellectual property rights, which is prohibited on this site.
  15. Welcome to RennTech As the code is emissions related, it A may take serveral drive cycles to reset, assuming the cap is OK.
  16. They are going to have to have a PIWIS, which all dealers do, as well as some independents. You need to ask if they have one as you are going nowhere without it, and for security reasons, they are going to need the car as well..
  17. You cannot just swap DME's as the Vag-com will not be able to do all the necessary recoding; that requires access to a PIWIS
  18. You should first scan the car with a Porsche specific scan tool (Durametric, PIWIS), which can start the SAI pump without the car running. If it does not run, I would check the electrical connections to the pump, and attempt to run it on the bench before replacing it. Sometimes these pumps get gummed up internally and a simple clean out gets them back up and running.
  19. No, the child seat option can simply be turned off.
  20. I would check the MAF values. Often, when a MAF is either very dirty, or on its way out, rough idle is a common complaint. The VarioCam system can be fully tested with a Porsche scan tool like the Durametric system (which can also check the MAF values); I would test that before even thinking about replacing any components in the system as they are all rather $.
  21. Welcome to RennTech You need to correctly clear the fault code.
  22. Welcome to RennTech Unfortunately, you are not going to be able to hone out that amount of liner damage, and even if you could, the pistons would be so loose in the bores you would have even larger issues.
